Hi all,
I am having a strange behaviour in my system.
I am running latest 2.2 stable and I have few ZWave units.
If I control the Zwave switches one by one in the sitemap they work correctly and react immediately.
But if create a scene in a rule then the behaviour is weird.
Sometimes the zwave devices do not respond, sometimes they respond with a lot of delay.
Attached is a debug and event log case where the zwave responded with several seconds of delay after selecting SceneNumber = 2.
The most delayed one is node3 that is a FIBARO FGS-222.
Here is the scene:
import org.openhab.core.library.types
import org.openhab.model.script.actions
rule "Movie Scene Selector"
Item nMovieScene received command
if (nMovieScene.state == 0) {
//all OFF
zsRGBW_AllSwitch.sendCommand(OFF)
Thread::sleep(100)
zsLedNord.sendCommand(OFF)
Thread::sleep(100)
zsLedSud.sendCommand(OFF)
Thread::sleep(100)
zsDimmer1.sendCommand(OFF)
Thread::sleep(100)
sX10A13.sendCommand(OFF)
} else if (nMovieScene.state == 1) {
//led blue at 3%
zdRGBW_R.sendCommand(1)
Thread::sleep(100)
zdRGBW_G.sendCommand(3)
Thread::sleep(100)
zdRGBW_B.sendCommand(3)
Thread::sleep(100)
zdRGBW_W.sendCommand(0)
Thread::sleep(100)
Thread::sleep(100)
Thread::sleep(100)
Thread::sleep(100)
Thread::sleep(100)
} else if (nMovieScene.state == 2) {
//led blue at 7%
zdRGBW_R.sendCommand(2)
Thread::sleep(100)
zdRGBW_G.sendCommand(7)
Thread::sleep(100)
zdRGBW_B.sendCommand(7)
Thread::sleep(100)
Thread::sleep(100)
Thread::sleep(100)
Thread::sleep(100)
Thread::sleep(100)
} else if (nMovieScene.state == 3) {
//led blue at 100% + white at 50%
zdRGBW_R.sendCommand(28)
Thread::sleep(100)
zdRGBW_G.sendCommand(100)
Thread::sleep(100)
zdRGBW_B.sendCommand(100)
Thread::sleep(100)
zdRGBW_W.sendCommand(50)
Thread::sleep(100)
Thread::sleep(100)
Thread::sleep(100)
Thread::sleep(100)
} else if (nMovieScene.state == 4) {
//led white at 50%
zdRGBW_R.sendCommand(0)
Thread::sleep(100)
zdRGBW_G.sendCommand(0)
Thread::sleep(100)
zdRGBW_B.sendCommand(0)
Thread::sleep(100)
zdRGBW_W.sendCommand(75)
Thread::sleep(100)
Thread::sleep(100)
Thread::sleep(100)
} else if (nMovieScene.state == 5) {
//led spot ON
Thread::sleep(100)
zsLedNord.sendCommand(ON)
Thread::sleep(100)
zsLedSud.sendCommand(ON)
Thread::sleep(100)
} else if (nMovieScene.state == 6) {
//all OFF
Thread::sleep(100)
Thread::sleep(100)
Thread::sleep(100)
Here are the z-wave items:
// Fibaro 2x1.5kW (node=3; ID=fibaro_fgs222_00_000)
Switch zsLedNord "Led Nord" <switch> (gSalotto,gZwave) {channel="zwave:device:controller:node3:switch_binary"}
Switch zsLedSud "Led Sud" <switch> (gSalotto,gZwave) {channel="zwave:device:controller:node3:switch_binary2"}
// Fibaro 2x1.5kW 2 (node=5; ID=fibaro_fgs222_00_000)
Switch zsSwitch1 "Switch1" <switch> (gSalotto,gZwave) {channel="zwave:device:controller:node5:switch_binary"}
Switch zsSwitch2 "Switch2" <switch> (gSalotto,gZwave) {channel="zwave:device:controller:node5:switch_binary2"}
// FIBARO DIMMER (node=8; ID=fibaro_fgd211_02_001)
Switch zsDimmer1 "Switch Alogena" <switch> (gSalotto,gZwave) {channel="zwave:device:controller:node8:switch_dimmer"}
Dimmer zdDimmer1 "Dimmer Alogena" <slider> (gSalotto,gZwave) {channel="zwave:device:controller:node8:switch_dimmer"}
// Fibaro RGBW (node=7; ID=fibaro_fgrgbw_00_000)
Color zcRGBW "RGBW ColorPicker" <slider> (gSalotto,gZwave,gzRGBW) {channel="zwave:device:controller:node7:color_color"}
Dimmer zdRGBW_All "RGBW All" <slider> (gSalotto,gZwave,gzRGBW) {channel="zwave:device:controller:node7:switch_dimmer"}
Dimmer zdRGBW_R "RGBW Red [%d %%]" <slider> (gSalotto,gZwave,gzRGBW) {channel="zwave:device:controller:node7:switch_dimmer2"}
Dimmer zdRGBW_G "RGBW Green [%d %%]" <slider> (gSalotto,gZwave,gzRGBW) {channel="zwave:device:controller:node7:switch_dimmer3"}
Dimmer zdRGBW_B "RGBW Blue [%d %%]" <slider> (gSalotto,gZwave,gzRGBW) {channel="zwave:device:controller:node7:switch_dimmer4"}
Dimmer zdRGBW_W "RGBW White" <slider> (gSalotto,gZwave,gzRGBW) {channel="zwave:device:controller:node7:switch_dimmer5"}
Switch zsRGBW_AllSwitch "RGBW SwitchAll" <switch> (gSalotto,gZwave,gzRGBW) {channel="zwave:device:controller:node7:switch_dimmer"}
Switch zsRGBW_RSwitch "RGBW SwitchRed" <switch> (gSalotto,gZwave,gzRGBW) {channel="zwave:device:controller:node7:switch_dimmer2"}
Switch zsRGBW_GSwitch "RGBW SwitchGreen" <switch> (gSalotto,gZwave,gzRGBW) {channel="zwave:device:controller:node7:switch_dimmer3"}
Switch zsRGBW_BSwitch "RGBW SwitchBlue" <switch> (gSalotto,gZwave,gzRGBW) {channel="zwave:device:controller:node7:switch_dimmer4"}
Switch zsRGBW_WSwitch "RGBW SwitchWhite" <switch> (gSalotto,gZwave,gzRGBW) {channel="zwave:device:controller:node7:switch_dimmer5"}
Number znRGBW_Power "RGBW Potenza [%.1f W]" <energy> (gSalotto,gZwave,gzRGBW) {channel="zwave:device:controller:node7:meter_watts"}
Number znRGBW_Energy "RGBW Energia [%.2f KWh]" <energy> (gSalotto,gZwave,gzRGBW) {channel="zwave:device:controller:node7:meter_kwh"}
Number znRGBW_Programs "RGBW Programs" <switch> (gSalotto,gZwave,gzRGBW) {channel="zwave:device:controller:node7:scene_number_param72"}
String zsRGBW_ProgName "RGBW Program Name: [%s]" <switch> (gSalotto,gZwave,gzRGBW) //valore calcolato nelle RULES
// TEST
Color zcRGBWtest "RGBW TEST ColorPicker" <slider> (gSalotto,gZwave,gzRGBW)
// VIRTUAL
Number nMovieScene "MovieScene" <switch> (gSalotto,gZwave,gzRGBW) //valore calcolato nelle RULES
The debug log is attached (had to change the name to .xml to be able to upload)
openhab.xml (50.7 KB)
and the event.log
2017-12-26 17:01:18.626 [ome.event.ItemCommandEvent] - Item 'nMovieScene' received command 2
2017-12-26 17:01:18.630 [vent.ItemStateChangedEvent] - nMovieScene changed from 0 to 2
2017-12-26 17:01:18.648 [ome.event.ItemCommandEvent] - Item 'zdRGBW_R' received command 2
2017-12-26 17:01:18.662 [vent.ItemStateChangedEvent] - zdRGBW_R changed from 0 to 2
2017-12-26 17:01:18.752 [ome.event.ItemCommandEvent] - Item 'zdRGBW_G' received command 7
2017-12-26 17:01:18.758 [vent.ItemStateChangedEvent] - zdRGBW_G changed from 0 to 7
2017-12-26 17:01:18.856 [ome.event.ItemCommandEvent] - Item 'zdRGBW_B' received command 7
2017-12-26 17:01:18.872 [vent.ItemStateChangedEvent] - zdRGBW_B changed from 0 to 7
2017-12-26 17:01:18.874 [vent.ItemStateChangedEvent] - zsRGBW_RSwitch changed from OFF to ON
2017-12-26 17:01:18.896 [vent.ItemStateChangedEvent] - zsRGBW_AllSwitch changed from OFF to ON
2017-12-26 17:01:18.912 [vent.ItemStateChangedEvent] - zdRGBW_All changed from 0 to 2
2017-12-26 17:01:18.914 [vent.ItemStateChangedEvent] - zcRGBW changed from 0,0,0 to 0,0,2
2017-12-26 17:01:18.962 [ome.event.ItemCommandEvent] - Item 'zdRGBW_W' received command 0
2017-12-26 17:01:19.062 [ome.event.ItemCommandEvent] - Item 'zsLedNord' received command OFF
2017-12-26 17:01:19.072 [vent.ItemStateChangedEvent] - zsLedNord changed from ON to OFF
2017-12-26 17:01:19.166 [ome.event.ItemCommandEvent] - Item 'zsLedSud' received command OFF
2017-12-26 17:01:19.174 [vent.ItemStateChangedEvent] - zsLedSud changed from ON to OFF
2017-12-26 17:01:19.214 [vent.ItemStateChangedEvent] - zsRGBW_GSwitch changed from OFF to ON
2017-12-26 17:01:19.249 [vent.ItemStateChangedEvent] - zsRGBW_BSwitch changed from OFF to ON
2017-12-26 17:01:19.262 [vent.ItemStateChangedEvent] - zdRGBW_All changed from 2 to 7
2017-12-26 17:01:19.264 [vent.ItemStateChangedEvent] - zcRGBW changed from 0,0,2 to 0,0,7
2017-12-26 17:01:19.270 [ome.event.ItemCommandEvent] - Item 'zsDimmer1' received command OFF
2017-12-26 17:01:19.373 [ome.event.ItemCommandEvent] - Item 'sX10A13' received command OFF
