- Platform information:
- Hardware: CPUArchitecture/RAM/storage Intel i3 / 16 GB
- OS: what OS is used and which version Ubuntu 20.04
- Java Runtime Environment: which java platform is used and what version OpenJDK 11
- openHAB version: 3.0.0
- Issue of the topic:
Just installed OPenHAB and added MQTT broker as a “thing”, Says “Online”. Now confused and need a nudge in the right direction…
I have a Sonoff ZB Bride (coordinator) flashed with Tasmota 9.2, a Bliyzwolf BW-SHP13 plugg and a Trådfri Switch type E1743.
Coordinator, plug and remote works fine from konsol on coordinator. I have set up a group and can issue command and also direct com swith to plug.
Where do I go from here to make openHAB aware of the plugg and switch?
I want a switch that publish { “device”:“Plug1”, “send”:{“Power”:“Off”} } or { “device”:“Plug1”, “send”:{“Power”:“On”} } to the cmnd/tasmota_E36F05/ZBsend/ topic.
What do I have to do? Set up a thing? With a channel? An Item?
Thanks!
