Hi OpenHab Community!
I’ve got a Fibaro Multisensor that worked with OpenHAB 1.8, but I couldn’t get this working with OH 2 that I just setted up. First I installed the beta 4 version via package repository, afterwards changed to snapshot, but today I started again from scratch with the snapshot manual installation.
I removed all openhab files from my debian system (on a RasPi 2 using Raspbian). The node10.xml file wasn’t regenerated afterwards.
The device was added as a thing and listed in the things overview in HABmin, but is shown as unknown
. In the attributes
tab no information are available (e. g. no manufacturer). I also pushed the button three times to start initialization again, according to the log the device woke up and communicated with my controller.
My other z-wave devices are working.
Maybe the first lines of the log are already helpful, you can find the full log for this node in the attachment (see below):
2016-12-19 23:19:14.228 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 10: Node found
2016-12-19 23:20:54.956 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 10: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2016-12-19 23:21:16.790 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising Thing Node...
2016-12-19 23:45:45.962 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: MANUFACTURER not set
2016-12-19 23:45:49.532 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 10: Node found
2016-12-19 23:45:49.683 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 10: Init node thread start
2016-12-19 23:45:50.589 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 10: Serializing from file /opt/openhab2/userdata/zwave/node10.xml
2016-12-19 23:45:50.590 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 10: Error serializing from file: file does not exist.
2016-12-19 23:45:50.786 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 10: Starting initialisation from EMPTYNODE
Looks like communication is working:
2016-12-20 00:01:00.541 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 19.9
- OH2 Version: 2.0.0.201612180944
- Binding Version: 2.0.0.201612180944
- Device name: Fibaro FIBEFGMS-001-ZW5 5G 4-in-1 Multisensor
- Device version: I assume >= 3.2
Here you could find the log where I only extracted loggings related to the node, I hope that’s enough: node10-20161219.log.txt
Right now no new xml file was generated, but here is an old one for this device I saved before reinstalling everything:
node10.xml.txt
Thanks for your support and best regards,
Christian
