- Platform information:
- Hardware: Raspberry Pi 3
- OS: Raspbian GNU/Linux 9 (stretch)
- Java Runtime Environment: openjdk version “1.8.0_152”
- openHAB version: OpenHabian 2.3.0-1
- Issue of the topic:
I’m new to this and very excited to get things going. I just bought a house a few weeks ago, and started setting up all my components. I have a Aeotec Z-stick gen5 hooked up to a Raspberry Pi 3 running OpenHabian. I was able to connect two Monoprice door sensors, an Aeotec Water Sensor, Z-Wave Flood & Leak Sensor (DSB45) and two CT-101 thermostats.
The door sensors worked fine immediately. The Z-Wave Flood & Leak Sensor doesn’t report it’s status on the control screen of Paper UI.
However, it shows up working in the log. This is what happens when I submerge the sensor. Nothing changes on the control screen.
2018-06-25 07:41:25.109 [vent.ItemStateChangedEvent] - WaterSensorFridge_BinarySensor changed from NULL to ON
2018-06-25 07:41:25.150 [vent.ItemStateChangedEvent] - ZWaveNode3_BatteryLevel changed from 98 to 100
2018-06-25 07:41:25.595 [vent.ItemStateChangedEvent] - WaterSensorFridge_BinarySensor changed from ON to OFF
2018-06-25 07:41:25.651 [vent.ItemStateChangedEvent] - ZWaveNode3_BatteryLevel changed from 100 to 99
2018-06-25 07:41:27.750 [vent.ItemStateChangedEvent] - WaterSensorFridge_BinarySensor changed from OFF to ON
2018-06-25 07:41:28.747 [vent.ItemStateChangedEvent] - WaterSensorFridge_BinarySensor changed from ON to OFF
2018-06-25 07:41:28.796 [vent.ItemStateChangedEvent] - ZWaveNode3_BatteryLevel changed from 99 to 98
2018-06-25 07:41:29.394 [vent.ItemStateChangedEvent] - WaterSensorFridge_BinarySensor changed from OFF to ON
2018-06-25 07:41:29.445 [vent.ItemStateChangedEvent] - ZWaveNode3_BatteryLevel changed from 98 to 100
2018-06-25 07:41:30.044 [vent.ItemStateChangedEvent] - WaterSensorFridge_BinarySensor changed from ON to OFF
I have a similar issue with the CT-101 thermostats. I can change the temperature, but it doesn’t read the current temp, state, mode, etcetera.
What am I missing here?
