I use Raspi3B, openHABian v1.4, openHAB 2.3.0 Build #1243
openHAB is working.
Now I try to integrate Z-Wave first time and install a new Razberry2-Modul and use this instructions
but the Z-Wave Serial Controller stays OFFLINE.
I take new set up withe only Z-Wave-Binding.
Raspy has been restarted.
The 2 LEDs at modul only flashes once after powerON. http://find.zwave.me, http://192.168.___.___:8083 and …/expert works
Can I check if the Razberry is defect?
As long a you’e running z-way-server - that is z-wave.me own implementation of home automation, you cannot use the razberry with the z-wave binding. The razberry will be in use and the z-wave binding cannot access it.
You’ll have to stop z-way-server with a sudo systemctl stop z-way-server. To disable it for good, you’ll have to sudo systemctl disable z-way-server.
If you want to run z-way-server alongside openHAB you have to try the Z-Way (z-way <> z-wave!) binding. That’s a bridge between z-way-server and openHAB.
Instantiate the app once (under Configuration - Apps - Local Apps). Important: Change the selection from “Featured Apps” to “All Apps” to make the app visible. It is not necessary to make the configuration manually.
