Hi dear openHAB community,
I’m the owner of a recent version of the Aeotec Multisensor 6 which I’m using with USB power (no battery).
I have configured it with the following lines in my default.things file
Thing zwave:aeon_zw100_01_010:controller:node10 "ZW100 MultiSensor 6" (zwave:serial_zstick:controller) [
node_id=10,
zwave_nodeid=10,
zwave_manufacturer=134,
zwave_deviceid=100,
zwave_devicetype=2,
zwave_version="1.11",
zwave_routing="true",
zwave_listening="true",
config_111_4=300,
wakeup_interval=1800
The thing is correctly displayed in the PaperUI interface and I have several items using it sucessfully.
Example of working config for an item on the temperature channel :
Number:Temperature ZW100_Temperature "ZW100" <temperature> (Home_Temperature) { channel="zwave:aeon_zw100_01_010:controller:node10:sensor_temperature" }
All this is working quite well except that I am not able to change the reporting interval. I’d like to set it to 5 minutes (300 seconds). If I understand the documentation well this should be done with the config_111_4 parameter. But it looks like it stays ignored, reporting is done every 1 hour (which seems to be the default value).
My openHAB version is 2.4
Any hint on what is going wrong would be greatly appreciated.
Thank you.
