Following the issues I had in previous topic I opened, now I have a few working devices (PAN08 and PAN04), but few are still with status Unknown. One of them even was active and worked before I reinstalled everything.
As per the suggestion in PaperUI (as you posted above) - it says - “for battery devices the device must be woken up a number of times”.
You need to do this for it to be discovered. Possibly if you just leave it for a few hours or days (depending on the device config) it might sort itself out.
Looking at this further, there is no communication with any device in your log. The controller is rejecting all communications so I’d suggest a reset for starters.
Maybe elsewhere it’s working, in which case please provide a log that I can look at as at the moment all I can see are CAN responses from the controller which cancel all outgoing transactions.
The only responses I see in the log are the identify node responses and these only come from the controller - notover the ZWave network.
