Hi All,
I’m working on OH 2.4 runnung on a Synology.
The installation is woking fine with KNX and other bindings.
The Z-Wave Binding is installed:
207 │ Active │ 80 │ 2.4.0 │ ZWave Binding
openhab-binding-zwave │ 2.4.0 │ x │ Started │ openhab-addons-2.4.0 │ Z-Wave Binding
I have a Nortek HUSBZB-1 as Z-Wawe controller
looking at device ‘/devices/pci0000:00/0000:00:15.0/usb1/1-3/1-3:1.0/ttyUSB0/tty/ttyUSB0’:
KERNEL==“ttyUSB0”
SUBSYSTEM==“tty”
DRIVER==""
looking at parent device ‘/devices/pci0000:00/0000:00:15.0/usb1/1-3/1-3:1.0/ttyUSB0’:
KERNELS==“ttyUSB0”
SUBSYSTEMS==“usb-serial”
DRIVERS==“cp210x”
ATTRS{port_number}==“0”
looking at parent device ‘/devices/pci0000:00/0000:00:15.0/usb1/1-3/1-3:1.0’:
KERNELS==“1-3:1.0”
SUBSYSTEMS==“usb”
DRIVERS==“cp210x”
ATTRS{bInterfaceClass}==“ff”
ATTRS{bInterfaceSubClass}==“00”
ATTRS{bInterfaceProtocol}==“00”
ATTRS{bNumEndpoints}==“02”
ATTRS{authorized}==“1”
ATTRS{supports_autosuspend}==“1”
ATTRS{bAlternateSetting}==" 0"
ATTRS{bInterfaceNumber}==“00”
ATTRS{interface}==“HubZ Z-Wave Com Port”
The controller is online and after activating debug on z-wawe there are NO errors.
The controller ha the following parameters:
controller is master: YES
SIS Node:1
Inclusion mode timeout:30
default wakeup period:every hour
Inclusion Mode:High power (tried also the other two)
secure inclusion:do not use security (tried also the other two oprions)
network security key:xxxxxxxxx
I’m using Habmin to discover the PST02 (configuration->object->z-wave binding) that I previously reset (4 quick click, wait led off, click) tried in different order, discovery mode -> reset, reset -> discovery mode.
I tried also the discovery mode (3 quick cliks) but nothing happens.
Tried to remove and reinstall batteries, same result.
This is the OH log during dicovery process:
16:45:41.781 [INFO ] [smarthome.event.BindingEvent ] - org.openhab.binding.zwave.event.BindingEvent@25173ab1
16:46:11.775 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_fb9aa05e_serial_ack changed from 48 to 49
16:46:11.826 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_fb9aa05e_serial_sof changed from 37 to 38
16:46:11.832 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_fb9aa05e_serial_ack changed from 49 to 50
I see a BindingEvents and some frame received, but nothing is added.
Any Ideas?
