I recently added a ZEN20 Z-Wave Plus Power Strip , and after adding this device the start frames just keep on adding up. Is this normal ?
and in the logs this keeps repeating constantly:
07-Jun-2019 16:01:53.313 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 17: Application Command Request (ALIVE:DONE)
07-Jun-2019 16:01:53.314 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 17: resetResendCount initComplete=true isDead=false
07-Jun-2019 16:01:53.314 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 17: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
07-Jun-2019 16:01:53.314 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 17: Incoming command class COMMAND_CLASS_SWITCH_BINARY, endpoint 7
07-Jun-2019 16:01:53.315 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 17: SECURITY not supported
07-Jun-2019 16:01:53.315 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 17: Received COMMAND_CLASS_SWITCH_BINARY V1 SWITCH_BINARY_REPORT
07-Jun-2019 16:01:53.315 [DEBUG] [rotocol.commandclass.ZWaveBinarySwitchCommandClass] - NODE 17: Switch Binary report, value = 255
07-Jun-2019 16:01:53.316 [TRACE] [ab.binding.zwave.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
07-Jun-2019 16:01:53.316 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
07-Jun-2019 16:01:53.316 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Got a value event from Z-Wave network, endpoint=7, command class=COMMAND_CLASS_SWITCH_BINARY, value=255
07-Jun-2019 16:01:53.317 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:switch_binary, cmdClass=COMMAND_CLASS_SWITCH_BINARY, endpoint=0
07-Jun-2019 16:01:53.317 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:switch_binary, cmdClass=COMMAND_CLASS_BASIC, endpoint=0
07-Jun-2019 16:01:53.318 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:meter_watts, cmdClass=COMMAND_CLASS_METER, endpoint=0
07-Jun-2019 16:01:53.318 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:meter_kwh, cmdClass=COMMAND_CLASS_METER, endpoint=0
07-Jun-2019 16:01:53.318 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:meter_reset, cmdClass=COMMAND_CLASS_METER, endpoint=0
07-Jun-2019 16:01:53.319 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:alarm_power, cmdClass=COMMAND_CLASS_ALARM, endpoint=0
07-Jun-2019 16:01:53.319 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:switch_binary1, cmdClass=COMMAND_CLASS_SWITCH_BINARY, endpoint=1
07-Jun-2019 16:01:53.319 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:switch_binary1, cmdClass=COMMAND_CLASS_BASIC, endpoint=1
07-Jun-2019 16:01:53.320 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:meter_watts1, cmdClass=COMMAND_CLASS_METER, endpoint=1
07-Jun-2019 16:01:53.320 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:meter_kwh1, cmdClass=COMMAND_CLASS_METER, endpoint=1
07-Jun-2019 16:01:53.320 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:meter_reset1, cmdClass=COMMAND_CLASS_METER, endpoint=1
07-Jun-2019 16:01:53.321 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:switch_binary2, cmdClass=COMMAND_CLASS_SWITCH_BINARY, endpoint=2
07-Jun-2019 16:01:53.321 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:switch_binary2, cmdClass=COMMAND_CLASS_BASIC, endpoint=2
07-Jun-2019 16:01:53.321 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:meter_watts2, cmdClass=COMMAND_CLASS_METER, endpoint=2
07-Jun-2019 16:01:53.322 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:meter_kwh2, cmdClass=COMMAND_CLASS_METER, endpoint=2
07-Jun-2019 16:01:53.322 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:meter_reset2, cmdClass=COMMAND_CLASS_METER, endpoint=2
07-Jun-2019 16:01:53.322 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:switch_binary3, cmdClass=COMMAND_CLASS_SWITCH_BINARY, endpoint=3
07-Jun-2019 16:01:53.323 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:switch_binary3, cmdClass=COMMAND_CLASS_BASIC, endpoint=3
07-Jun-2019 16:01:53.323 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:meter_watts3, cmdClass=COMMAND_CLASS_METER, endpoint=3
07-Jun-2019 16:01:53.323 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:meter_kwh3, cmdClass=COMMAND_CLASS_METER, endpoint=3
07-Jun-2019 16:01:53.324 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:meter_reset3, cmdClass=COMMAND_CLASS_METER, endpoint=3
07-Jun-2019 16:01:53.324 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:switch_binary4, cmdClass=COMMAND_CLASS_SWITCH_BINARY, endpoint=4
07-Jun-2019 16:01:53.324 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:switch_binary4, cmdClass=COMMAND_CLASS_BASIC, endpoint=4
07-Jun-2019 16:01:53.325 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:meter_watts4, cmdClass=COMMAND_CLASS_METER, endpoint=4
07-Jun-2019 16:01:53.325 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:meter_kwh4, cmdClass=COMMAND_CLASS_METER, endpoint=4
07-Jun-2019 16:01:53.325 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:meter_reset4, cmdClass=COMMAND_CLASS_METER, endpoint=4
07-Jun-2019 16:01:53.326 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:switch_binary5, cmdClass=COMMAND_CLASS_SWITCH_BINARY, endpoint=5
07-Jun-2019 16:01:53.326 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:switch_binary5, cmdClass=COMMAND_CLASS_BASIC, endpoint=5
07-Jun-2019 16:01:53.326 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:meter_watts5, cmdClass=COMMAND_CLASS_METER, endpoint=5
07-Jun-2019 16:01:53.327 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:meter_kwh5, cmdClass=COMMAND_CLASS_METER, endpoint=5
07-Jun-2019 16:01:53.327 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:meter_reset5, cmdClass=COMMAND_CLASS_METER, endpoint=5
07-Jun-2019 16:01:53.328 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:switch_binary6, cmdClass=COMMAND_CLASS_SWITCH_BINARY, endpoint=6
07-Jun-2019 16:01:53.328 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:switch_binary6, cmdClass=COMMAND_CLASS_BASIC, endpoint=6
07-Jun-2019 16:01:53.328 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:switch_binary7, cmdClass=COMMAND_CLASS_SWITCH_BINARY, endpoint=7
07-Jun-2019 16:01:53.329 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Updating channel state zwave:device:faff6fa0:node17:switch_binary7 to ON [OnOffType]
07-Jun-2019 16:01:53.329 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 17: Checking channel=zwave:device:faff6fa0:node17:switch_binary7, cmdClass=COMMAND_CLASS_BASIC, endpoint=7
07-Jun-2019 16:01:53.330 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 17: Commands processed 1.
07-Jun-2019 16:01:53.330 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 17: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@8d7f34.
07-Jun-2019 16:01:53.330 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
07-Jun-2019 16:01:53.331 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
07-Jun-2019 16:01:53.331 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
07-Jun-2019 16:01:53.331 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
the controller has the following after just a brief startup:
Start Frames
4157
trending_up
Frames Acknowledged
182
Any advice.
