Zcombo smoke/CO detectors not sending z-wave command when triggered from smoke
I’ve kicked off a build with the updates, so hopefully it will be ready in an hour or so…
The build is done. However… I would recommend against installing a snapshot release after and including build 1427.
See this post. Depending on what DateTime methods you use in your rules, those rules could be badly broken by a recent ESH change.
If you want to pick up a new zwave binding, and don’t want to install a snapshot for the above reason, use the method explained in this post.
FYI, the issue with the DateTime methods in rules was fixed in build 1430.
I updated the binding and everything is working perfectly! After setting up the new channels and writing some new rules, my ZCombo alarms now send my phone the correct notifications based on what triggered the alarm (CO, Smoke, Test button). :+1:
Thank you!
