Hey,
I’m trying to configure a Z-Way-Binding
In default configuration (http/port 8083/8084) everything worked.
I placed an apache reverseproxy in front of the z-way-gateway that manages tls and secures the connection.
But now I’m getting this error messages:
2017-12-27 14:25:23.612 [INFO ] [b.core.service.AbstractActiveService] - HTTP Refresh Service has been started
2017-12-27 14:25:25.133 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2017-12-27 14:25:25.326 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2017-12-27 14:25:26.472 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2017-12-27 14:25:26.673 [INFO ] [netatmo.handler.NetatmoBridgeHandler] - Initializing API Connection and scheduling token refresh every 5400s
2017-12-27 14:37:50.062 [INFO ] [nding.zway.handler.ZWayBridgeHandler] - Initializing Z-Way bridge ...
2017-12-27 14:37:50.084 [WARN ] [eclipse.jetty.servlet.ServletHandler] -
javax.servlet.ServletException: org.glassfish.jersey.server.ContainerException: java.lang.NoClassDefFoundError: org/eclipse/jetty/util/ssl/SslContextFactory
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:489) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [85:org.eclipse.jetty.security:9.3.22.v20171030]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.Server.handle(Server.java:534) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [90:org.eclipse.jetty.util:9.3.22.v20171030]
Caused by: org.glassfish.jersey.server.ContainerException: java.lang.NoClassDefFoundError: org/eclipse/jetty/util/ssl/SslContextFactory
at org.glassfish.jersey.servlet.internal.ResponseWriter.rethrow(ResponseWriter.java:278) ~[?:?]
at org.glassfish.jersey.servlet.internal.ResponseWriter.failure(ResponseWriter.java:260) ~[?:?]
at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:509) ~[178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:334) ~[178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) ~[177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) ~[177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) ~[177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) ~[177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) ~[177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) ~[177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) ~[178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) ~[178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) ~[175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
... 31 more
Caused by: java.lang.NoClassDefFoundError: org/eclipse/jetty/util/ssl/SslContextFactory
at de.fh_zwickau.informatik.sensor.ZWayApiHttp.<init>(ZWayApiHttp.java:106) ~[?:?]
at org.openhab.binding.zway.handler.ZWayBridgeHandler.initialize(ZWayBridgeHandler.java:284) ~[?:?]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.handleConfigurationUpdate(BaseThingHandler.java:173) ~[?:?]
at org.openhab.binding.zway.handler.ZWayBridgeHandler.handleConfigurationUpdate(ZWayBridgeHandler.java:334) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.updateConfiguration(ThingRegistryImpl.java:94) ~[?:?]
at org.eclipse.smarthome.io.rest.core.internal.thing.ThingResource.updateConfiguration(ThingResource.java:413) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) ~[178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) ~[178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) ~[178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) ~[178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) ~[178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) ~[178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) ~[178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) ~[178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) ~[178:org.glassfish.jersey.core.jersey-server:2.22.2]
... 31 more
2017-12-27 14:37:50.104 [WARN ] [org.eclipse.jetty.server.HttpChannel] - //openhab.example.com/rest/things/zway:zwayServer:395ad739/config
javax.servlet.ServletException: javax.servlet.ServletException: org.glassfish.jersey.server.ContainerException: java.lang.NoClassDefFoundError: org/eclipse/jetty/util/ssl/SslContextFactory
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:88) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
Caused by: javax.servlet.ServletException: org.glassfish.jersey.server.ContainerException: java.lang.NoClassDefFoundError: org/eclipse/jetty/util/ssl/SslContextFactory
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:489) ~[?:?]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) ~[?:?]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) ~[?:?]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[?:?]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) ~[?:?]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) ~[?:?]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) ~[?:?]
... 13 more
at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:509) ~[?:?]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:334) ~[?:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) ~[?:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) ~[?:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) ~[?:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) ~[?:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) ~[?:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) ~[?:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) ~[?:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) ~[?:?]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) ~[?:?]
... 13 more
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) ~[?:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) ~[?:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) ~[?:?]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) ~[?:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) ~[?:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) ~[?:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) ~[?:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) ~[?:?]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) ~[?:?]
... 13 more
I tried deleting cache/tmp.
How to solve ths problem?
Thank you
Flotastisch
