Hello!
I’m just getting started with OpenHAB2 (no experience with OpenHAB), and while importing Z-wave things, I’ve found that one my devices (an in-wall relay single switch) is not in the database.
After reading some posts, I think I’ve determined that I cannot do much about this without either a) registering on the database, or b) installing an eclipse development environment, which is beyond me at this point.
Within the Z-wave device database, there is a very similar device already created, the ZWN-RSM2, which is an in-wall relay dual switch.
The database guide indicates that I should upload the XML file created by OpenHAB2, however, even after adding the thing to OpenHAB using the inbox through either HABMin or PaperUI, no XML file is created in /opt/openhab2/userdata/zwave . I can see my other nodes (2,3,4 & 6), but the assigned Node (5) was not created.
There is an online listing for the device here.
The message I get in PaperUI looks like this:
Z-Wave Node 5 (011A:0111:0605:5.10)
Unknown Device
This device has not been fully discovered by the binding. There are a few possible reasons for this -:
The device is not in the database. If the device attributes show that this device has a valid manufacturer ID, device ID and type, then this is likely the case (eg. you see a label like “Z-Wave node 1 (0082:6015:020D::2.0)”). Even if the device appears to be in the database, some manufacturers use multiple sets of references for different regions or versions, and your device references may not be in the database. In either case, the database must be updated and you should raise an issue to get this addressed.
The device initialisation is not complete. Once the device is included into the network, the binding must interrogate it to find out what type of device it is. One part of this process is to get the manufacturer information required to identify the device, and until this is done, the device will remain unknown. For mains powered devices, this will occur quickly, however for battery devices the device must be woken up a number of times to allow the discovery phase to complete. This must be performed with the device close to the controller.
Is there anything else I can do to help add this device to the database?
Thanks,
Sherwin
