Z-Wave Sub-parameter testing
haha :wink: I keep it covered / muffled with my hand … its ok then :wink: (dont tell the intruder)
  • in all tries I always updated both values
(offtopic: did you update the DCH Z110 Dlink Sensor aswell? its not waking up from offline in habmin… however it reports values)
here we go:
21:34:15.807 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Configuration update received
21:34:15.820 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Configuration update config_37_2_0000000F to 3
21:34:15.824 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Set sub-parameter 37 from 3 / 0000000F
21:34:15.850 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Parameter 37 set value 00000003 mask 0000000F
21:34:15.852 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 2: Creating new message for application command CONFIGURATIONCMD_GET
21:34:15.854 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
21:34:15.855 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 02 03 70 05 25 25 2C BE
21:34:15.855 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 2: Sending REQUEST Message = 01 0A 00 13 02 03 70 05 25 25 2C BE
21:34:15.856 [DEBUG] [ve.internal.protocol.ZWaveController] - Enqueueing message. Queue length = 0
21:34:15.863 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Configuration update config_37_2_00000F00 to 1
21:34:15.865 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
21:34:15.870 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
21:34:15.871 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
21:34:15.872 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
21:34:15.873 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = SendData (0x13), type = Response (0x01), payload = 01
21:34:15.873 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: Sent Data successfully placed on stack.
21:34:15.874 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Set sub-parameter 37 from 1 / 00000F00
21:34:15.875 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Parameter 37 set value 00000001 mask 00000F00
21:34:15.882 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 2C 00 00 02 C5
21:34:15.883 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
21:34:15.884 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 2C 00 00 02 00 00 CB
21:34:15.885 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 2C 00 00 02 00 00 CB
21:34:15.886 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = SendData (0x13), type = Request (0x00), payload = 2C 00 00 02
21:34:15.888 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: SendData Request. CallBack ID = 44, Status = Transmission complete and ACK received(0)
21:34:15.890 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 02 03 70 05 25
21:34:15.892 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 2C 00 00 02
21:34:15.893 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, expected=ApplicationCommandHandler, cancelled=false
21:34:15.909 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0E 00 04 00 02 08 70 06 25 02 01 03 00 00 AC
21:34:15.912 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
21:34:15.913 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0E 00 04 00 02 08 70 06 25 02 01 03 00 00 AC
21:34:15.915 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0E 00 04 00 02 08 70 06 25 02 01 03 00 00 AC
21:34:15.917 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 02 08 70 06 25 02 01 03 00 00
21:34:15.919 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 2: Application Command Request (ALIVE:DONE)
21:34:15.920 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 2: Incoming command class CONFIGURATION
21:34:15.929 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 2: Received Configuration Request
21:34:15.930 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 2: Node configuration report, parameter = 37, value = 259, size = 2
21:34:15.940 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveConfigurationParameterEvent
21:34:15.940 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveConfigurationParameterEvent
21:34:15.941 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got a value event from Z-Wave network, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ZWaveConfigurationParameter@111c746
21:34:15.942 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Update CONFIGURATION 37/2 to 259
21:34:15.942 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Updating sub-parameter 37 to 259
21:34:15.943 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Setting parameter 37 to 259
21:34:15.944 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 2: Creating new message for application command CONFIGURATIONCMD_SET
21:34:15.944 [DEBUG] [ve.internal.protocol.ZWaveController] - Enqueueing message. Queue length = 1
21:34:15.950 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 2: Creating new message for application command CONFIGURATIONCMD_GET
21:34:15.951 [DEBUG] [ve.internal.protocol.ZWaveController] - Enqueueing message. Queue length = 2
21:34:15.952 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 02 03 70 05 25
21:34:15.953 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 02 08 70 06 25 02 01 03 00 00
21:34:15.958 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, expected=ApplicationCommandHandler, cancelled=false
21:34:15.959 [DEBUG] [.serialmessage.ZWaveCommandProcessor] -          transaction complete!
21:34:15.961 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
21:34:15.979 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
21:34:15.989 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 2: Response processed after 133ms/3147ms.
21:34:15.990 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 1
21:34:15.991 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0D 00 13 02 06 70 04 25 02 01 03 25 2D BC
21:34:15.992 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 2: Sending REQUEST Message = 01 0D 00 13 02 06 70 04 25 02 01 03 25 2D BC
21:34:16.003 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
21:34:16.004 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
21:34:16.005 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
21:34:16.006 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
21:34:16.011 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = SendData (0x13), type = Response (0x01), payload = 01
21:34:16.011 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: Sent Data successfully placed on stack.
21:34:16.021 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 2D 00 00 02 C4
21:34:16.022 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
21:34:16.023 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 2D 00 00 02 00 00 CA
21:34:16.024 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 2D 00 00 02 00 00 CA
21:34:16.025 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = SendData (0x13), type = Request (0x00), payload = 2D 00 00 02
21:34:16.025 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: SendData Request. CallBack ID = 45, Status = Transmission complete and ACK received(0)
21:34:16.027 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 02 06 70 04 25 02 01 03
21:34:16.027 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 2D 00 00 02
21:34:16.028 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, expected=SendData, cancelled=false
21:34:16.028 [DEBUG] [.serialmessage.ZWaveCommandProcessor] -          transaction complete!
21:34:16.029 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
21:34:16.029 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
21:34:16.030 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 2: Response processed after 36ms/3147ms.
21:34:16.030 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
21:34:16.031 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 02 03 70 05 25 25 2E BC
21:34:16.031 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 2: Sending REQUEST Message = 01 0A 00 13 02 03 70 05 25 25 2E BC
21:34:16.042 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
21:34:16.043 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
21:34:16.044 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
21:34:16.045 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
21:34:16.045 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = SendData (0x13), type = Response (0x01), payload = 01
21:34:16.046 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: Sent Data successfully placed on stack.
21:34:16.059 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 2E 00 00 02 C7
21:34:16.061 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
21:34:16.062 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 2E 00 00 02 00 00 C9
21:34:16.064 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 2E 00 00 02 00 00 C9
21:34:16.065 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = SendData (0x13), type = Request (0x00), payload = 2E 00 00 02
21:34:16.065 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: SendData Request. CallBack ID = 46, Status = Transmission complete and ACK received(0)
21:34:16.067 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 02 03 70 05 25
21:34:16.079 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 2E 00 00 02
21:34:16.080 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, expected=ApplicationCommandHandler, cancelled=false
21:34:16.133 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0E 00 04 00 02 08 70 06 25 02 01 03 00 00 AC
21:34:16.135 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
21:34:16.136 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0E 00 04 00 02 08 70 06 25 02 01 03 00 00 AC
21:34:16.137 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0E 00 04 00 02 08 70 06 25 02 01 03 00 00 AC
21:34:16.138 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 02 08 70 06 25 02 01 03 00 00
21:34:16.138 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 2: Application Command Request (ALIVE:DONE)
21:34:16.139 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 2: Incoming command class CONFIGURATION
21:34:16.139 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 2: Received Configuration Request
21:34:16.140 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 2: Node configuration report, parameter = 37, value = 259, size = 2
21:34:16.140 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveConfigurationParameterEvent
21:34:16.140 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveConfigurationParameterEvent
21:34:16.141 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got a value event from Z-Wave network, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ZWaveConfigurationParameter@111c746
21:34:16.141 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Update CONFIGURATION 37/2 to 259
21:34:16.142 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Config about to update 6 parameters...
21:34:16.142 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Processing config_37_2_0000000F
21:34:16.142 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Processing config_37_2_0000000F len=4
21:34:16.143 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Processing config_37_2_0000000F - id = '37'
21:34:16.143 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Processing config_37_2_0000000F - size = '2'
21:34:16.143 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Processing config_37_2_0000000F - bitmask = '0000000F'
21:34:16.143 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Processing config_37_2_0000000F - dec = '15'
21:34:16.144 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Sub-parameter config_37_2_0000000F is 00000003
21:34:16.144 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Pre-processing  00000003>>0000000F
21:34:16.145 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Post-processing 00000003>>0000000F
21:34:16.145 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Sub-parameter setting config_37_2_0000000F is 00000003 [3]
21:34:16.145 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Processing config_37_2_00000F00
21:34:16.146 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Processing config_37_2_00000F00 len=4
21:34:16.146 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Processing config_37_2_00000F00 - id = '37'
21:34:16.146 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Processing config_37_2_00000F00 - size = '2'
21:34:16.146 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Processing config_37_2_00000F00 - bitmask = '00000F00'
21:34:16.147 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Processing config_37_2_00000F00 - dec = '3840'
21:34:16.147 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Sub-parameter config_37_2_00000F00 is 00000100
21:34:16.147 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Pre-processing  00000100>>00000F00
21:34:16.148 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Post-processing 00000001>>00000F00
21:34:16.148 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Sub-parameter setting config_37_2_00000F00 is 00000001 [1]
21:34:16.148 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Processing config_252_1
21:34:16.149 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Processing config_252_1 len=3
21:34:16.149 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Processing config_252_1 - id = '252'
21:34:16.149 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Processing config_37_2
21:34:16.150 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Processing config_37_2 len=3
21:34:16.150 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Processing config_37_2 - id = '37'
21:34:16.150 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Processing config_37_2 - size = '2'
21:34:16.150 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Sub-parameter config_37_2 is 00000103
21:34:16.151 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Pre-processing  00000103>>FFFFFFFF
21:34:16.151 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Post-processing 00000103>>FFFFFFFF
21:34:16.152 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Sub-parameter setting config_37_2 is 00000103 [259]
21:34:16.152 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Processing config_80_1
21:34:16.152 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Processing config_80_1 len=3
21:34:16.152 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Processing config_80_1 - id = '80'
21:34:16.153 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Processing nodeid
21:34:16.550 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Config updated
21:34:16.551 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 02 03 70 05 25
21:34:16.552 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 02 08 70 06 25 02 01 03 00 00
21:34:16.552 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, expected=ApplicationCommandHandler, cancelled=false
21:34:16.553 [DEBUG] [.serialmessage.ZWaveCommandProcessor] -          transaction complete!
21:34:16.553 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
21:34:16.553 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
21:34:16.554 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 2: Response processed after 522ms/3147ms.
21:34:19.960 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 49 84 02 12 04 10 05 5E 25 70 85 59 72 2B 2C 86 7A 73 98 EF 5A 82 A9
21:34:19.969 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
21:34:19.971 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 18 00 49 84 02 12 04 10 05 5E 25 70 85 59 72 2B 2C 86 7A 73 98 EF 5A 82 A9
21:34:19.972 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 18 00 49 84 02 12 04 10 05 5E 25 70 85 59 72 2B 2C 86 7A 73 98 EF 5A 82 A9
21:34:19.973 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationUpdate (0x49), type = Request (0x00), payload = 84 02 12 04 10 05 5E 25 70 85 59 72 2B 2C 86 7A 73 98 EF 5A 82
21:34:19.989 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 2: Application update request. Node information received.
21:34:19.991 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 02 03 70 05 25
21:34:19.993 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = ApplicationUpdate (0x49), type = Request (0x00), payload = 84 02 12 04 10 05 5E 25 70 85 59 72 2B 2C 86 7A 73 98 EF 5A 82
21:34:19.994 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationUpdate, expected=ApplicationCommandHandler, cancelled=false
openhab>
Thanks - so from your perspective, did it look like this worked ok? Looking at the logs, it looks fine - both parameters appear to be processed ok, and the three parameters appear to be set ok (that’s the hidden ‘real’ parameter, and the two ‘sub-parameters’).
Thanks for the testing :slightly_smiling:
for the joy of my neighbors I will try all 15 different settings when I come home from work :wink:
I will let you know if all looks good … yesterday I just muted it and got the log …
Node 4: DCH-Z110 Door & Window Sensor still shows offline … I think it could be the sub parameter 7?
if that was compiled in on the latest jars
The database for the Z110 that’s currently in the JAR doesn’t have the sub-parameters included… You should be able to confirm that by looking in the device configuration - you should just see the single parameter 7.
hi chris
seems not ok - changing volume does actually change sound … so I assume these 2 values are mixed up in in sub parameter magic?
Maybe - does changing sound change the volume? :wink: If so, I’ll swap them around. If they both change the same thing (sound) then there’s a bug in the processing…
really not that easy to tell…
I would say yes swap them… it tends to be a little lower in volume sometimes
however I dont know if sound 1 equals 88db and so on :wink:
and I definately can not set all different 5 sounds with the 3 volume parameters :smiley:
Maybe I should take a look at a log - instead of changing both parameters, maybe change one, then the other 10 seconds later?
I would … but currently its not coming back online… also deleting the node did not help :frowning:
ok whatever I try … Node 2 stays dead
since I can not go for a exclusion…
fatory reset and inclusion again? what happens to Node 2 then? :-/
edit:
since when is that option to remove a device available? didn’t notice it before… is it hard removal or exclusion?
Likely node 2 will remain and you should be able to delete it, and you’ll end up with a new node number…
Since always :wink:. It doesn’t exclude - it removes…
There are two possible options that you can see here, and they do different things. The one you see now probably means that the stick thinks the device is FAILED (this is bad!) and this option will delete this node from the controllers list of devices. In theory, the binding will only present this option if the device is in this FAILED state - this information comes directly from the stick and you can see this check in the log during startup (it’s probably the first check that’s done during device initialisation).
ok just reset siren on the siren itself and started discovery
now added as NODE 10
First set a new SOUND; Second set a new VOLUME
part 1 (parts are not split by the 2 actions :wink: just by too many lines)
20:15:53.600 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update received
20:15:53.603 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update config_37_2_0000000F to 2
20:15:53.604 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Set sub-parameter 37 from 2 / 0000000F
20:15:53.606 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Parameter 37 set value 00000002 mask 0000000F
20:15:53.607 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 10: Creating new message for application command CONFIGURATIONCMD_GET
20:15:53.609 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
20:15:53.610 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 0A 03 70 05 25 25 43 D9
20:15:53.618 [DEBUG] [ve.internal.protocol.ZWaveController] - Enqueueing message. Queue length = 0
20:15:53.618 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 10: Sending REQUEST Message = 01 0A 00 13 0A 03 70 05 25 25 43 D9
20:15:53.627 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_152faff77f7_serial_ack changed from 126 to 127
20:15:53.631 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
20:15:53.634 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_152faff77f7_serial_sof changed from 248 to 249
20:15:53.635 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
20:15:53.636 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
20:15:53.637 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
20:15:53.638 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = SendData (0x13), type = Response (0x01), payload = 01
20:15:53.639 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 10: Sent Data successfully placed on stack.
20:15:53.648 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 43 00 00 02 AA
20:15:53.651 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_152faff77f7_serial_sof changed from 249 to 250
20:15:53.691 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
20:15:53.692 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 43 00 00 02 00 00 A4
20:15:53.694 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 43 00 00 02 00 00 A4
20:15:53.695 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0E 00 04 00 0A 08 70 06 25 02 01 03 00 00 A4
20:15:53.695 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = SendData (0x13), type = Request (0x00), payload = 43 00 00 02
20:15:53.697 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 10: SendData Request. CallBack ID = 67, Status = Transmission complete and ACK received(0)
20:15:53.697 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_152faff77f7_serial_sof changed from 250 to 251
20:15:53.701 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 0A 03 70 05 25
20:15:53.702 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 43 00 00 02
20:15:53.703 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, expected=ApplicationCommandHandler, cancelled=false
20:15:53.704 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
20:15:53.705 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0E 00 04 00 0A 08 70 06 25 02 01 03 00 00 A4
20:15:53.706 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0E 00 04 00 0A 08 70 06 25 02 01 03 00 00 A4
20:15:53.706 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 0A 08 70 06 25 02 01 03 00 00
20:15:53.707 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 10: Application Command Request (ALIVE:DONE)
20:15:53.708 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 10: Incoming command class CONFIGURATION
20:15:53.708 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 10: Received Configuration Request
20:15:53.709 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 10: Node configuration report, parameter = 37, value = 259, size = 2
20:15:53.709 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveConfigurationParameterEvent
20:15:53.710 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got an event from Z-Wave network: ZWaveConfigurationParameterEvent
20:15:53.711 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got a value event from Z-Wave network, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ZWaveConfigurationParameter@16c037
20:15:53.711 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Update CONFIGURATION 37/2 to 259
20:15:53.712 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Updating sub-parameter 37 to 258
20:15:53.712 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Setting parameter 37 to 258
20:15:53.713 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 10: Creating new message for application command CONFIGURATIONCMD_SET
20:15:53.714 [DEBUG] [ve.internal.protocol.ZWaveController] - Enqueueing message. Queue length = 1
20:15:53.714 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 10: Creating new message for application command CONFIGURATIONCMD_GET
20:15:53.715 [DEBUG] [ve.internal.protocol.ZWaveController] - Enqueueing message. Queue length = 2
20:15:53.716 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 0A 03 70 05 25
20:15:53.717 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 0A 08 70 06 25 02 01 03 00 00
20:15:53.717 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, expected=ApplicationCommandHandler, cancelled=false
20:15:53.717 [DEBUG] [.serialmessage.ZWaveCommandProcessor] -          transaction complete!
20:15:53.718 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
20:15:53.719 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
20:15:53.719 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 10: Response processed after 98ms/4949ms.
20:15:53.720 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 1
20:15:53.721 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0D 00 13 0A 06 70 04 25 02 01 02 25 44 DC
20:15:53.722 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 10: Sending REQUEST Message = 01 0D 00 13 0A 06 70 04 25 02 01 02 25 44 DC
20:15:53.729 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_152faff77f7_serial_ack changed from 127 to 128
20:15:53.740 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
20:15:53.740 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_152faff77f7_serial_sof changed from 251 to 252
20:15:53.747 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
20:15:53.753 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
20:15:53.754 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_152faff77f7_serial_sof changed from 252 to 253
20:15:53.755 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 44 00 00 03 AC
20:15:53.756 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
20:15:53.757 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = SendData (0x13), type = Response (0x01), payload = 01
20:15:53.757 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 10: Sent Data successfully placed on stack.
20:15:53.759 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
20:15:53.761 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 44 00 00 03 00 00 A2
20:15:53.762 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 44 00 00 03 00 00 A2
20:15:53.763 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = SendData (0x13), type = Request (0x00), payload = 44 00 00 03
20:15:53.763 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 10: SendData Request. CallBack ID = 68, Status = Transmission complete and ACK received(0)
20:15:53.764 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 0A 06 70 04 25 02 01 02
20:15:53.765 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 44 00 00 03
20:15:53.766 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, expected=SendData, cancelled=false
20:15:53.766 [DEBUG] [.serialmessage.ZWaveCommandProcessor] -          transaction complete!
20:15:53.767 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
20:15:53.768 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
20:15:53.769 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 10: Response processed after 46ms/4949ms.
20:15:53.769 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
20:15:53.770 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 0A 03 70 05 25 25 45 DF
20:15:53.772 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 10: Sending REQUEST Message = 01 0A 00 13 0A 03 70 05 25 25 45 DF
20:15:53.781 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_152faff77f7_serial_ack changed from 128 to 129
20:15:53.783 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
20:15:53.785 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
20:15:53.786 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
20:15:53.787 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
20:15:53.787 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = SendData (0x13), type = Response (0x01), payload = 01
20:15:53.788 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 10: Sent Data successfully placed on stack.
20:15:53.794 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_152faff77f7_serial_sof changed from 253 to 254
20:15:53.800 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 45 00 00 02 AC
20:15:53.802 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
20:15:53.804 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 45 00 00 02 00 00 A2
20:15:53.805 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 45 00 00 02 00 00 A2
20:15:53.806 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = SendData (0x13), type = Request (0x00), payload = 45 00 00 02
20:15:53.806 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 10: SendData Request. CallBack ID = 69, Status = Transmission complete and ACK received(0)
20:15:53.808 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 0A 03 70 05 25
20:15:53.809 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 45 00 00 02
20:15:53.809 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, expected=ApplicationCommandHandler, cancelled=false
20:15:53.823 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0E 00 04 00 0A 08 70 06 25 02 01 02 00 00 A5
20:15:53.824 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_152faff77f7_serial_sof changed from 254 to 255
20:15:53.827 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
20:15:53.828 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0E 00 04 00 0A 08 70 06 25 02 01 02 00 00 A5
20:15:53.829 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0E 00 04 00 0A 08 70 06 25 02 01 02 00 00 A5
20:15:53.831 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 0A 08 70 06 25 02 01 02 00 00
20:15:53.832 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 10: Application Command Request (ALIVE:DONE)
20:15:53.832 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 10: Incoming command class CONFIGURATION
20:15:53.833 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 10: Received Configuration Request
20:15:53.834 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 10: Node configuration report, parameter = 37, value = 258, size = 2
20:15:53.834 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveConfigurationParameterEvent
20:15:53.835 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got an event from Z-Wave network: ZWaveConfigurationParameterEvent
20:15:53.836 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got a value event from Z-Wave network, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ZWaveConfigurationParameter@16c037
20:15:53.836 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_152faff77f7_serial_sof changed from 255 to 256
20:15:53.836 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Update CONFIGURATION 37/2 to 258
20:15:53.838 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Config about to update 5 parameters...
20:15:53.839 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2
20:15:53.840 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2 len=3
20:15:53.840 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2 - id = '37'
20:15:53.841 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2 - size = '2'
20:15:53.841 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Sub-parameter config_37_2 is 00000102
20:15:53.842 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Pre-processing  00000102>>FFFFFFFF
20:15:53.843 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Post-processing 00000102>>FFFFFFFF
20:15:53.844 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Sub-parameter setting config_37_2 is 00000102 [258]
20:15:53.844 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_80_1
20:15:53.845 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_80_1 len=3
20:15:53.846 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_80_1 - id = '80'
20:15:53.846 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2_0000000F
20:15:53.847 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2_0000000F len=4
20:15:53.847 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2_0000000F - id = '37'
20:15:53.848 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2_0000000F - size = '2'
20:15:53.849 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2_0000000F - bitmask = '0000000F'
20:15:53.849 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2_0000000F - dec = '15'
20:15:53.850 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Sub-parameter config_37_2_0000000F is 00000002
20:15:53.850 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Pre-processing  00000002>>0000000F
20:15:53.851 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Post-processing 00000002>>0000000F
20:15:53.852 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Sub-parameter setting config_37_2_0000000F is 00000002 [2]
part 2:
20:15:53.853 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2_00000F00
20:15:53.853 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2_00000F00 len=4
20:15:53.854 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2_00000F00 - id = '37'
20:15:53.854 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2_00000F00 - size = '2'
20:15:53.855 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2_00000F00 - bitmask = '00000F00'
20:15:53.855 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2_00000F00 - dec = '3840'
20:15:53.856 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Sub-parameter config_37_2_00000F00 is 00000100
20:15:53.857 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Pre-processing  00000100>>00000F00
20:15:53.857 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Post-processing 00000001>>00000F00
20:15:53.858 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Sub-parameter setting config_37_2_00000F00 is 00000001 [1]
20:15:53.859 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_252_1
20:15:53.860 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_252_1 len=3
20:15:53.860 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_252_1 - id = '252'
20:15:53.893 [INFO ] [smarthome.event.ThingUpdatedEvent   ] - Thing 'zwave:aeon_dsd31_00_000:152faff77f7:node10' has been updated.
20:15:54.116 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Config updated
20:15:54.118 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 0A 03 70 05 25
20:15:54.118 [INFO ] [smarthome.event.ThingUpdatedEvent   ] - Thing 'zwave:aeon_dsd31_00_000:152faff77f7:node10' has been updated.
20:15:54.121 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 0A 08 70 06 25 02 01 02 00 00
20:15:54.123 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, expected=ApplicationCommandHandler, cancelled=false
20:15:54.124 [DEBUG] [.serialmessage.ZWaveCommandProcessor] -          transaction complete!
20:15:54.126 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
20:15:54.127 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
20:15:54.129 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 10: Response processed after 355ms/4949ms.
20:15:58.781 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 49 84 0A 12 04 10 05 5E 25 70 85 59 72 2B 2C 86 7A 73 98 EF 5A 82 A1
20:15:58.787 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
20:15:58.788 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_152faff77f7_serial_sof changed from 256 to 257
20:15:58.792 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 18 00 49 84 0A 12 04 10 05 5E 25 70 85 59 72 2B 2C 86 7A 73 98 EF 5A 82 A1
20:15:58.811 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 18 00 49 84 0A 12 04 10 05 5E 25 70 85 59 72 2B 2C 86 7A 73 98 EF 5A 82 A1
20:15:58.823 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationUpdate (0x49), type = Request (0x00), payload = 84 0A 12 04 10 05 5E 25 70 85 59 72 2B 2C 86 7A 73 98 EF 5A 82
20:15:58.835 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 10: Application update request. Node information received.
20:15:58.840 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 0A 03 70 05 25
20:15:58.842 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = ApplicationUpdate (0x49), type = Request (0x00), payload = 84 0A 12 04 10 05 5E 25 70 85 59 72 2B 2C 86 7A 73 98 EF 5A 82
20:15:58.845 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationUpdate, expected=ApplicationCommandHandler, cancelled=false
20:16:14.417 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update received
20:16:14.419 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Configuration update config_37_2_00000F00 to 1
20:16:14.420 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Set sub-parameter 37 from 1 / 00000F00
20:16:14.421 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Parameter 37 set value 00000001 mask 00000F00
20:16:14.421 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 10: Creating new message for application command CONFIGURATIONCMD_GET
20:16:14.422 [DEBUG] [ve.internal.protocol.ZWaveController] - Enqueueing message. Queue length = 1
20:16:14.422 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
20:16:14.425 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 0A 03 70 05 25 25 46 DC
20:16:14.427 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 10: Sending REQUEST Message = 01 0A 00 13 0A 03 70 05 25 25 46 DC
20:16:14.446 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_152faff77f7_serial_ack changed from 129 to 130
20:16:14.455 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_152faff77f7_serial_sof changed from 257 to 258
20:16:14.458 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
20:16:14.461 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
20:16:14.463 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
20:16:14.464 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
20:16:14.465 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = SendData (0x13), type = Response (0x01), payload = 01
20:16:14.465 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 10: Sent Data successfully placed on stack.
20:16:14.473 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_152faff77f7_serial_sof changed from 258 to 259
20:16:14.476 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 46 00 00 02 AF
20:16:14.479 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
20:16:14.480 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 46 00 00 02 00 00 A1
20:16:14.481 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 46 00 00 02 00 00 A1
20:16:14.483 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = SendData (0x13), type = Request (0x00), payload = 46 00 00 02
20:16:14.485 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 10: SendData Request. CallBack ID = 70, Status = Transmission complete and ACK received(0)
20:16:14.487 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 0A 03 70 05 25
20:16:14.489 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 46 00 00 02
20:16:14.496 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, expected=ApplicationCommandHandler, cancelled=false
20:16:14.496 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_152faff77f7_serial_sof changed from 259 to 260
20:16:14.498 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0E 00 04 00 0A 08 70 06 25 02 01 02 00 00 A5
20:16:14.502 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
20:16:14.503 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0E 00 04 00 0A 08 70 06 25 02 01 02 00 00 A5
20:16:14.505 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0E 00 04 00 0A 08 70 06 25 02 01 02 00 00 A5
20:16:14.507 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 0A 08 70 06 25 02 01 02 00 00
20:16:14.511 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 10: Application Command Request (ALIVE:DONE)
20:16:14.513 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 10: Incoming command class CONFIGURATION
20:16:14.513 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 10: Received Configuration Request
20:16:14.514 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 10: Node configuration report, parameter = 37, value = 258, size = 2
20:16:14.515 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveConfigurationParameterEvent
20:16:14.516 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got an event from Z-Wave network: ZWaveConfigurationParameterEvent
20:16:14.517 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got a value event from Z-Wave network, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ZWaveConfigurationParameter@16c037
20:16:14.518 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Update CONFIGURATION 37/2 to 258
20:16:14.518 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Updating sub-parameter 37 to 258
20:16:14.519 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Setting parameter 37 to 258
20:16:14.520 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 10: Creating new message for application command CONFIGURATIONCMD_SET
20:16:14.521 [DEBUG] [ve.internal.protocol.ZWaveController] - Enqueueing message. Queue length = 1
20:16:14.522 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 10: Creating new message for application command CONFIGURATIONCMD_GET
20:16:14.523 [DEBUG] [ve.internal.protocol.ZWaveController] - Enqueueing message. Queue length = 2
20:16:14.525 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 0A 03 70 05 25
20:16:14.526 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 0A 08 70 06 25 02 01 02 00 00
20:16:14.527 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, expected=ApplicationCommandHandler, cancelled=false
20:16:14.527 [DEBUG] [.serialmessage.ZWaveCommandProcessor] -          transaction complete!
20:16:14.528 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
20:16:14.529 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
20:16:14.530 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 10: Response processed after 90ms/4949ms.
20:16:14.532 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 1
20:16:14.533 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0D 00 13 0A 06 70 04 25 02 01 02 25 47 DF
20:16:14.534 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 10: Sending REQUEST Message = 01 0D 00 13 0A 06 70 04 25 02 01 02 25 47 DF
20:16:14.540 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_152faff77f7_serial_ack changed from 130 to 131
20:16:14.544 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
20:16:14.546 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
20:16:14.547 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
20:16:14.547 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
20:16:14.548 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = SendData (0x13), type = Response (0x01), payload = 01
20:16:14.549 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_152faff77f7_serial_sof changed from 260 to 261
20:16:14.550 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 10: Sent Data successfully placed on stack.
20:16:14.561 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 47 00 00 02 AE
20:16:14.564 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_152faff77f7_serial_sof changed from 261 to 262
20:16:14.565 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
20:16:14.566 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 47 00 00 02 00 00 A0
20:16:14.568 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 47 00 00 02 00 00 A0
20:16:14.569 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = SendData (0x13), type = Request (0x00), payload = 47 00 00 02
20:16:14.570 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 10: SendData Request. CallBack ID = 71, Status = Transmission complete and ACK received(0)
20:16:14.572 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 0A 06 70 04 25 02 01 02
20:16:14.574 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 47 00 00 02
20:16:14.575 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, expected=SendData, cancelled=false
20:16:14.576 [DEBUG] [.serialmessage.ZWaveCommandProcessor] -          transaction complete!
20:16:14.577 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
20:16:14.578 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
20:16:14.580 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 10: Response processed after 45ms/4949ms.
20:16:14.581 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
20:16:14.582 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 0A 03 70 05 25 25 48 D2
20:16:14.583 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 10: Sending REQUEST Message = 01 0A 00 13 0A 03 70 05 25 25 48 D2
20:16:14.590 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_152faff77f7_serial_ack changed from 131 to 132
20:16:14.595 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
20:16:14.598 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
20:16:14.598 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_152faff77f7_serial_sof changed from 262 to 263
20:16:14.599 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
20:16:14.600 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
20:16:14.601 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = SendData (0x13), type = Response (0x01), payload = 01
20:16:14.601 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 10: Sent Data successfully placed on stack.
20:16:14.610 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 48 00 00 02 A1
20:16:14.620 [INFO ] [smarthome.event.ThingUpdatedEvent   ] - Thing 'zwave:aeon_dsd31_00_000:152faff77f7:node10' has been updated.
20:16:14.621 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
20:16:14.622 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_152faff77f7_serial_sof changed from 263 to 264
20:16:14.624 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 48 00 00 02 00 00 AF
20:16:14.626 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 48 00 00 02 00 00 AF
20:16:14.627 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = SendData (0x13), type = Request (0x00), payload = 48 00 00 02
20:16:14.639 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0E 00 04 00 0A 08 70 06 25 02 01 02 00 00 A5
20:16:14.634 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 10: SendData Request. CallBack ID = 72, Status = Transmission complete and ACK received(0)
20:16:14.646 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 0A 03 70 05 25
20:16:14.647 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 48 00 00 02
20:16:14.651 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, expected=ApplicationCommandHandler, cancelled=false
20:16:14.651 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_152faff77f7_serial_sof changed from 264 to 265
20:16:14.653 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
20:16:14.655 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0E 00 04 00 0A 08 70 06 25 02 01 02 00 00 A5
20:16:14.657 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0E 00 04 00 0A 08 70 06 25 02 01 02 00 00 A5
20:16:14.659 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 0A 08 70 06 25 02 01 02 00 00
20:16:14.661 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 10: Application Command Request (ALIVE:DONE)
20:16:14.662 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 10: Incoming command class CONFIGURATION
20:16:14.663 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 10: Received Configuration Request
20:16:14.664 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 10: Node configuration report, parameter = 37, value = 258, size = 2
20:16:14.665 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveConfigurationParameterEvent
20:16:14.666 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got an event from Z-Wave network: ZWaveConfigurationParameterEvent
20:16:14.667 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got a value event from Z-Wave network, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ZWaveConfigurationParameter@16c037
20:16:14.668 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Update CONFIGURATION 37/2 to 258
20:16:14.670 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Config about to update 5 parameters...
20:16:14.671 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2
20:16:14.671 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2 len=3
20:16:14.672 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2 - id = '37'
20:16:14.673 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2 - size = '2'
20:16:14.674 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Sub-parameter config_37_2 is 00000102
20:16:14.675 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Pre-processing  00000102>>FFFFFFFF
20:16:14.676 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Post-processing 00000102>>FFFFFFFF
20:16:14.677 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Sub-parameter setting config_37_2 is 00000102 [258]
20:16:14.678 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_80_1
20:16:14.680 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_80_1 len=3
20:16:14.680 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_80_1 - id = '80'
20:16:14.681 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2_0000000F
20:16:14.682 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2_0000000F len=4
20:16:14.683 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2_0000000F - id = '37'
20:16:14.683 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2_0000000F - size = '2'
20:16:14.683 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2_0000000F - bitmask = '0000000F'
20:16:14.684 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2_0000000F - dec = '15'
20:16:14.685 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Sub-parameter config_37_2_0000000F is 00000002
20:16:14.686 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Pre-processing  00000002>>0000000F
20:16:14.687 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Post-processing 00000002>>0000000F
20:16:14.687 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Sub-parameter setting config_37_2_0000000F is 00000002 [2]
20:16:14.689 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2_00000F00
20:16:14.689 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2_00000F00 len=4
20:16:14.690 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2_00000F00 - id = '37'
20:16:14.691 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2_00000F00 - size = '2'
20:16:14.691 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2_00000F00 - bitmask = '00000F00'
20:16:14.692 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_37_2_00000F00 - dec = '3840'
20:16:14.692 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Sub-parameter config_37_2_00000F00 is 00000100
20:16:14.693 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Pre-processing  00000100>>00000F00
20:16:14.694 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Post-processing 00000001>>00000F00
20:16:14.695 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Sub-parameter setting config_37_2_00000F00 is 00000001 [1]
20:16:14.695 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_252_1
20:16:14.696 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_252_1 len=3
20:16:14.698 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Processing config_252_1 - id = '252'
20:16:14.933 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Config updated
20:16:14.935 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 0A 03 70 05 25
20:16:14.935 [INFO ] [smarthome.event.ThingUpdatedEvent   ] - Thing 'zwave:aeon_dsd31_00_000:152faff77f7:node10' has been updated.
20:16:14.937 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 0A 08 70 06 25 02 01 02 00 00
20:16:14.937 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, expected=ApplicationCommandHandler, cancelled=false
20:16:14.938 [DEBUG] [.serialmessage.ZWaveCommandProcessor] -          transaction complete!
20:16:14.939 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
20:16:14.939 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
20:16:14.940 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 10: Response processed after 356ms/4949ms.
20:16:20.300 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 49 84 0A 12 04 10 05 5E 25 70 85 59 72 2B 2C 86 7A 73 98 EF 5A 82 A1
20:16:20.303 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
20:16:20.304 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_152faff77f7_serial_sof changed from 265 to 266
20:16:20.309 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 18 00 49 84 0A 12 04 10 05 5E 25 70 85 59 72 2B 2C 86 7A 73 98 EF 5A 82 A1
20:16:20.311 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 18 00 49 84 0A 12 04 10 05 5E 25 70 85 59 72 2B 2C 86 7A 73 98 EF 5A 82 A1
20:16:20.312 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationUpdate (0x49), type = Request (0x00), payload = 84 0A 12 04 10 05 5E 25 70 85 59 72 2B 2C 86 7A 73 98 EF 5A 82
20:16:20.313 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 10: Application update request. Node information received.
20:16:20.314 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 0A 03 70 05 25
20:16:20.315 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Recv message Message: class = ApplicationUpdate (0x49), type = Request (0x00), payload = 84 0A 12 04 10 05 5E 25 70 85 59 72 2B 2C 86 7A 73 98 EF 5A 82
20:16:20.316 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationUpdate, expected=ApplicationCommandHandler, cancelled=false
20:16:34.767 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 09 03 20 01 00 D9
20:16:34.766 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_152faff77f7_serial_sof changed from 266 to 267
20:16:34.773 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
20:16:34.775 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 09 03 20 01 00 D9
20:16:34.776 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 09 03 20 01 00 D9
20:16:34.777 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 09 03 20 01 00
20:16:34.777 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
20:16:34.778 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class BASIC
20:16:34.779 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 9: Received Basic Request
20:16:34.780 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 9: Basic Set sent to the controller will be processed as Basic Report
20:16:34.780 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 9: Basic report, value = 0x00
20:16:34.781 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
20:16:34.782 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
20:16:34.783 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 0
20:16:34.789 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_aeon_zw100_00_000_152faff77f7_node9_sensor_relhumidity changed from 43 to 0
20:16:34.790 [DEBUG] [ssage.ApplicationCommandMessageClass] - Transaction not completed: node address inconsistent.
20:16:34.797 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_aeon_zw100_00_000_152faff77f7_node9_sensor_temperature changed from 22.7 to 0
20:16:35.065 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 09 0A 71 05 00 00 00 FF 07 00 00 00 64
20:16:35.066 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_152faff77f7_serial_sof changed from 267 to 268
20:16:35.068 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
20:16:35.069 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 10 00 04 00 09 0A 71 05 00 00 00 FF 07 00 00 00 64
20:16:35.070 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 10 00 04 00 09 0A 71 05 00 00 00 FF 07 00 00 00 64
20:16:35.071 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 09 0A 71 05 00 00 00 FF 07 00 00 00
20:16:35.072 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
20:16:35.073 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class ALARM
20:16:35.073 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Received Alarm Request
20:16:35.073 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Process Alarm Report, V3, length 13
20:16:35.074 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Alarm report - 0 = 0, source=0, event=0, status=255
20:16:35.074 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Alarm Type = General (0)
20:16:35.075 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
20:16:35.076 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveAlarmValueEvent
20:16:35.076 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 0
20:16:35.079 [DEBUG] [ssage.ApplicationCommandMessageClass] - Transaction not completed: node address inconsistent.
btw… can I clean up the NODE counter somehow…
I have quite a few numbers missing
No - they are set by the controller, and there’s no way to change them (at least not as far as I know).
All looks good to me…
Volume request received
Binding requests current value
Current value is 259 (0x103) - we want to change the 03 to 02…
NODE 10: Setting parameter 37 to 258 (258 = 0x102)
We set the value, and then request a read back.
Read back confirmed :slight_smile:
We process the 3 parameters (the real parameter 37, then the two sub-parameters) and update the UI… Stage 1 successful :slightly_smiling:
Sound request received
Request current value
Response received and we send out our SET and GET. There’s a potential simplification here in that the value was already set correctly, so I could have done nothing…
Response received, processed, and we’re done…
I also checked the docs, and the low/high bytes (ie volume and sound) are around the right way - at least according to the docs :wink:
checked it once again and can clearly say
Sound 1 = DB88
Sound 2 = DB100
Sound 3 = DB105
Sound 4,5 = no effect
Volume 1,2,3 do change to different alarm sounds
Ok - thanks. I’ll swap them around. I guess that means the documentation is wrong :confused:
I did however find on the OZW website they also have them swapped (ie the same as you are reporting).
ok once I got the new jar I will test again…
is the new jar placed in theme channel of habmin2 again? or now only via official addons in paperui?
Actually, I mis-read the OZW - they are the same as the manual, which it seems is what I have in the database…
<Item label="Sound 1 - Low Volume" value="257"/>
<Item label="Sound 1 - Mid Volume" value="258"/>
<Item label="Sound 1 - High Volume" value="259"/>
<Item label="Sound 2 - Low Volume" value="513"/>
<Item label="Sound 2 - Mid Volume" value="514"/>
<Item label="Sound 2 - High Volume" value="515"/>
<Item label="Sound 3 - Low Volume" value="769"/>
<Item label="Sound 3 - Mid Volume" value="770"/>
<Item label="Sound 3 - High Volume" value="771"/>
<Item label="Sound 4 - Low Volume" value="1025"/>
<Item label="Sound 4 - Mid Volume" value="1026"/>
<Item label="Sound 4 - High Volume" value="1027"/>
<Item label="Sound 5 - Low Volume" value="1281"/>
<Item label="Sound 5 - Mid Volume" value="1282"/>
<Item label="Sound 5 - High Volume" value="1283"/>
Maybe it’s worth trying these numbers into the ‘advanced’ parameter 32?
