I was going to try and just do a nightly update via the official route. If there’s a lot of debugging happening (like yesterday
) then I’ll also use another route such as the Github site…
these values in advanced do exactly work out as named in the label before them ![]()
so where is the error?
Good question…
if you set the sup-parameter volume to middle, and sound to 3, then check the log file for messages like “Setting parameter 37 to 770”, and then do it again with (say) sound 5 and low volume and see if the number is now 1281 - it will check that the conversions are right…
Can you please provide me an example of your item and sitemap definition of the siren?
I tried to play different sounds too and it is not working wiht the current 2.1.0 zwave snapshop, in older once it was working.
