Hey @chris, i bought myself a Z-Wave.Me WALLC-2 controller.
can you add it? as it was not found in de db.
node29.xml (4.4 KB)
2016-03-10 16:07:08.116 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 29: Device could not be resolved to a thingType! 0154:0100:0101::1.1
Button presses behave al follows:
Button 1 press:
2016-03-10 16:10:37.750 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 1D 05 5B 03 BF 00 01 0E
2016-03-10 16:10:37.753 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-03-10 16:10:37.754 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0B 00 04 00 1D 05 5B 03 BF 00 01 0E
2016-03-10 16:10:37.756 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0B 00 04 00 1D 05 5B 03 BF 00 01 0E
2016-03-10 16:10:37.757 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, payload=00 1D 05 5B 03 BF 00 01
2016-03-10 16:10:37.758 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 29: Application Command Request (ALIVE:DONE)
2016-03-10 16:10:37.759 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 29: Incoming command class CENTRAL_SCENE
2016-03-10 16:10:37.760 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 29: Command class CENTRAL_SCENE not found, trying to add it.
2016-03-10 16:10:37.761 [WARN ] [tocol.commandclass.ZWaveCommandClass] - NODE 29: Unsupported command class CENTRAL_SCENE
2016-03-10 16:10:37.762 [ERROR] [ssage.ApplicationCommandMessageClass] - NODE 29: Unsupported command class CENTRAL_SCENE (0x5b)
Button 2 press:
2016-03-10 16:10:42.139 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 1D 05 5B 03 C0 00 02 72
2016-03-10 16:10:42.141 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-03-10 16:10:42.143 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0B 00 04 00 1D 05 5B 03 C0 00 02 72
2016-03-10 16:10:42.144 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0B 00 04 00 1D 05 5B 03 C0 00 02 72
2016-03-10 16:10:42.151 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, payload=00 1D 05 5B 03 C0 00 02
2016-03-10 16:10:42.152 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 29: Application Command Request (ALIVE:DONE)
2016-03-10 16:10:42.154 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 29: Incoming command class CENTRAL_SCENE
2016-03-10 16:10:42.155 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 29: Command class CENTRAL_SCENE not found, trying to add it.
2016-03-10 16:10:42.156 [WARN ] [tocol.commandclass.ZWaveCommandClass] - NODE 29: Unsupported command class CENTRAL_SCENE
2016-03-10 16:10:42.157 [ERROR] [ssage.ApplicationCommandMessageClass] - NODE 29: Unsupported command class CENTRAL_SCENE (0x5b)
Button 3 press:
2016-03-10 16:10:45.699 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 1D 05 5B 03 C1 00 03 72
2016-03-10 16:10:45.707 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-03-10 16:10:45.709 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0B 00 04 00 1D 05 5B 03 C1 00 03 72
2016-03-10 16:10:45.710 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0B 00 04 00 1D 05 5B 03 C1 00 03 72
2016-03-10 16:10:45.712 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, payload=00 1D 05 5B 03 C1 00 03
2016-03-10 16:10:45.716 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 29: Application Command Request (ALIVE:DONE)
2016-03-10 16:10:45.717 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 29: Incoming command class CENTRAL_SCENE
2016-03-10 16:10:45.718 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 29: Command class CENTRAL_SCENE not found, trying to add it.
2016-03-10 16:10:45.719 [WARN ] [tocol.commandclass.ZWaveCommandClass] - NODE 29: Unsupported command class CENTRAL_SCENE
2016-03-10 16:10:45.720 [ERROR] [ssage.ApplicationCommandMessageClass] - NODE 29: Unsupported command class CENTRAL_SCENE (0x5b)
Button 4 press:
2016-03-10 16:10:48.153 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 1D 05 5B 03 C2 00 04 76
2016-03-10 16:10:48.156 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-03-10 16:10:48.157 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0B 00 04 00 1D 05 5B 03 C2 00 04 76
2016-03-10 16:10:48.159 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0B 00 04 00 1D 05 5B 03 C2 00 04 76
2016-03-10 16:10:48.161 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, payload=00 1D 05 5B 03 C2 00 04
2016-03-10 16:10:48.162 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 29: Application Command Request (ALIVE:DONE)
2016-03-10 16:10:48.163 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 29: Incoming command class CENTRAL_SCENE
2016-03-10 16:10:48.164 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 29: Command class CENTRAL_SCENE not found, trying to add it.
2016-03-10 16:10:48.165 [WARN ] [tocol.commandclass.ZWaveCommandClass] - NODE 29: Unsupported command class CENTRAL_SCENE
2016-03-10 16:10:48.166 [ERROR] [ssage.ApplicationCommandMessageClass] - NODE 29: Unsupported command class CENTRAL_SCENE (0x5b)
Do you need more info?
