Chrishab
(Christian)
1
I bought several of the below motion sensors on AliExpress:
https://www.aliexpress.com/item/NEO-COOLCAM-Z-wave-PIR-Motion-Sensor-Detector-Temperature-Sensor-Home-Automation-Alarm-System-Motion-Alarm/32836387244.html
https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/401
They are recognized just fine by the binding but I noticed that I only have a binary sensor channel available.
In the log I see
2018-10-27 10:34:50.762 [vent.ItemStateChangedEvent] - motion01_motion changed from OFF to ON
but in BasicUI it just shows “triggered” and “untriggered”.
Sorry for my stupid question, but: shouldn’t there be another switch channel that just triggers “ON/OFF”?
network_e5b25217__node_4.xml (14.0 KB)
Thanks in advance for any hints!
Chrishab
(Christian)
2
Hi @chris,
I still can’t get it to work (showing triggered/untriggered in BasicUI)
I found an old tread (Sensor recognised as switch) where you mentioned to use another channel.
Does this device have another channel we could use in the database?
Please help
chris
(Chris Jackson)
3
I’ve made an update to the database. Let’s see if that fixes it - it not, please provide a log showing what is received.
Chrishab
(Christian)
4
Wow, thank you @chris
I suppose I have to wait for the next OH release? Or is the device data independent from the binding?
chris
(Chris Jackson)
5
Yes, it will be in the next snapshot which I’ll try and do either tonight, or tomorrow night.
