Hi there,
My Fibaro smoke sensor (node 10 in the picture below) doesn’t connect properly to the Z-Wave network.
I’m running openHAB 2.4 on raspberry 3b with aeontec z-wave controller
From habmin Z-Wave network viewer:
It’s quite strange since it used to work in the past.
Accordding to paper UI the device is online and channels are linked:
But it doesn’t show up in the sitemap nor in the logfile:
Here’s the code:
// THINGS
Bridge zwave:serial_zstick:controller "Z-Wave Controller" @ "Z-Wave" [ port="/dev/ttyACM0", controller_softreset="false", controller_master="true", heal_enable="true", heal_time=2, security_networkkey="xxxxxxxxxx" ]
Thing zwave:fibaro_fgsd002_00_000:controller:node10 "Z-Wave: Rauchmelder FGSS001 - Node10" (zwave:serial_zstick:controller) @ "Z-Wave" [ node_id=10 ] // Smoke sensor Fibaro (FGSD002)
// ITEMS
Number TBP_rauch1_temp "Rauchmelder1 - Temperatur Sensor" <fire> (gM,Gzwave,Gstatus,Gsensor,Grauch,Gad) {channel="zwave:fibaro_fgsd002_00_000:controller:node10:sensor_temperature"}
Switch TBP_rauch1_alrsmoke "Rauchmelder1 - Rauch Alarm" <fire> (gM,Gzwave,Gstatus,Gsensor,Grauch,Gad) {channel="zwave:fibaro_fgsd002_00_000:controller:node10:alarm_smoke"}
Switch TBP_rauch1_alrtamper "Rauchmelder1 - Tamper Alarm" <fire> (gM,Gzwave,Gstatus,Gsensor,Grauch,Gad) {channel="zwave:fibaro_fgsd002_00_000:controller:node10:alarm_tamper"}
Switch TBP_rauch1_alrbatt "Rauchmelder1 - Batteriestand Alarm" <fire> (gM,Gzwave,Gstatus,Gsensor,Grauch,Gad) {channel="zwave:fibaro_fgsd002_00_000:controller:node10:alarm_battery"}
Switch TBP_rauch1_alrsys "Rauchmelder1 - Hardware Fehler" <fire> (gM,Gzwave,Gstatus,Gsensor,Grauch,Gad) {channel="zwave:fibaro_fgsd002_00_000:controller:node10:alarm_system"}
Switch TBP_rauch1_alrheat "Rauchmelder1 - Hitze Alarm" <fire> (gM,Gzwave,Gstatus,Gsensor,Grauch,Gad) {channel="zwave:fibaro_fgsd002_00_000:controller:node10:alarm_heat"}
Number TBP_rauch1_batt "Rauchmelder1 - Batterieladung" <fire> (gM,Gzwave,Gstatus,Gsensor,Grauch,Gad) {channel="zwave:fibaro_fgsd002_00_000:controller:node10:battery-level"}
Number TBP_rauch1_timeoffset "Rauchmelder1 - Zeit Offset" <fire> (gM,Gzwave,Gstatus,Gsensor,Grauch,Gad) {channel="zwave:fibaro_fgsd002_00_000:controller:node10:time_offset"}
