Interestingly, after changing the channel’s profile from Default
to (No Profile)
(effectively a noop), the status is correctly polled when the device hails:
2021-03-17 15:43:23.379 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling...
2021-03-17 15:45:08.250 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Channel zwave:device:949245ad36:node2:switch_dimmer unlinked - polling stopped.
2021-03-17 15:45:08.270 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Channel zwave:device:949245ad36:node2:switch_dimmer linked - polling started.
2021-03-17 15:45:47.719 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Received SOF
2021-03-17 15:45:47.720 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0A 00 04 00 02 02 82 01 D5 00 A7
2021-03-17 15:45:47.721 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Creating new SerialMessage from buffer = 01 0A 00 04 00 02 02 82 01 D5 00 A7
2021-03-17 15:45:47.721 [TRACE] [wave.internal.protocol.SerialMessage] - Calculated checksum = -89
2021-03-17 15:45:47.721 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Checksum matched
2021-03-17 15:45:47.722 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 2: Message payload = 00 02 02 82 01 D5 00
2021-03-17 15:45:47.722 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Message is valid, sending ACK
2021-03-17 15:45:47.722 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2021-03-17 15:45:47.723 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 02 82 01 D5 00
2021-03-17 15:45:47.723 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 02 82 01 D5 00
2021-03-17 15:45:47.724 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2021-03-17 15:45:47.724 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Application Command Request (ALIVE:DONE)
2021-03-17 15:45:47.724 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: resetResendCount initComplete=true isDead=false
2021-03-17 15:45:47.724 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Incoming command class COMMAND_CLASS_HAIL, endpoint 0
2021-03-17 15:45:47.725 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY not supported
2021-03-17 15:45:47.725 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Received COMMAND_CLASS_HAIL V0 HAIL
2021-03-17 15:45:47.725 [TRACE] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveDelayedPollEvent
2021-03-17 15:45:47.725 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveDelayedPollEvent
2021-03-17 15:45:47.726 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling initialised at 1800 seconds - start in 75 milliseconds.
2021-03-17 15:45:47.726 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Commands processed 1.
2021-03-17 15:45:47.726 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@7df26f55.
2021-03-17 15:45:47.726 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-03-17 15:45:47.727 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-03-17 15:45:47.727 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-03-17 15:45:47.727 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-03-17 15:45:47.727 [TRACE] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage nothing
2021-03-17 15:45:47.801 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling...
2021-03-17 15:45:47.801 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling zwave:device:949245ad36:node2:switch_dimmer
2021-03-17 15:45:47.802 [DEBUG] [erter.ZWaveMultiLevelSwitchConverter] - NODE 2: Generating poll message for COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 0
2021-03-17 15:45:47.802 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 2: Creating new message for command SWITCH_MULTILEVEL_GET
2021-03-17 15:45:47.803 [TRACE] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Encapsulating message, endpoint 0
2021-03-17 15:45:47.803 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY not supported
2021-03-17 15:45:47.803 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Command Class COMMAND_CLASS_SWITCH_MULTILEVEL is NOT required to be secured
2021-03-17 15:45:47.804 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling skipped for zwave:device:949245ad36:node2:switch_dimmer on COMMAND_CLASS_BASIC
2021-03-17 15:45:47.804 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Adding to device queue
2021-03-17 15:45:47.804 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Added 120 to queue - size 1
2021-03-17 15:45:47.805 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-03-17 15:45:47.805 [TRACE] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: listening == true, frequentlyListening == false, awake == false
2021-03-17 15:45:47.806 [TRACE] [nal.protocol.ZWaveTransactionManager] - Transaction from sendQueue
2021-03-17 15:45:47.806 [TRACE] [nal.protocol.ZWaveTransactionManager] - getTransactionToSend 6
2021-03-17 15:45:47.807 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 2: Creating empty message of class = SendData (0x13), type = Request
2021-03-17 15:45:47.807 [TRACE] [wave.internal.protocol.SerialMessage] - Calculated checksum = -88
2021-03-17 15:45:47.807 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 02 02 26 02 25 4C A8
2021-03-17 15:45:47.808 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 2: Sending REQUEST Message = 01 09 00 13 02 02 26 02 25 4C A8
2021-03-17 15:45:47.808 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2021-03-17 15:45:47.810 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2021-03-17 15:45:47.810 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Creating new SerialMessage from buffer = 06
2021-03-17 15:45:47.811 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-03-17 15:45:47.812 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-03-17 15:45:47.812 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 120: Transaction Start type SendData
2021-03-17 15:45:47.812 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2021-03-17 15:45:47.812 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 120: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 76
2021-03-17 15:45:47.813 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2021-03-17 15:45:47.813 [TRACE] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: expected cmd class: COMMAND_CLASS_SWITCH_MULTILEVEL
2021-03-17 15:45:47.813 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-03-17 15:45:47.813 [TRACE] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: expected cmd: 3
2021-03-17 15:45:47.814 [TRACE] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage Transactions outstanding: 1
2021-03-17 15:45:47.815 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Received SOF
2021-03-17 15:45:47.816 [TRACE] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Wed Mar 17 15:45:49 PDT 2021 - 1999ms
2021-03-17 15:45:47.817 [TRACE] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage lastTransaction: TID 120: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 76
2021-03-17 15:45:47.817 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2021-03-17 15:45:47.817 [TRACE] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2021-03-17 15:45:47.818 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Creating new SerialMessage from buffer = 01 04 01 13 01 E8
2021-03-17 15:45:47.818 [TRACE] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Wed Mar 17 15:45:49 PDT 2021 - 1996ms
2021-03-17 15:45:47.819 [TRACE] [wave.internal.protocol.SerialMessage] - Calculated checksum = -24
2021-03-17 15:45:47.820 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Checksum matched
2021-03-17 15:45:47.820 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Message payload = 01
2021-03-17 15:45:47.821 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Message is valid, sending ACK
2021-03-17 15:45:47.822 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2021-03-17 15:45:47.822 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-03-17 15:45:47.826 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-03-17 15:45:47.826 [TRACE] [nal.protocol.ZWaveTransactionManager] - Transaction lastTransaction outstanding...
2021-03-17 15:45:47.827 [TRACE] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2021-03-17 15:45:47.827 [TRACE] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Wed Mar 17 15:45:49 PDT 2021 - 1987ms
2021-03-17 15:45:47.828 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-03-17 15:45:47.828 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 120: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 76
2021-03-17 15:45:47.829 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2021-03-17 15:45:47.829 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 120: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 76
2021-03-17 15:45:47.830 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-03-17 15:45:47.830 [TRACE] [ve.internal.protocol.ZWaveController] - Incoming Message type = RESPONSE
2021-03-17 15:45:47.831 [TRACE] [l.serialmessage.SendDataMessageClass] - Handle Message Send Data Response
2021-03-17 15:45:47.831 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: sentData successfully placed on stack.
2021-03-17 15:45:47.831 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 120: TransactionAdvance ST: WAIT_RESPONSE
2021-03-17 15:45:47.832 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 120: TransactionAdvance WT: ApplicationCommandHandler {}
2021-03-17 15:45:47.832 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 120: TransactionAdvance RX: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-03-17 15:45:47.833 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 120: TransactionAdvance TO: WAIT_REQUEST
2021-03-17 15:45:47.833 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 120: Advanced to WAIT_REQUEST
2021-03-17 15:45:47.833 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: TID 120: Transaction not completed
2021-03-17 15:45:47.834 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-03-17 15:45:47.834 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-03-17 15:45:47.834 [TRACE] [nal.protocol.ZWaveTransactionManager] - Transaction lastTransaction outstanding...
2021-03-17 15:45:47.834 [TRACE] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2021-03-17 15:45:47.835 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Received SOF
2021-03-17 15:45:47.835 [TRACE] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Wed Mar 17 15:45:52 PDT 2021 - 4998ms
2021-03-17 15:45:47.836 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 13 4C 00 00 02 00 D4 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 6F
2021-03-17 15:45:47.837 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Creating new SerialMessage from buffer = 01 18 00 13 4C 00 00 02 00 D4 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 6F
2021-03-17 15:45:47.837 [TRACE] [wave.internal.protocol.SerialMessage] - Calculated checksum = 111
2021-03-17 15:45:47.837 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Checksum matched
2021-03-17 15:45:47.837 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 0: Message payload = 4C 00 00 02 00 D4 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2021-03-17 15:45:47.838 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Message is valid, sending ACK
2021-03-17 15:45:47.838 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2021-03-17 15:45:47.838 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=76, payload=4C 00 00 02 00 D4 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2021-03-17 15:45:47.839 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=76, payload=4C 00 00 02 00 D4 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2021-03-17 15:45:47.839 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 120: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 76
2021-03-17 15:45:47.839 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2021-03-17 15:45:47.840 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 120: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 76
2021-03-17 15:45:47.840 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 120: (Callback 76)
2021-03-17 15:45:47.840 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2021-03-17 15:45:47.841 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 120: callback 76
2021-03-17 15:45:47.841 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=76, payload=4C 00 00 02 00 D4 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2021-03-17 15:45:47.841 [TRACE] [ve.internal.protocol.ZWaveController] - Incoming Message type = REQUEST
2021-03-17 15:45:47.842 [TRACE] [l.serialmessage.SendDataMessageClass] - Handle Message Send Data Request
2021-03-17 15:45:47.842 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: SendData Request. CallBack ID = 76, Status = Transmission complete and ACK received(0)
2021-03-17 15:45:47.842 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: resetResendCount initComplete=true isDead=false
2021-03-17 15:45:47.843 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 120: TransactionAdvance ST: WAIT_REQUEST
2021-03-17 15:45:47.843 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 120: TransactionAdvance WT: ApplicationCommandHandler {}
2021-03-17 15:45:47.843 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 120: TransactionAdvance RX: Message: class=SendData[19], type=Request[0], dest=0, callback=76, payload=4C 00 00 02 00 D4 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2021-03-17 15:45:47.844 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 120: TransactionAdvance RQ: RREQ=true, RCLS=ApplicationCommandHandler
2021-03-17 15:45:47.844 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 120: TransactionAdvance TO: WAIT_DATA
2021-03-17 15:45:47.844 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 120: Advanced to WAIT_DATA
2021-03-17 15:45:47.844 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: TID 120: Transaction not completed
2021-03-17 15:45:47.845 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-03-17 15:45:47.845 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-03-17 15:45:47.845 [TRACE] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage nothing
2021-03-17 15:45:47.845 [TRACE] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2021-03-17 15:45:47.846 [TRACE] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Wed Mar 17 15:45:52 PDT 2021 - 4998ms
2021-03-17 15:45:47.849 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Received SOF
2021-03-17 15:45:47.850 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0D 00 04 00 02 05 26 03 56 56 00 D4 00 00
2021-03-17 15:45:47.850 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Creating new SerialMessage from buffer = 01 0D 00 04 00 02 05 26 03 56 56 00 D4 00 00
2021-03-17 15:45:47.850 [TRACE] [wave.internal.protocol.SerialMessage] - Calculated checksum = 0
2021-03-17 15:45:47.851 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Checksum matched
2021-03-17 15:45:47.851 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 2: Message payload = 00 02 05 26 03 56 56 00 D4 00
2021-03-17 15:45:47.851 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Message is valid, sending ACK
2021-03-17 15:45:47.852 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2021-03-17 15:45:47.852 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 05 26 03 56 56 00 D4 00
2021-03-17 15:45:47.852 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 05 26 03 56 56 00 D4 00
2021-03-17 15:45:47.853 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2021-03-17 15:45:47.853 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Application Command Request (ALIVE:DONE)
2021-03-17 15:45:47.853 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: resetResendCount initComplete=true isDead=false
2021-03-17 15:45:47.854 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 0
2021-03-17 15:45:47.854 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY not supported
2021-03-17 15:45:47.854 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
2021-03-17 15:45:47.854 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 2: Switch Multi Level report, value = 86
2021-03-17 15:45:47.855 [TRACE] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2021-03-17 15:45:47.855 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2021-03-17 15:45:47.855 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SWITCH_MULTILEVEL, value=86
2021-03-17 15:45:47.856 [TRACE] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Checking channel=zwave:device:949245ad36:node2:switch_dimmer, cmdClass=COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint=0
2021-03-17 15:45:47.856 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Updating channel state zwave:device:949245ad36:node2:switch_dimmer to 86 [PercentType]
2021-03-17 15:45:47.857 [TRACE] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Checking channel=zwave:device:949245ad36:node2:switch_dimmer, cmdClass=COMMAND_CLASS_BASIC, endpoint=0
2021-03-17 15:45:47.857 [TRACE] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Checking channel=zwave:device:949245ad36:node2:scene_number, cmdClass=COMMAND_CLASS_SCENE_ACTIVATION, endpoint=0
2021-03-17 15:45:47.858 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Commands processed 1.
2021-03-17 15:45:47.858 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@6c5cd871.
2021-03-17 15:45:47.858 [TRACE] [nal.protocol.ZWaveTransactionManager] - NODE 2: Checking transaction 120 ApplicationCommandHandler.
2021-03-17 15:45:47.859 [TRACE] [nal.protocol.ZWaveTransactionManager] - NODE 2: Checking transaction : state >> WAIT_DATA
2021-03-17 15:45:47.859 [TRACE] [nal.protocol.ZWaveTransactionManager] - NODE 2: Checking transaction : node >> 2
2021-03-17 15:45:47.859 [TRACE] [nal.protocol.ZWaveTransactionManager] - NODE 2: Checking transaction : class >> 38 == 38.
2021-03-17 15:45:47.860 [TRACE] [nal.protocol.ZWaveTransactionManager] - NODE 2: Checking transaction : commd >> 3 == 3.
2021-03-17 15:45:47.860 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@6c5cd871.
2021-03-17 15:45:47.860 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 120: TransactionAdvance ST: WAIT_DATA
2021-03-17 15:45:47.861 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 120: TransactionAdvance WT: ApplicationCommandHandler {}
2021-03-17 15:45:47.862 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 120: TransactionAdvance RX: Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 05 26 03 56 56 00 D4 00
2021-03-17 15:45:47.862 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 120: TransactionAdvance TO: DONE
2021-03-17 15:45:47.862 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: notifyTransactionResponse TID:120 DONE
2021-03-17 15:45:47.863 [TRACE] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2021-03-17 15:45:47.864 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-03-17 15:45:47.864 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2021-03-17 15:45:47.864 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-03-17 15:45:47.865 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-03-17 15:45:47.865 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-03-17 15:45:47.865 [TRACE] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage nothing
2021-03-17 15:45:47.865 [TRACE] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2021-03-17 15:45:49.635 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Received SOF
2021-03-17 15:45:49.637 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0A 00 04 00 02 02 82 01 D2 00 A0
2021-03-17 15:45:49.638 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Creating new SerialMessage from buffer = 01 0A 00 04 00 02 02 82 01 D2 00 A0
2021-03-17 15:45:49.639 [TRACE] [wave.internal.protocol.SerialMessage] - Calculated checksum = -96
2021-03-17 15:45:49.639 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Checksum matched
2021-03-17 15:45:49.639 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 2: Message payload = 00 02 02 82 01 D2 00
2021-03-17 15:45:49.640 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Message is valid, sending ACK
2021-03-17 15:45:49.640 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2021-03-17 15:45:49.641 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 02 82 01 D2 00
2021-03-17 15:45:49.642 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 02 82 01 D2 00
2021-03-17 15:45:49.642 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2021-03-17 15:45:49.643 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Application Command Request (ALIVE:DONE)
2021-03-17 15:45:49.643 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: resetResendCount initComplete=true isDead=false
2021-03-17 15:45:49.644 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Incoming command class COMMAND_CLASS_HAIL, endpoint 0
2021-03-17 15:45:49.644 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY not supported
2021-03-17 15:45:49.645 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Received COMMAND_CLASS_HAIL V0 HAIL
2021-03-17 15:45:49.646 [TRACE] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveDelayedPollEvent
2021-03-17 15:45:49.649 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveDelayedPollEvent
2021-03-17 15:45:49.650 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling initialised at 1800 seconds - start in 75 milliseconds.
2021-03-17 15:45:49.651 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Commands processed 1.
2021-03-17 15:45:49.651 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@7ae05a45.
2021-03-17 15:45:49.652 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-03-17 15:45:49.653 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-03-17 15:45:49.653 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-03-17 15:45:49.654 [TRACE] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage nothing
2021-03-17 15:45:49.725 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling...
2021-03-17 15:45:49.726 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling zwave:device:949245ad36:node2:switch_dimmer
2021-03-17 15:45:49.726 [DEBUG] [erter.ZWaveMultiLevelSwitchConverter] - NODE 2: Generating poll message for COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 0
2021-03-17 15:45:49.727 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 2: Creating new message for command SWITCH_MULTILEVEL_GET
2021-03-17 15:45:49.727 [TRACE] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Encapsulating message, endpoint 0
2021-03-17 15:45:49.728 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY not supported
2021-03-17 15:45:49.728 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Command Class COMMAND_CLASS_SWITCH_MULTILEVEL is NOT required to be secured
2021-03-17 15:45:49.729 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling skipped for zwave:device:949245ad36:node2:switch_dimmer on COMMAND_CLASS_BASIC
2021-03-17 15:45:49.729 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Adding to device queue
2021-03-17 15:45:49.730 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Added 121 to queue - size 1
2021-03-17 15:45:49.730 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-03-17 15:45:49.731 [TRACE] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: listening == true, frequentlyListening == false, awake == false
2021-03-17 15:45:49.731 [TRACE] [nal.protocol.ZWaveTransactionManager] - Transaction from sendQueue
2021-03-17 15:45:49.731 [TRACE] [nal.protocol.ZWaveTransactionManager] - getTransactionToSend 6
2021-03-17 15:45:49.732 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 2: Creating empty message of class = SendData (0x13), type = Request
2021-03-17 15:45:49.732 [TRACE] [wave.internal.protocol.SerialMessage] - Calculated checksum = -87
2021-03-17 15:45:49.733 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 02 02 26 02 25 4D A9
2021-03-17 15:45:49.734 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 2: Sending REQUEST Message = 01 09 00 13 02 02 26 02 25 4D A9
2021-03-17 15:45:49.734 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2021-03-17 15:45:49.735 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 121: Transaction Start type SendData
2021-03-17 15:45:49.736 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 121: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 77
2021-03-17 15:45:49.736 [TRACE] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: expected cmd class: COMMAND_CLASS_SWITCH_MULTILEVEL
2021-03-17 15:45:49.737 [TRACE] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: expected cmd: 3
2021-03-17 15:45:49.738 [TRACE] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage Transactions outstanding: 1
2021-03-17 15:45:49.738 [TRACE] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Wed Mar 17 15:45:51 PDT 2021 - 2000ms
2021-03-17 15:45:49.739 [TRACE] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage lastTransaction: TID 121: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 77
2021-03-17 15:45:49.739 [TRACE] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2021-03-17 15:45:49.740 [TRACE] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Wed Mar 17 15:45:51 PDT 2021 - 1998ms
2021-03-17 15:45:49.741 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2021-03-17 15:45:49.742 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Creating new SerialMessage from buffer = 06
2021-03-17 15:45:49.742 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-03-17 15:45:49.743 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-03-17 15:45:49.743 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Received SOF
2021-03-17 15:45:49.744 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 121: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 77
2021-03-17 15:45:49.744 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2021-03-17 15:45:49.744 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2021-03-17 15:45:49.745 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-03-17 15:45:49.745 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Creating new SerialMessage from buffer = 01 04 01 13 01 E8
2021-03-17 15:45:49.745 [TRACE] [wave.internal.protocol.SerialMessage] - Calculated checksum = -24
2021-03-17 15:45:49.746 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Checksum matched
2021-03-17 15:45:49.745 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-03-17 15:45:49.747 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Message payload = 01
2021-03-17 15:45:49.747 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Message is valid, sending ACK
2021-03-17 15:45:49.747 [TRACE] [nal.protocol.ZWaveTransactionManager] - Transaction lastTransaction outstanding...
2021-03-17 15:45:49.748 [TRACE] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2021-03-17 15:45:49.748 [TRACE] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Wed Mar 17 15:45:51 PDT 2021 - 1990ms
2021-03-17 15:45:49.748 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2021-03-17 15:45:49.749 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-03-17 15:45:49.750 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-03-17 15:45:49.751 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 121: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 77
2021-03-17 15:45:49.752 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2021-03-17 15:45:49.753 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 121: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 77
2021-03-17 15:45:49.754 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-03-17 15:45:49.755 [TRACE] [ve.internal.protocol.ZWaveController] - Incoming Message type = RESPONSE
2021-03-17 15:45:49.756 [TRACE] [l.serialmessage.SendDataMessageClass] - Handle Message Send Data Response
2021-03-17 15:45:49.757 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: sentData successfully placed on stack.
2021-03-17 15:45:49.758 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 121: TransactionAdvance ST: WAIT_RESPONSE
2021-03-17 15:45:49.759 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 121: TransactionAdvance WT: ApplicationCommandHandler {}
2021-03-17 15:45:49.760 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 121: TransactionAdvance RX: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-03-17 15:45:49.761 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Received SOF
2021-03-17 15:45:49.761 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 121: TransactionAdvance TO: WAIT_REQUEST
2021-03-17 15:45:49.763 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 121: Advanced to WAIT_REQUEST
2021-03-17 15:45:49.764 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 13 4D 00 00 02 00 D2 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 68
2021-03-17 15:45:49.764 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: TID 121: Transaction not completed
2021-03-17 15:45:49.765 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Creating new SerialMessage from buffer = 01 18 00 13 4D 00 00 02 00 D2 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 68
2021-03-17 15:45:49.765 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-03-17 15:45:49.765 [TRACE] [wave.internal.protocol.SerialMessage] - Calculated checksum = 104
2021-03-17 15:45:49.766 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Checksum matched
2021-03-17 15:45:49.766 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-03-17 15:45:49.766 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 0: Message payload = 4D 00 00 02 00 D2 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2021-03-17 15:45:49.767 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Message is valid, sending ACK
2021-03-17 15:45:49.767 [TRACE] [nal.protocol.ZWaveTransactionManager] - Transaction lastTransaction outstanding...
2021-03-17 15:45:49.767 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2021-03-17 15:45:49.767 [TRACE] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2021-03-17 15:45:49.768 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=77, payload=4D 00 00 02 00 D2 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2021-03-17 15:45:49.768 [TRACE] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Wed Mar 17 15:45:54 PDT 2021 - 4996ms
2021-03-17 15:45:49.770 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=77, payload=4D 00 00 02 00 D2 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2021-03-17 15:45:49.770 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 121: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 77
2021-03-17 15:45:49.771 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2021-03-17 15:45:49.772 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 121: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 77
2021-03-17 15:45:49.773 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 121: (Callback 77)
2021-03-17 15:45:49.774 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2021-03-17 15:45:49.775 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 121: callback 77
2021-03-17 15:45:49.775 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Received SOF
2021-03-17 15:45:49.776 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=77, payload=4D 00 00 02 00 D2 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2021-03-17 15:45:49.776 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0D 00 04 00 02 05 26 03 63 63 00 D2 00 06
2021-03-17 15:45:49.777 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Creating new SerialMessage from buffer = 01 0D 00 04 00 02 05 26 03 63 63 00 D2 00 06
2021-03-17 15:45:49.777 [TRACE] [ve.internal.protocol.ZWaveController] - Incoming Message type = REQUEST
2021-03-17 15:45:49.777 [TRACE] [wave.internal.protocol.SerialMessage] - Calculated checksum = 6
2021-03-17 15:45:49.778 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Checksum matched
2021-03-17 15:45:49.779 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 2: Message payload = 00 02 05 26 03 63 63 00 D2 00
2021-03-17 15:45:49.779 [TRACE] [l.serialmessage.SendDataMessageClass] - Handle Message Send Data Request
2021-03-17 15:45:49.779 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Message is valid, sending ACK
2021-03-17 15:45:49.780 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2021-03-17 15:45:49.780 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: SendData Request. CallBack ID = 77, Status = Transmission complete and ACK received(0)
2021-03-17 15:45:49.781 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 05 26 03 63 63 00 D2 00
2021-03-17 15:45:49.781 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: resetResendCount initComplete=true isDead=false
2021-03-17 15:45:49.782 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 121: TransactionAdvance ST: WAIT_REQUEST
2021-03-17 15:45:49.783 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 121: TransactionAdvance WT: ApplicationCommandHandler {}
2021-03-17 15:45:49.784 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 121: TransactionAdvance RX: Message: class=SendData[19], type=Request[0], dest=0, callback=77, payload=4D 00 00 02 00 D2 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2021-03-17 15:45:49.785 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 121: TransactionAdvance RQ: RREQ=true, RCLS=ApplicationCommandHandler
2021-03-17 15:45:49.786 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 121: TransactionAdvance TO: WAIT_DATA
2021-03-17 15:45:49.786 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 121: Advanced to WAIT_DATA
2021-03-17 15:45:49.787 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: TID 121: Transaction not completed
2021-03-17 15:45:49.788 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 05 26 03 63 63 00 D2 00
2021-03-17 15:45:49.789 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2021-03-17 15:45:49.790 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Application Command Request (ALIVE:DONE)
2021-03-17 15:45:49.791 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: resetResendCount initComplete=true isDead=false
2021-03-17 15:45:49.792 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 0
2021-03-17 15:45:49.793 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY not supported
2021-03-17 15:45:49.793 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
2021-03-17 15:45:49.796 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 2: Switch Multi Level report, value = 99
2021-03-17 15:45:49.796 [TRACE] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2021-03-17 15:45:49.797 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2021-03-17 15:45:49.798 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SWITCH_MULTILEVEL, value=99
2021-03-17 15:45:49.798 [TRACE] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Checking channel=zwave:device:949245ad36:node2:switch_dimmer, cmdClass=COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint=0
2021-03-17 15:45:49.799 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Updating channel state zwave:device:949245ad36:node2:switch_dimmer to 100 [PercentType]
2021-03-17 15:45:49.800 [TRACE] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Checking channel=zwave:device:949245ad36:node2:switch_dimmer, cmdClass=COMMAND_CLASS_BASIC, endpoint=0
2021-03-17 15:45:49.800 [TRACE] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Checking channel=zwave:device:949245ad36:node2:scene_number, cmdClass=COMMAND_CLASS_SCENE_ACTIVATION, endpoint=0
2021-03-17 15:45:49.801 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Commands processed 1.
2021-03-17 15:45:49.801 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@34f3bc8d.
2021-03-17 15:45:49.802 [TRACE] [nal.protocol.ZWaveTransactionManager] - NODE 2: Checking transaction 121 ApplicationCommandHandler.
2021-03-17 15:45:49.803 [TRACE] [nal.protocol.ZWaveTransactionManager] - NODE 2: Checking transaction : state >> WAIT_DATA
2021-03-17 15:45:49.803 [TRACE] [nal.protocol.ZWaveTransactionManager] - NODE 2: Checking transaction : node >> 2
2021-03-17 15:45:49.804 [TRACE] [nal.protocol.ZWaveTransactionManager] - NODE 2: Checking transaction : class >> 38 == 38.
2021-03-17 15:45:49.804 [TRACE] [nal.protocol.ZWaveTransactionManager] - NODE 2: Checking transaction : commd >> 3 == 3.
2021-03-17 15:45:49.805 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@34f3bc8d.
2021-03-17 15:45:49.805 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 121: TransactionAdvance ST: WAIT_DATA
2021-03-17 15:45:49.806 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 121: TransactionAdvance WT: ApplicationCommandHandler {}
2021-03-17 15:45:49.806 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 121: TransactionAdvance RX: Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 05 26 03 63 63 00 D2 00
2021-03-17 15:45:49.807 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 121: TransactionAdvance TO: DONE
2021-03-17 15:45:49.807 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: notifyTransactionResponse TID:121 DONE
2021-03-17 15:45:49.808 [TRACE] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2021-03-17 15:45:49.809 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-03-17 15:45:49.809 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2021-03-17 15:45:49.810 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-03-17 15:45:49.810 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-03-17 15:45:49.810 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-03-17 15:45:49.811 [TRACE] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage nothing
2021-03-17 15:45:49.811 [TRACE] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
So maybe the issue is not with the HAIL command, but with the event listener / command handler…?
