I have installed a Aeon Z-Stick Gen 5. The controller is seen fine within PaperUI.
I add a Leviton DZ15S-1BZ to the controller and it shows up in my inbox. However it is coming up as an unknown device.
Z-Wave Node 004
Unknown Device
This device has not been fully discovered by the binding. There are a few possible reasons for this -:
The device is not in the database. If the device attributes show that this device has a valid manufacturer ID, device ID and type, then this is likely the case (eg. you see a label like “Z-Wave node 1 (0082:6015:020D::2.0)”). Even if the device appears to be in the database, some manufacturers use multiple sets of references for different regions or versions, and your device references may not be in the database. In either case, the database must be updated and you should raise an issue to get this addressed.
The device initialisation is not complete. Once the device is included into the network, the binding must interrogate it to find out what type of device it is. One part of this process is to get the manufacturer information required to identify the device, and until this is done, the device will remain unknown. For mains powered devices, this will occur quickly, however for battery devices the device must be woken up a number of times to allow the discovery phase to complete. This must be performed with the device close to the controller.
Status: ONLINE
zwave_class_basic BASIC_TYPE_ROUTING_SLAVE
zwave_class_generic GENERIC_TYPE_SWITCH_BINARY
zwave_frequent false
zwave_neighbours 1
zwave_nodeid 4
zwave_version 0.0
zwave_listening true
zwave_routing true
zwave_beaming true
zwave_secure false
zwave_class_specific SPECIFIC_TYPE_POWER_SWITCH_BINARY
This device was previously added no problem, however I was having other issues and reinstalled OpenHabian.
Any clues what I can do to get this device detected correctly again? Did my database not update? I am using the Jan 18 ZWave 2.3 jar file installed into my addons folder.
Thank you.
