Platform information:
- Hardware: RPi4, RaZberry 2nd gen controller
- OS: Raspbian Buster
- Java Runtime Environment: OpenJDK (Zulu Embedded) v.1.8.0_152
- openHAB version: Openhab2 2.4.0-1
Issue of the topic:
I use the Z-way binding in Openhab2, which talks to my z-way-server and RaZberry communication stack.
I have included the Aeotec Multisensor 6 (unsecurely).
I used Openhabs “simple mode” when adding the Thing, which instantiates the PIR Item as a Switch.
I can see the PIR link being enabled and turning ON during Openhab startup.
I can also see the PIR event happening - both by the green light blinking on the device, and in the z-way-server.log; but nothing shows up in Openhab’s events.log.
I am able to trigger a rule based on the PIR item being updated - which only happens once during boot.
I have tried to re-include, restart servers of course, but Openhab does not react to the event.
The device is USB powered.
So the problem is I cannot react to the event in Openhab and perform any logic based on the PIR firing
- Please post configurations (if applicable):
- Items configuration related to the issue
Switch PIR_sensor_1 "Motion sensor" <network> {channel="zway:zwayDevice:SERVER_IP:47:sensorMotion-ZWayVDev_zway_47-0-48-1"}
- Sitemap configuration related to the issue
- Rules code related to the issue
rule "Handle PIR Events"
Item PIR_sensor_1 received update
GF_LivingDining_Light_2.sendCommand(100)
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
openhab2/events.log
2019-11-09 10:25:56.199 [.ItemChannelLinkAddedEvent] - Link 'zway_zwayDevice_192_168_1_80_47_sensorMotion_ZWayVDev_zway_47_0_48_1-zway:zwayDevice:192_168_1_80:47:sensorMotion-ZWayVDev_zway_47-0-48-1' has been added.
2019-11-09 10:26:04.926 [vent.ItemStateChangedEvent] - zway_zwayDevice_192_168_1_80_47_sensorMotion_ZWayVDev_zway_47_0_48_1 changed from NULL to ON
z-way-server.log excerpt:
[2019-11-09 10:15:50.050] [D] [zway] SETDATA devices.47.data.lastReceived = 0 (0x00000000)
[2019-11-09 10:15:50.050] [D] [zway] SETDATA devices.47.instances.0.commandClasses.48.data.1.level = True
[2019-11-09 10:15:50.050] [D] [zway] SETDATA devices.47.instances.0.commandClasses.48.data.1 = Empty
[2019-11-09 10:15:50.063] [I] [core] Notification: device-info (device-OnOff): {"dev":"PIR (#47)","l":"on","location":""}
[2019-11-09 10:15:50.491] [D] [zway] RECEIVED: ( 01 11 00 04 00 2F 09 71 05 00 00 00 FF 07 08 00 CA 00 82 )
[2019-11-09 10:15:50.492] [D] [zway] SENT ACK
[2019-11-09 10:15:50.492] [D] [zway] SETDATA devices.47.data.lastReceived = 0 (0x00000000)
[2019-11-09 10:15:50.492] [D] [zway] SETDATA devices.47.instances.0.commandClasses.113.data.7.eventParameters = byte[0]
[2019-11-09 10:15:50.492] [D] [zway] ( zero-length buffer )
[2019-11-09 10:15:50.492] [D] [zway] SETDATA devices.47.instances.0.commandClasses.113.data.7.event = 8 (0x00000008)
[2019-11-09 10:15:50.494] [D] [zway] SETDATA devices.47.instances.0.commandClasses.113.data.7.eventString = "Motion detected, location unknown"
[2019-11-09 10:15:50.494] [D] [zway] SETDATA devices.47.instances.0.commandClasses.113.data.7.status = 255 (0x000000ff)
[2019-11-09 10:15:50.494] [D] [zway] SETDATA devices.47.instances.0.commandClasses.113.data.7 = Empty
