Z-Wave Stick Migration (via Z-Wave "Controller Shift" feature)
(For reference purposes, the manual procedure towards the end of this thread has been updated per Scott’s help)
To manually migrate from my older controller (AEON S2) to the newer one (AEON Gen5 Zstick);
  1. Take screenshots or in some other way (e.g., copy JSON files) capture all of the configuration information for the current set of things
  2. Take the (old or new) controller around and exclude all of the devices
  3. For each thing in Habmin> Configuration> Things, select the respective zwave Thing and press the Delete button
  4. Plug the Gen5 Zstick in, add it in PaperUI, and ensure it is set to the desired TTY port Z-Wave Serial Adapter setup - #2 by rlkoshak
  5. Use Habmin or PaperUI to discover all of the devices
  6. Restore the configuration information captured in step 1
  7. Reconfig each thing per the information captured in step 1.
