Hello OpenHAB community.
today i’d like to share my sonos coordinator rule which, in combination with sonos coordinator widget, is able to control your sonos system without any configuration steps necessary (especially no fiddling with tons of items, no item naming conventions etc.)
The code for the rule as well as the code for the widget can be found on github: sonos-coordinator
Requirements:
- At least OpenHAB 3.2 or higher
- OpenHAB Sonos binding
- The JSScripting plugin needs to be installed
Installation
Just create a new file in the ./conf/automation/js
folder of your OpenHAB installation and paste the code from below into it (or download the file from the link above).
How it works
The rule will initialize itself as soon as it is copied into the correct destination folder. It will automatically search for all available sonos Things within the Openhab ThingRegistry. After the discovery, it will check all required channels of the Things for bound items. If a required channel is not yet bound to an item, the rule will automatically create a “proxy” item and bind it to the channel (although i prefer creating the items manually and adding them properly to the model of OpenHAB, you wouldn’t need to as the rule will create everything you need for the widget to run properly). Futhermore, the rule will create “proxy” items with informations for the widget, for controlling the zone volume, zone mute and grouping functionality of your sonos system as well as the required rules within OpenHAB to properly synchronize on state changes. If the rule should be removed from the ./conf/automation/js
, it will automatically delete all items and rules that have been created by the rule upon removal.
Code
const controllerGroupName = "SonosControllerGroup";
const proxyItemTagName = "SonosProxyItem";
const coordinatorProxyItemTagName = "SonosCoordinatorProxyItem";
const zoneVolumeProxyItemTagName = "ZoneVolume_SonosProxyItem";
const groupSwitcherItemTagName = "GroupSwitcher_SonosProxyItem";
const zoneMuteProxyItemTagName = "ZoneMute_SonosProxyItem";
const channelIds = {
playerChannelId : "control",
albumChannelId : "currentalbum",
artistChannelId: "currentartist",
coverArtChannelId : "currentalbumart",
coverArtChannelUrlId : "currentalbumarturl",
titleChannelId : "currenttitle",
masterChannelId : "coordinator",
localMasterChannelId : "localcoordinator",
volumeChannelId : "volume",
zoneNameChannelId : "zonename",
addChannelId : "add",
removeChannelId : "remove",
standaloneChannelId : "standalone",
trackChannelId : "currenttrack",
muteChannelId : "mute",
favoriteChannelId: "favorite"
const services = {
channelLinkRegistry : osgi.getService("org.openhab.core.thing.link.ItemChannelLinkRegistry"),
thingRegistry : osgi.getService("org.openhab.core.thing.ThingRegistry"),
managedLinkProvider : osgi.getService("org.openhab.core.thing.link.ManagedItemChannelLinkProvider")
const constants = {
sonosIdentifierString : "RINCON_"
const ItemChannelLink = Java.type("org.openhab.core.thing.link.ItemChannelLink");
var createItemChannelLink = function(itemName, channel) {
console.log("Linking item " + itemName + " to channel " + channel.getUID());
var link = new ItemChannelLink(itemName, channel.getUID());
services.managedLinkProvider.add(link);
console.log("Link: " + link);
var getChannelUidFromItem = function(item){
let foundChannels = Array.from(services.channelLinkRegistry.getBoundChannels(item.name));
return foundChannels.find(channel => channel.getThingUID().getId().includes(constants.sonosIdentifierString));
var getItemBoundToChannel = function(thingUidString, channelIdString){
var item = items.getItemsByTag().find(item => {
let channelUid = getChannelUidFromItem(item);
if(channelUid === undefined) return null;
return channelUid.getThingUID().getId() === thingUidString && channelUid.getId() === channelIdString;
if(item === undefined){
return null;
return item;
var getAllSonosThings = function(){
let foundThings = Array.from(services.thingRegistry.getAll());
return foundThings.filter(thing => thing.getUID().getId().startsWith(constants.sonosIdentifierString));
var itemExists = function(itemName){
return items.getItem(itemName, true) !== null;
class SonosCoordinator{
constructor(){
this.group = itemExists(controllerGroupName) ? items.getItem(controllerGroupName) : items.addItem(controllerGroupName, "Group", undefined, undefined, undefined, new Array(proxyItemTagName));
this.allSonosThings = getAllSonosThings().map(thing => new SonosThing(thing, this.onZoneVolumeChanged, this.onVolumeChanged));
var coordinatorTriggerArray = new Array();
var volumeTriggerArray = new Array();
var zoneVolumeTriggerArray = new Array();
var groupSwitchTriggerArray = new Array();
var muteTriggerArray = new Array();
var zoneMuteTriggerArray = new Array();
this.allSonosThings.forEach(sonosThing => {
coordinatorTriggerArray.push(triggers.ItemStateChangeTrigger(sonosThing.allThingItemNames[channelIds.localMasterChannelId]));
coordinatorTriggerArray.push(triggers.ItemStateChangeTrigger(sonosThing.allThingItemNames[channelIds.masterChannelId]));
muteTriggerArray.push(triggers.ItemStateChangeTrigger(sonosThing.allThingItemNames[channelIds.muteChannelId]));
volumeTriggerArray.push(triggers.ItemStateChangeTrigger(sonosThing.allThingItemNames[channelIds.volumeChannelId]));
zoneVolumeTriggerArray.push(triggers.ItemCommandTrigger(sonosThing.zoneVolumeItemName));
groupSwitchTriggerArray.push(triggers.ItemCommandTrigger(sonosThing.groupSwitcherItemName));
zoneMuteTriggerArray.push(triggers.ItemCommandTrigger(sonosThing.zoneMuteItemName));
this.updatingItems = {};
if(!itemExists(coordinatorProxyItemTagName)){
items.addItem(coordinatorProxyItemTagName, "String", undefined, new Array(controllerGroupName), undefined, new Array(proxyItemTagName, coordinatorProxyItemTagName));
this.updateCoordinatorProxyItems();
rules.JSRule({
name: "A coordinator item has changed",
description: "This rule refreshes the coordinator proxy items, when a coordinator item has changed",
triggers: coordinatorTriggerArray,
execute: data => {
console.log("Entering rule A coordinator item has changed for item " + data.itemName);
rules.JSRule({
name: "A zone volume proxy item received a command",
description: "Adjusts the volume of volume items in the group according to the delta of the zone volume proxy item",
triggers: zoneVolumeTriggerArray,
execute: data => {
console.log("Rule Zone volume proxy " + data.itemName + "received command started!");
var changedThing = this.getSonosThingFromItemName(data.itemName);
if(changedThing === undefined){
console.log("Did not find a thing for the changed item " + data.itemName + ". Therefor the rule will be ignored!");
return;
this.onZoneVolumeChanged(changedThing);
rules.JSRule({
name: "A volume item received a command",
description: "Adjusts the volume of the zone volume in the group according to the delta of the volume item",
triggers: volumeTriggerArray,
execute: data => {
console.log("Rule Volume item " + data.itemName + " received command started!");
return;
this.onVolumeChanged(changedThing);
rules.JSRule({
name: "A group switch item received a command",
description: "Rearanges the sonos group according to the configuration of the group switch item",
triggers: groupSwitchTriggerArray,
execute: data => {
console.log("Rule group switch item " + data.itemName + " received command started!");
return;
this.onGroupSwitched(changedThing);
rules.JSRule({
name: "A mute item received a command",
description: "Synchronizes the mute state with of zone mute state",
triggers: muteTriggerArray,
execute: data => {
console.log("Rule mute item " + data.itemName + " received command started!");
return;
this.onMuteChanged(changedThing);
rules.JSRule({
name: "A zone mute item received a command",
description: "Synchronizes the mute the zone mute state with all sone mute items",
triggers: zoneMuteTriggerArray,
execute: data => {
console.log("Rule zone mute item " + data.itemName + " received command started!");
return;
this.onGroupMuteChanged(changedThing);
onZoneVolumeChanged(sonosThing){
console.log("Zone volume for " + sonosThing.thing.getLabel() + " changed.");
if(this.wasOwnUpdate(sonosThing.zoneVolumeItemName)){
return;
if(!sonosThing.isZoneCoordinator()){
console.log("Returning from onZoneVolumeChanged as the thing is not a zone coordinator!");
return
var allGroupedThings = this.allSonosThings.filter(st => st.getMasterId() === sonosThing.thing.getUID().getId());
var groupedAvgVolume = 0.0;
allGroupedThings.forEach(gt => {
groupedAvgVolume += gt.getVolume();
groupedAvgVolume = groupedAvgVolume / allGroupedThings.length;
var delta = Math.round(sonosThing.getZoneVolume() - groupedAvgVolume);
console.log("Groupe avg volume is " + groupedAvgVolume + ". Calculated delta is " + delta);
if(delta === 0){
return;
allGroupedThings.forEach(st => {
var newValue = st.getVolume() + delta;
if(newValue > 100.0){
newValue = 100.0;
if(newValue < 0.0){
newValue = 0.0;
this.setNewVolume(st.allThingItemNames[channelIds.volumeChannelId], newValue)
onVolumeChanged(sonosThing){
console.log("Volume for " + sonosThing.thing.getLabel() + " changed.");
if(this.wasOwnUpdate(sonosThing.allThingItemNames[channelIds.volumeChannelId])){
return;
var masterThing = this.allSonosThings.find(st => st.thing.getUID().getId() === sonosThing.getMasterId());
var newVolume = 0.0;
var allSonosThingsInGroup = this.allSonosThings.filter(st => st.getMasterId() === masterThing.thing.getUID().getId());
allSonosThingsInGroup.forEach(st => newVolume += st.getVolume());
newVolume = Math.round(newVolume / allSonosThingsInGroup.length);
this.setNewVolume(masterThing.zoneVolumeItemName, newVolume);
onGroupSwitched(sonosThing){
var groupConfigurationString = items.getItem(sonosThing.groupSwitcherItemName).state;
console.log("A group configuration has changed: " + groupConfigurationString);
console.log("Skipping group changes as thing " + sonosThing.thing.getLabel() + " is not a zone coordinator!");
return;
var groupConfiguration =JSON.parse(groupConfigurationString);
Object.keys(groupConfiguration).forEach(configKey =>{
var groupThing = this.allSonosThings.find(st => st.thing.getUID().getId() === configKey);
if(groupThing === undefined){
return;
if(groupConfiguration[configKey]){
console.log("Adding " + groupThing.thing.getLabel() + " to group of " + sonosThing.thing.getLabel());
items.getItem(sonosThing.allThingItemNames[channelIds.addChannelId]).sendCommand(groupThing.thing.getUID().getId());
else{
console.log("Removing " + groupThing.thing.getLabel() + " from group of " + sonosThing.thing.getLabel());
items.getItem(groupThing.allThingItemNames[channelIds.standaloneChannelId]).sendCommand("ON");
onMuteChanged(sonosThing){
console.log("Mute for " + sonosThing.thing.getLabel() + " changed.");
if(this.wasOwnUpdate(sonosThing.allThingItemNames[channelIds.muteChannelId])){
console.log("returning as the muted/unmuted sonos device was triggered by this rule");
return;
var muteValue = this.getZoneMuteState(masterThing);
this.setMute(masterThing.zoneMuteItemName, muteValue);
getZoneMuteState(sonosThing){
var unmutedThingFound = false;
this.getAllGroupedSonosThings(sonosThing).forEach(gt => {
if(unmutedThingFound){
return;
unmutedThingFound = items.getItem(gt.allThingItemNames[channelIds.muteChannelId]).state === "OFF";
return unmutedThingFound ? "OFF" : "ON";
onGroupMuteChanged(sonosThing){
console.log("returning as the muted/unmuted sonos device is not a zone coordinator");
return;
if(this.wasOwnUpdate(sonosThing.zoneMuteItemName)){
console.log("returning as the muted/unmuted sonos zone device was triggered by this rule");
return;
var groupedThings = this.getAllGroupedSonosThings(sonosThing);
var muteState = items.getItem(sonosThing.zoneMuteItemName).state;
console.log("Setting mute state to " + muteState + " of all grouped sonos players of from zone coordinator " +sonosThing.thing.getLabel());
groupedThings.forEach(gt => {
var muteItemName = gt.allThingItemNames[channelIds.muteChannelId];
this.setMute(muteItemName, muteState);
setMute(itemName, muteValue){
var item = items.getItem(itemName);
if(item.state === muteValue){
return;
this.updatingItems[itemName] = muteValue;
console.log("Setting mute of item " + item.name + " to " + muteValue);
item.sendCommand(muteValue);
getSonosThingFromItemName(itemName){
return this.allSonosThings.find(sonosThing => Object.keys(sonosThing.allThingItemNames).some(key => sonosThing.allThingItemNames[key] === itemName) || sonosThing.groupSwitcherItemName === itemName || sonosThing.zoneVolumeItemName === itemName || sonosThing.zoneMuteItemName === itemName);
wasOwnUpdate(itemName){
if(this.updatingItems.hasOwnProperty(itemName)){
console.log("Removing " + itemName + " from updating items as its target and returning true for wasOwnUpdate");
delete this.updatingItems[itemName];
return true;
return false;
setNewVolume(itemName, newVolume){
var itemVolume = parseFloat(items.getItem(itemName).state);
if(itemVolume === newVolume){
return;
console.log("Setting "+ itemName +" to new volume " + newVolume);
this.updatingItems[itemName] = newVolume;
items.getItem(itemName).sendCommand(newVolume);
getSonosCoordinatorProxyItemName(sonosThing){
return sonosThing.thing.getUID().getId() + "_" + coordinatorProxyItemTagName;
getAllGroupedSonosThings(sonosThing){
return Array.from(sonosThing);
return this.allSonosThings.filter(st => st.getMasterId() === sonosThing.thing.getUID().getId() || st.thing.getUID().getId() === sonosThing.thing.getUID().getId());
updateCoordinatorProxyItems(){
var allCoordinators = this.allSonosThings.filter(sonosThing => sonosThing.isZoneCoordinator());
var coordinatorArray = new Array();
allCoordinators.forEach(sonosCoordinator => {
var groupedSonosThings = Array.from(this.getAllGroupedSonosThings(sonosCoordinator));
var coordinatorProxyItem = {};
coordinatorProxyItem.id = sonosCoordinator.thing.getUID().getId();
coordinatorProxyItem.zoneVolumeItemName = sonosCoordinator.zoneVolumeItemName;
coordinatorProxyItem.artistItemName = sonosCoordinator.allThingItemNames[channelIds.artistChannelId];
coordinatorProxyItem.titelItemName = sonosCoordinator.allThingItemNames[channelIds.titleChannelId];
coordinatorProxyItem.albumItemName = sonosCoordinator.allThingItemNames[channelIds.albumChannelId];
coordinatorProxyItem.coverArtItemName = sonosCoordinator.allThingItemNames[channelIds.coverArtChannelId];
coordinatorProxyItem.coverArtUrlItemName = sonosCoordinator.allThingItemNames[channelIds.coverArtChannelUrlId];
coordinatorProxyItem.playerItemName = sonosCoordinator.allThingItemNames[channelIds.playerChannelId];
coordinatorProxyItem.trackItemName = sonosCoordinator.allThingItemNames[channelIds.trackChannelId];
coordinatorProxyItem.muteItemName = sonosCoordinator.allThingItemNames[channelIds.muteChannelId];
coordinatorProxyItem.zoneMuteItemName = sonosCoordinator.zoneMuteItemName;
coordinatorProxyItem.groupSwitcherItemName = sonosCoordinator.groupSwitcherItemName;
coordinatorProxyItem.favoriteItemName = sonosCoordinator.allThingItemNames[channelIds.favoriteChannelId];
var zoneItemNames = new Array();
var volumeItemsInformation = new Array();
var groupedItemsInformation = new Array();
var groupedThingDeleteVars = new Array();
var groupVolume = 0.0;
groupedThingDeleteVars.push(sonosCoordinator.thing.getUID().getId() + "_group");
groupedThingDeleteVars.push(sonosCoordinator.thing.getUID().getId() + "_volume");
groupedThingDeleteVars.push(sonosCoordinator.thing.getUID().getId() + "_favorite");
groupedSonosThings.forEach(gt => {
zoneItemNames.push(items.getItem(gt.allThingItemNames[channelIds.zoneNameChannelId]).state)
var gtVolumeInformation = {};
gtVolumeInformation.zoneItemName = gt.allThingItemNames[channelIds.zoneNameChannelId];
gtVolumeInformation.volumeItemName = gt.allThingItemNames[channelIds.volumeChannelId];
gtVolumeInformation.muteItemName = gt.allThingItemNames[channelIds.muteChannelId];
volumeItemsInformation.push(gtVolumeInformation);
groupVolume = groupVolume + gt.getVolume();
if(groupedSonosThings.length > 0)
groupVolume = Math.round(groupVolume / groupedSonosThings.length);
items.getItem(sonosCoordinator.zoneVolumeItemName).postUpdate(groupVolume);
items.getItem(sonosCoordinator.zoneMuteItemName).postUpdate(this.getZoneMuteState(sonosCoordinator));
var allOtherSonosItems = this.allSonosThings.filter(ast => {
return ast.thing.getUID().getId() !== sonosCoordinator.thing.getUID().getId();
var idCounter = 0;
allOtherSonosItems.forEach(aosi => {
var groupedItemInformation = {};
groupedItemInformation.isInGroup = groupedSonosThings.some(gst => aosi.getMasterId() === gst.thing.getUID().getId());
groupedItemInformation.name = items.getItem(aosi.allThingItemNames[channelIds.zoneNameChannelId]).state
groupedItemInformation.thingUid = aosi.thing.getUID().getId();
groupedItemInformation.id = "itemInfo_" + idCounter;
groupedItemsInformation.push(groupedItemInformation);
groupedThingDeleteVars.push(aosi.thing.getUID().getId());
idCounter++;
coordinatorProxyItem.zoneNames = zoneItemNames.join(" + ");
coordinatorProxyItem.volumeInformation = volumeItemsInformation;
coordinatorProxyItem.groupedItemsInformation = groupedItemsInformation;
coordinatorProxyItem.groupedThingDeleteVars = groupedThingDeleteVars;
coordinatorArray.push(coordinatorProxyItem);
items.getItem(coordinatorProxyItemTagName).sendCommand(JSON.stringify(coordinatorArray));
class SonosThing{
constructor(thing, onZoneVolumeChanged, onVolumeChanged){
this.onZoneVolumeChanged = onZoneVolumeChanged;
this.onVolumeChanged = onVolumeChanged;
this.thing = thing;
this.allThingItemNames = {};
Object.keys(channelIds).forEach(key => {
var foundItem = getItemBoundToChannel(thing.getUID().getId(), channelIds[key]);
if(foundItem === null){
var channel = thing.getChannel(channelIds[key]);
var itemType = channel.getAcceptedItemType();
this.allThingItemNames[channelIds[key]] = items.addItem(thing.getUID().getId() + "_" + channel.getLabel() + "_" + proxyItemTagName, itemType, undefined, new Array(controllerGroupName), undefined, new Array(proxyItemTagName)).name;
createItemChannelLink(this.allThingItemNames[channelIds[key]], channel)
else{
this.allThingItemNames[channelIds[key]] = foundItem.name;
this.volumeItemName = this.allThingItemNames[channelIds.volumeChannelId];
var zoneVolumeItemName = thing.getUID().getId() + "_" + zoneVolumeProxyItemTagName;
var zoneVolumeItemType = thing.getChannel(channelIds.volumeChannelId).getAcceptedItemType();
var zoneVolumeItem = itemExists(zoneVolumeItemName) ? items.getItem(zoneVolumeItemName) : items.addItem(zoneVolumeItemName, zoneVolumeItemType, undefined, undefined, undefined, new Array(proxyItemTagName, zoneVolumeProxyItemTagName));
this.zoneVolumeItemName = zoneVolumeItem.name;
var groupSwichterItemName = thing.getUID().getId() + "_" + groupSwitcherItemTagName;
var groupSwitcherItem = itemExists(groupSwichterItemName) ? items.getItem(groupSwichterItemName) : items.addItem(groupSwichterItemName, "String", undefined, undefined, undefined, new Array(proxyItemTagName, groupSwitcherItemTagName));
this.groupSwitcherItemName = groupSwitcherItem.name;
var zoneMuteItemName = thing.getUID().getId() + "_" + zoneMuteProxyItemTagName;
var zoneMuteItemType = thing.getChannel(channelIds.muteChannelId).getAcceptedItemType();
var zoneMuteItem = itemExists(zoneMuteItemName) ? items.getItem(zoneMuteItemName) : items.addItem(zoneMuteItemName, zoneMuteItemType, undefined, undefined, undefined, new Array(proxyItemTagName, zoneMuteProxyItemTagName));
this.zoneMuteItemName = zoneMuteItem.name;
isZoneCoordinator(){
var thingName = this.allThingItemNames[channelIds.localMasterChannelId];
var localMasterItem = items.getItem(thingName);
return localMasterItem.state == "ON";
getMasterId(){
var masterString = items.getItem(this.allThingItemNames[channelIds.masterChannelId]).state;
if(!masterString.includes(constants.sonosIdentifierString)){
return this.thing.getUID().getId();
return masterString;
getVolume(){
var volume = parseFloat(items.getItem(this.allThingItemNames[channelIds.volumeChannelId]).state);
return isNaN(volume) ? 0.0 : volume;
getZoneVolume(){
var zoneVolume = parseFloat(items.getItem(this.zoneVolumeItemName).state);
return isNaN(zoneVolume) ? 0.0 : zoneVolume;
var coordinator = null;
scriptLoaded = function () {
console.log("Sonos coordinator rule load");
loadedDate = Date.now();
coordinator = new SonosCoordinator();
scriptUnloaded = function () {
console.log("Sonos coordinator rule unload");
var foundItems = Array.from(items.getItemsByTag(proxyItemTagName).map(item => item.name));
foundItems.forEach(foundItem => {
let foundLinks = Array.from(services.channelLinkRegistry.getLinks(foundItem));
foundLinks.forEach(foundLink => {
console.log("Removing link " + foundLink);
services.managedLinkProvider.remove(foundLink.getUID());
console.log("Removing proxy item:" + foundItem)
try {
items.removeItem(foundItem);
} catch (e) {
