I’m trying to use the Qubino ZMNHAD1 with OH2 (latest snapshot).
I’ve attached association group 2 to OH for getting reports on presses of the physical switch attached to the ZMNHAD1, however, this error is popping up in the logs when the switch is pressed and the status is never updated.
22:35:23.591 [ERROR] [class.ZWaveMultiInstanceCommandClass] - NODE 2: Endpoint 1 not found. Cannot set command classes.
22:35:26.303 [ERROR] [class.ZWaveMultiInstanceCommandClass] - NODE 2: Endpoint 1 not found. Cannot set command classes.
Also, when linking the binary sensor to an item, these messages pop up:
@chris Could this have something to do with multi-channel v3 not being supported in the binding? The manual says the device supports the multi-channel v3 command class, but in the source code of the binding I can only find references to the multi-instance v2 command class.
I’m pretty much a noob regarding Z-wave, so I’m only reporting what I am seeing
Multi-channel is definitely supported in the binding - not just multi-instance. The extra commands in V3 almost certainly won’t matter. The fact that the report says V0 indicates something else has probably gone wrong. That said, the XML doesn’t show the V0, so I don’t really know what’s causing this without the log…
Sorry - I’ve not had the chance to look at this as I’ve been tied up with other things - I just had a quick look at your log and there’s no debug information included so you’ll need to update this and then I’ll try and take a look to see what’s up.
Sorry - I missed your previous message (it’s always best to reply or mention me - otherwise there’s no notifications sent).
I’ve just had a quick look in the logs, but there’s really nothing to go on. There’s next to no information from the zwave binding in the log - nothing at all showing any received or transmitted messages (ie no zwave messages) so really I can’t comment much - sorry.
Have you tried deleting the XML and restarting the binding? I would suggest this, and grabbing the debug log during the startup so we can actually see what’s happening during the interrogation period.
@chris Thanks for replying!
I’ve shut down openHAB, removed the XML and restarted openHAB in this new log file.
Also, I tried to use the physical switch again, so that should be in the logs too.
No problem. I checked the last two logs which ran from 07:00 to 14:30 today and there’s no errors. Is this error here from yesterday or today (there’s no date on this log ;)).
I’m just wondering if the problem has gone after resetting the XML which is quite possible as it should re-interrogate the device.
You’ve probably said somewhere above, but I can’t see it (sorry) - what version of the binding are you using? Is this the latest snapshot of the release (or another)?
@chris This is some pre-2.0 release snapshot, but I got the same errors with 2.0 release and latest snapshot. I haven’t tried in a few weeks though, I’ll try to setup a new latest snapshot to see what happens.
In the new log files you can see me unlinking and relinking the Binary Sensor channel. You’ll see the ‘unsupported multi instance’ error popping up several times.
The ‘endpoint 1 not found’ error seems to be reported as DEBUG now, but it’s there in the logs.
