In one of my rooms, I have a node (it is a gen 5 roller Qubino shutter, ZMNHCD), which does not work very good.
It will proably very seldom have contact with the zstick (gen 5 from aeon).
First I tried to heal the node, which made no difference, (did not check if the node actually got the heal message, probably not). Then I healed two neighbours, and finally I selected re-initialize on the bad node.
Anyway, for days it has now been offline, so I decided to investigate a little again.
What I did was to heal one of the very nearest neighbours, which revealed that it saw the bad node (it was in its neighbor list).
I then excluded/included the bad node again, in the hope that something good would come out. It didn’t.
Now, when I start up oh2, the zwave binding reports that the controller has a new node (67) that ought to be the bad device. However, no longer does it have node 66, which incidently is also a qubino gen 5 (but a dimmer) on the second floor just above the shutter.
The old shutter node address (60) is still in the controller list, however.
13:44:54.761 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
13:44:54.761 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 2: Node found
13:44:54.761 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 3: Node found
13:44:54.761 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 4: Node found
13:44:54.761 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 5: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 6: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 7: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 8: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 9: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 11: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 12: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 14: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 15: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 16: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 17: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 18: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 19: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 20: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 21: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 22: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 23: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 25: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 26: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 27: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 28: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 29: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 30: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 31: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 32: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 33: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 34: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 35: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 36: Node found
13:44:54.762 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 37: Node found
13:44:54.763 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 38: Node found
13:44:54.763 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 39: Node found
13:44:54.763 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 40: Node found
13:44:54.763 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 41: Node found
13:44:54.763 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 42: Node found
13:44:54.763 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 43: Node found
13:44:54.763 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 46: Node found
13:44:54.763 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 47: Node found
13:44:54.763 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 48: Node found
13:44:54.763 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 53: Node found
13:44:54.763 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 54: Node found
13:44:54.763 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 56: Node found
13:44:54.763 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 57: Node found
13:44:54.763 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 58: Node found
13:44:54.763 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 59: Node found
13:44:54.763 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 60: Node found
13:44:54.763 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 61: Node found
13:44:54.763 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 62: Node found
13:44:54.763 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 63: Node found
13:44:54.763 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 64: Node found
13:44:54.763 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 65: Node found
13:44:54.763 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 67: Node found
13:44:54.763 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 68: Node found
13:44:54.764 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 69: Node found
13:44:54.764 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
13:44:54.769 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
13:44:54.769 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
13:44:54.769 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 58
13:44:54.775 [INFO ] [age.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
Still 67 does not come online. But also (naturaly) 66 does show as off line.
Is this a bug in the Aeon stick? I used the sticks own exclude/include function, and while it seamed to work, the exclusion happened after 3 clicks on the node button after power on, not after 5 clicks as the manual said.
Edit: Reading the manual in detail, it says changes, so I think one click is two changes, which explains this.
So if I understand this correctly, it removed the wrong device. ?? Seams very fragile to me.
Then I look further down the log, and I see something that confuses me, but I guess this is something not related, but it is versy strange to see that node 66 is referenced in the same line as ‘online’.
13:44:55.136 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Controller status changed to ONLINE.
13:44:55.136 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Controller is ONLINE. Starting device initialisation.
13:44:55.136 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising Thing Node...
13:44:55.136 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising channel zwave:device:controller:node66:switch_binary
13:44:55.136 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising cmd channel zwave:device:controller:node66:switch_binary
13:44:55.136 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising poll channel zwave:device:controller:node66:switch_binary
13:44:55.136 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising state channel zwave:device:controller:node66:switch_binary
13:44:55.136 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising channel zwave:device:controller:node66:switch_dimmer
13:44:55.136 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising cmd channel zwave:device:controller:node66:switch_dimmer
13:44:55.136 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising poll channel zwave:device:controller:node66:switch_dimmer
13:44:55.136 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising state channel zwave:device:controller:node66:switch_dimmer
13:44:55.136 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising channel zwave:device:controller:node66:sensor_binary
13:44:55.136 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising cmd channel zwave:device:controller:node66:sensor_binary
13:44:55.136 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising poll channel zwave:device:controller:node66:sensor_binary
13:44:55.136 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising state channel zwave:device:controller:node66:sensor_binary
13:44:55.136 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising channel zwave:device:controller:node66:sensor_temperature
13:44:55.136 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising cmd channel zwave:device:controller:node66:sensor_temperature
13:44:55.136 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising poll channel zwave:device:controller:node66:sensor_temperature
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising state channel zwave:device:controller:node66:sensor_temperature
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising channel zwave:device:controller:node66:meter_kwh
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising cmd channel zwave:device:controller:node66:meter_kwh
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising poll channel zwave:device:controller:node66:meter_kwh
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising state channel zwave:device:controller:node66:meter_kwh
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising channel zwave:device:controller:node66:meter_watts
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising cmd channel zwave:device:controller:node66:meter_watts
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising poll channel zwave:device:controller:node66:meter_watts
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising state channel zwave:device:controller:node66:meter_watts
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising channel zwave:device:controller:node66:alarm_general
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising cmd channel zwave:device:controller:node66:alarm_general
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising poll channel zwave:device:controller:node66:alarm_general
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising state channel zwave:device:controller:node66:alarm_general
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising channel zwave:device:controller:node66:switch_binary1
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising cmd channel zwave:device:controller:node66:switch_binary1
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising poll channel zwave:device:controller:node66:switch_binary1
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising state channel zwave:device:controller:node66:switch_binary1
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising channel zwave:device:controller:node66:switch_dimmer1
13:44:55.137 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 40: Restore from config: Ok.
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising cmd channel zwave:device:controller:node66:switch_dimmer1
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising poll channel zwave:device:controller:node66:switch_dimmer1
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising state channel zwave:device:controller:node66:switch_dimmer1
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising channel zwave:device:controller:node66:meter_kwh1
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising cmd channel zwave:device:controller:node66:meter_kwh1
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising poll channel zwave:device:controller:node66:meter_kwh1
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising state channel zwave:device:controller:node66:meter_kwh1
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising channel zwave:device:controller:node66:meter_watts1
13:44:55.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising cmd channel zwave:device:controller:node66:meter_watts1
13:44:55.138 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising poll channel zwave:device:controller:node66:meter_watts1
13:44:55.138 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising state channel zwave:device:controller:node66:meter_watts1
13:44:55.138 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising channel zwave:device:controller:node66:sensor_binary2
13:44:55.138 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising cmd channel zwave:device:controller:node66:sensor_binary2
13:44:55.138 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising poll channel zwave:device:controller:node66:sensor_binary2
13:44:55.138 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising state channel zwave:device:controller:node66:sensor_binary2
13:44:55.138 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising channel zwave:device:controller:node66:alarm_general2
13:44:55.138 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising cmd channel zwave:device:controller:node66:alarm_general2
13:44:55.138 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising poll channel zwave:device:controller:node66:alarm_general2
13:44:55.138 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising state channel zwave:device:controller:node66:alarm_general2
13:44:55.138 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising channel zwave:device:controller:node66:sensor_binary3
13:44:55.138 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising cmd channel zwave:device:controller:node66:sensor_binary3
13:44:55.138 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising poll channel zwave:device:controller:node66:sensor_binary3
13:44:55.138 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising state channel zwave:device:controller:node66:sensor_binary3
13:44:55.138 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising channel zwave:device:controller:node66:alarm_general3
13:44:55.138 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising cmd channel zwave:device:controller:node66:alarm_general3
13:44:55.138 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising poll channel zwave:device:controller:node66:alarm_general3
13:44:55.138 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Initialising state channel zwave:device:controller:node66:alarm_general3
13:44:55.138 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Polling intialised at 1800 seconds - start in 1800000 milliseconds.
So I guess I will now exclude both the dimmer (66) and the shutter (60/67).
@chris is this something you have seen, or can explain?
Edit: And later on, I see a poll on 66!?
14:44:55.138 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Polling...
14:44:55.139 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 66: Polling deferred until initialisation complete
