because the Z-Wave security topic is so long i made a seperate one, maybe this one can be closed quickly.
I am testing the Z-Wave binding from here:
The first test with a AEON Labs ZW100 MultiSensor 6 (because they are not installed fix and are simple to trigger, i know there is no real need to use security for this devices), worked without any problems. I switched them back to normal inclusion and went on to the Devolo MT02648 Door/Window Contact. Inclusion seems to work and Habmin is showing that everything is okay:
But the device never triggers, the log shows repeatedly (every minute or so (i tried to wake up the device via the little push button)):
09-Sep-2017 11:37:44.911 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start
09-Sep-2017 11:37:44.912 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 46: listening == false, frequentlyListening == false, awake == false
09-Sep-2017 11:37:44.913 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 46: Node not awake!
09-Sep-2017 11:37:44.913 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 49: listening == false, frequentlyListening == false, awake == false
09-Sep-2017 11:37:44.915 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 49: Node not awake!
09-Sep-2017 11:37:44.918 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 49: listening == false, frequentlyListening == false, awake == false
09-Sep-2017 11:37:44.919 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 49: Node not awake!
09-Sep-2017 11:37:44.920 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 49: listening == false, frequentlyListening == false, awake == false
09-Sep-2017 11:37:44.920 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 49: Node not awake!
09-Sep-2017 11:37:44.921 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction from controllerQueue
If i trigger the sensor (open and close the door) also something like this comes in:
09-Sep-2017 11:41:32.226 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - lastTransaction null
09-Sep-2017 11:41:32.227 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
09-Sep-2017 11:41:32.228 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
09-Sep-2017 11:41:32.228 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_SECURITY, endpoint 0
09-Sep-2017 11:41:32.229 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY check internal
09-Sep-2017 11:41:32.230 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_SECURITY V1 SECURITY_NONCE_GET
09-Sep-2017 11:41:32.230 [DEBUG] [.protocol.commandclass.impl.CommandClassSecurityV1] - Creating command message SECURITY_NONCE_REPORT version 1
09-Sep-2017 11:41:32.231 [DEBUG] [saction.ZWaveCommandClassTransactionPayloadBuilder] - At build null
09-Sep-2017 11:41:32.232 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 49: Added to secure queue - size 1
09-Sep-2017 11:41:32.232 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
09-Sep-2017 11:41:32.234 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1808de4.
09-Sep-2017 11:41:32.235 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
09-Sep-2017 11:41:32.236 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
09-Sep-2017 11:41:32.343 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - lastTransaction null
09-Sep-2017 11:41:32.344 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
09-Sep-2017 11:41:32.344 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
09-Sep-2017 11:41:32.345 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 49: Decapsulating COMMAND_CLASS_SECURITY
09-Sep-2017 11:41:32.347 [DEBUG] [al.protocol.commandclass.ZWaveSecurityCommandClass] - NODE 49: SECURITY_RXD 8F 01 04 03 80 03 64 04 30 03 FF 0A 05 31 05 03 01 06 06 31 05 01 0A 00 46
09-Sep-2017 11:41:32.347 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_MULTI_CMD, endpoint 0
09-Sep-2017 11:41:32.348 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_MULTI_CMD V1 unknown command 1
09-Sep-2017 11:41:32.348 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
09-Sep-2017 11:41:32.349 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@587193.
09-Sep-2017 11:41:32.349 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
09-Sep-2017 11:41:36.134 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - lastTransaction null
09-Sep-2017 11:41:36.135 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
09-Sep-2017 11:41:36.138 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
09-Sep-2017 11:41:36.139 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_SECURITY, endpoint 0
09-Sep-2017 11:41:36.140 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY check internal
09-Sep-2017 11:41:36.141 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_SECURITY V1 SECURITY_NONCE_GET
09-Sep-2017 11:41:36.142 [DEBUG] [.protocol.commandclass.impl.CommandClassSecurityV1] - Creating command message SECURITY_NONCE_REPORT version 1
09-Sep-2017 11:41:36.143 [DEBUG] [saction.ZWaveCommandClassTransactionPayloadBuilder] - At build null
09-Sep-2017 11:41:36.144 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 49: Added to secure queue - size 1
09-Sep-2017 11:41:36.145 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
09-Sep-2017 11:41:36.145 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1e9cfa0.
09-Sep-2017 11:41:36.146 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
09-Sep-2017 17:19:58.924 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - lastTransaction null
09-Sep-2017 17:19:58.924 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
09-Sep-2017 17:19:58.925 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
09-Sep-2017 17:19:58.926 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_SECURITY, endpoint 0
09-Sep-2017 17:19:58.926 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY check internal
09-Sep-2017 17:19:58.926 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_SECURITY V1 SECURITY_NONCE_GET
09-Sep-2017 17:19:58.927 [DEBUG] [.protocol.commandclass.impl.CommandClassSecurityV1] - Creating command message SECURITY_NONCE_REPORT version 1
09-Sep-2017 17:19:58.927 [DEBUG] [saction.ZWaveCommandClassTransactionPayloadBuilder] - At build null
09-Sep-2017 17:19:58.928 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 49: Added to secure queue - size 1
09-Sep-2017 17:19:58.928 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
09-Sep-2017 17:19:58.929 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@44de12.
09-Sep-2017 17:19:58.929 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
The manual says:
So the question is: does anyone have experience with this? Do i have to change something in the configuration parameters (some bits maybe in the costumer functions to get the sensor binary report Type: 0x0C, Value: 0x00 whatever this means ???)
If there is not enough information i could attach more from the logs, if this is simply just not meant to work at the moment it is also okay ![]()
Matthias
