I have 35 Zigbee devices on my network which include Phillips HUE, Sonoff and 3A Smart Home DE
I am attempting to add a new device from 3A Smart Home which is a 4-gang Light switch (relays not dimmers), unfortunately the Zigbee binding only creates 4 Dimmer channels.
It looks like the binding recreates the channels on each boot (so manually editing .json is out of the question)
I have been playing with openhab-cli console and the zigbee commands (there are some logs below), but I have the following question:
- Should the binding also add channels for a switch as there is an On_Off Cluster in the Profile
1 : Profile ZIGBEE_LIGHT_LINK
: Device Type ZLL_ON_OFF_LIGHT
-> BASIC
-> IDENTIFY
-> GROUPS
-> SCENES
-> ON_OFF
-> LEVEL_CONTROL
-> 0x1000
<- BASIC
<- ON_OFF
**EDIT: I just noticed that the item is actually updating with either 0 or 100
Operating the Item using the Dimmer Slider, turns it on at “1” or greater.
It only turns OFF when the slider hits “0” **
I have edited the Item and made it a Switch and now it is working as expected.
(I swear I had tried that before and it was not working)…
> 2022-07-30 18:26:02.500 [DEBUG] [converter.ZigBeeConverterSwitchLevel] - E29F0111E00BFDB0: ZigBee attribute reports ZclAttribute [cluster=On/Off, id=0, name=On Off, dataType=BOOLEAN, lastValue=false, lastReportTime=Sat Jul 30 18:26:02 AEST 2022, implemented=false]
> 2022-07-30 18:26:02.500 [DEBUG] [converter.ZigBeeBaseChannelConverter] - E29F0111E00BFDB0: Channel zigbee:device:a72b450e:e29f0111e00bfdb0:E29F0111E00BFDB0_1_dimmer updated to OFF
> 2022-07-30 18:26:02.500 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - E29F0111E00BFDB0: Updating ZigBee channel state zigbee:device:a72b450e:e29f0111e00bfdb0:E29F0111E00BFDB0_1_dimmer to OFF
> 2022-07-30 18:26:02.500 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker reset for handler with thingUID=zigbee:device:a72b450e:e29f0111e00bfdb0
> 2022-07-30 18:26:02.501 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker cancelled task for thingUID=zigbee:device:a72b450e:e29f0111e00bfdb0
> 2022-07-30 18:26:02.501 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker scheduled task for thingUID=zigbee:device:a72b450e:e29f0111e00bfdb0 in 1830 seconds
> 2022-07-30 18:26:03.654 [DEBUG] [converter.ZigBeeConverterSwitchLevel] - E29F0111E00BFDB0: ZigBee attribute reports ZclAttribute [cluster=On/Off, id=0, name=On Off, dataType=BOOLEAN, lastValue=true, lastReportTime=Sat Jul 30 18:26:03 AEST 2022, implemented=false]
> 2022-07-30 18:26:03.655 [DEBUG] [converter.ZigBeeBaseChannelConverter] - E29F0111E00BFDB0: Channel zigbee:device:a72b450e:e29f0111e00bfdb0:E29F0111E00BFDB0_1_dimmer updated to 100
> 2022-07-30 18:26:03.655 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - E29F0111E00BFDB0: Updating ZigBee channel state zigbee:device:a72b450e:e29f0111e00bfdb0:E29F0111E00BFDB0_1_dimmer to 100
> 2022-07-30 18:26:03.656 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker reset for handler with thingUID=zigbee:device:a72b450e:e29f0111e00bfdb0
> 2022-07-30 18:26:03.656 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker cancelled task for thingUID=zigbee:device:a72b450e:e29f0111e00bfdb0
> 2022-07-30 18:26:03.656 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker scheduled task for thingUID=zigbee:device:a72b450e:e29f0111e00bfdb0 in 1830 seconds
Below are outputs from various commands
openhab> zigbee nodes
Total known nodes in network: 35
Network Addr IEEE Address Logical Type State EP Profile Device Type Manufacturer Model
0 0000 CCCCCCFFFEA3581D COORDINATOR ONLINE
1078 0436 086BD7FFFE5B71BE ROUTER ONLINE 1 ZIGBEE_HOME_AUTOMATION DIMMABLE_LIGHT 3A Smart Home DE LXN56-DS27LX1.3
1092 0444 0017880108F3913F END_DEVICE ONLINE 1 ZIGBEE_LIGHT_LINK ZLL_NON_COLOR_SCENE_CONTROLLER Philips RWL021
2 ZIGBEE_HOME_AUTOMATION SIMPLE_SENSOR
4315 10DB 086BD7FFFE5CF16E ROUTER ONLINE 1 ZIGBEE_HOME_AUTOMATION DIMMABLE_LIGHT 3A Smart Home DE LXN56-DS27LX1.3
12787 31F3 00124B0022665CF2 END_DEVICE UNKNOWN 1 ZIGBEE_HOME_AUTOMATION ON_OFF_SWITCH eWeLink WB01
13186 3382 086BD7FFFE5D89C8 ROUTER ONLINE 1 ZIGBEE_HOME_AUTOMATION DIMMABLE_LIGHT 3A Smart Home DE LXN56-DS27LX1.3
13309 33FD 804B50FFFEB0D94B ROUTER ONLINE 1 ZIGBEE_HOME_AUTOMATION ON_OFF_LIGHT SONOFF 01MINIZB
242 ZIGBEE_GREEN_POWER 0061
17602 44C2 086BD7FFFE5B7C7D ROUTER ONLINE 1 ZIGBEE_HOME_AUTOMATION DIMMABLE_LIGHT 3A Smart Home DE LXN56-DS27LX1.3
19528 4C48 086BD7FFFE404546 ROUTER ONLINE 1 ZIGBEE_HOME_AUTOMATION DIMMABLE_LIGHT 3A Smart Home DE LXN56-DS27LX1.3
19860 4D94 086BD7FFFE405D10 ROUTER ONLINE 1 ZIGBEE_HOME_AUTOMATION DIMMABLE_LIGHT 3A Smart Home DE LXN56-DS27LX1.3
23244 5ACC 804B50FFFEB7213A ROUTER ONLINE 1 ZIGBEE_HOME_AUTOMATION ON_OFF_LIGHT SONOFF 01MINIZB
29028 7164 0017880108F4BD03 END_DEVICE ONLINE 1 ZIGBEE_LIGHT_LINK ZLL_NON_COLOR_SCENE_CONTROLLER Philips RWL021
30400 76C0 00124B00226896CE END_DEVICE UNKNOWN 1 ZIGBEE_HOME_AUTOMATION IAS_ZONE eWeLink MS01
31054 794E 001788010867BFC0 END_DEVICE ONLINE 1 ZIGBEE_LIGHT_LINK ZLL_ON_OFF_SENSOR Philips SML001
2 ZIGBEE_HOME_AUTOMATION OCCUPANCY_SENSOR
31167 79BF 086BD7FFFE4040C4 ROUTER ONLINE 1 ZIGBEE_HOME_AUTOMATION DIMMABLE_LIGHT 3A Smart Home DE LXN56-DS27LX1.3
33111 8157 086BD7FFFE40450A ROUTER ONLINE 1 ZIGBEE_HOME_AUTOMATION DIMMABLE_LIGHT 3A Smart Home DE LXN56-DS27LX1.3
34453 8695 0017880108F23736 END_DEVICE ONLINE 1 ZIGBEE_LIGHT_LINK ZLL_NON_COLOR_SCENE_CONTROLLER Philips RWL021
37590 92D6 00124B0022665921 END_DEVICE UNKNOWN 1 ZIGBEE_HOME_AUTOMATION ON_OFF_SWITCH eWeLink WB01
41623 A297 00124B0022677FA2 ROUTER ONLINE 1 ZIGBEE_HOME_AUTOMATION MAINS_POWER_OUTLET SONOFF BASICZBR3
46550 B5D6 00124B0022E9F184 END_DEVICE ONLINE 1 ZIGBEE_HOME_AUTOMATION IAS_ZONE eWeLink MS01
47398 B926 00124B0022658782 END_DEVICE UNKNOWN 1 ZIGBEE_HOME_AUTOMATION ON_OFF_SWITCH eWeLink WB01
49703 C227 001788010867CDDD END_DEVICE ONLINE 1 ZIGBEE_LIGHT_LINK ZLL_ON_OFF_SENSOR Philips SML001
49738 C24A 000D6FFFFE941C83 ROUTER ONLINE 1 ZIGBEE_HOME_AUTOMATION DIMMABLE_LIGHT 3A Smart Home DE LXN60-DS27LX1.3
50963 C713 001788010867CCA3 END_DEVICE ONLINE 1 ZIGBEE_LIGHT_LINK ZLL_ON_OFF_SENSOR Philips SML001
51856 CA90 086BD7FFFE3F8BB0 ROUTER ONLINE 1 ZIGBEE_HOME_AUTOMATION DIMMABLE_LIGHT 3A Smart Home DE LXN56-DS27LX1.3
54561 D521 00124B00226A0C09 END_DEVICE ONLINE 1 ZIGBEE_HOME_AUTOMATION IAS_ZONE eWeLink MS01
55137 D761 E29F0111E00BFDB0 ROUTER ONLINE 1 ZIGBEE_LIGHT_LINK ZLL_ON_OFF_LIGHT 3A Smart Home DE LXN-4S27LX1.0
2 ZIGBEE_LIGHT_LINK ZLL_ON_OFF_LIGHT
3 ZIGBEE_LIGHT_LINK ZLL_ON_OFF_LIGHT
4 ZIGBEE_LIGHT_LINK ZLL_ON_OFF_LIGHT
56963 DE83 804B50FFFEB56A2E ROUTER ONLINE 1 ZIGBEE_HOME_AUTOMATION ON_OFF_LIGHT SONOFF 01MINIZB
58316 E3CC 00124B0022EBC4F3 END_DEVICE ONLINE 1 ZIGBEE_HOME_AUTOMATION IAS_ZONE eWeLink MS01
60971 EE2B 00124B0022682A2E END_DEVICE UNKNOWN 1 ZIGBEE_HOME_AUTOMATION IAS_ZONE eWeLink MS01
61014 EE56 804B50FFFEB722DE ROUTER ONLINE 1 ZIGBEE_HOME_AUTOMATION ON_OFF_LIGHT SONOFF 01MINIZB
64007 FA07 086BD7FFFE5B8255 ROUTER ONLINE 1 ZIGBEE_HOME_AUTOMATION DIMMABLE_LIGHT 3A Smart Home DE LXN56-DS27LX1.3
64129 FA81 0017880108F4BCBC END_DEVICE ONLINE 1 ZIGBEE_LIGHT_LINK ZLL_NON_COLOR_SCENE_CONTROLLER Philips RWL021
64575 FC3F 086BD7FFFE5AF068 ROUTER ONLINE 1 ZIGBEE_HOME_AUTOMATION DIMMABLE_LIGHT 3A Smart Home DE LXN56-DS27LX1.3
64587 FC4B 804B50FFFEB7201A ROUTER ONLINE 1 ZIGBEE_HOME_AUTOMATION ON_OFF_LIGHT SONOFF 01MINIZB
openhab> **zigbee node 55137**
IEEE Address : E29F0111E00BFDB0
Network Address : 55137
Node Descriptor : NodeDescriptor [apsFlags=0, bufferSize=80, complexDescriptorAvailable=false, manufacturerCode=0000, logicalType=ROUTER, serverCapabilities=[], incomingTransferSize=80, outgoingTransferSize=80, userDescriptorAvailable=false, frequencyBands=[FREQ_2400_MHZ], macCapabilities=[FULL_FUNCTION_DEVICE, MAINS_POWER, RECEIVER_ON_WHEN_IDLE], extendedEndpointListAvailable=false, extendedSimpleDescriptorListAvailable=false, stackCompliance=20]
Power Descriptor : PowerDescriptor [currentPowerMode=RECEIVER_ON_IDLE, availablePowerSources=[MAINS], currentPowerSource=MAINS, powerLevel=FULL]
Associations : []
Endpoints :
-> BASIC
-> IDENTIFY
-> GROUPS
-> SCENES
-> ON_OFF
-> LEVEL_CONTROL
-> 0x1000
<- BASIC
<- ON_OFF
2 : Profile ZIGBEE_LIGHT_LINK
-> BASIC
-> IDENTIFY
-> GROUPS
-> SCENES
-> ON_OFF
-> LEVEL_CONTROL
-> 0x1000
<- BASIC
<- ON_OFF
3 : Profile ZIGBEE_LIGHT_LINK
-> BASIC
-> IDENTIFY
-> GROUPS
-> SCENES
-> ON_OFF
-> LEVEL_CONTROL
-> 0x1000
<- BASIC
<- ON_OFF
4 : Profile ZIGBEE_LIGHT_LINK
-> BASIC
-> IDENTIFY
-> GROUPS
-> SCENES
-> ON_OFF
-> LEVEL_CONTROL
-> 0x1000
<- BASIC
<- ON_OFF
Neighbors :
Routes :
openhab> zigbee bindtable 55137
Binding table for node 55137 [E29F0111E00BFDB0]
Src Address | Dest Address | Group | Mode | Cluster
E29F0111E00BFDB0/1 | CCCCCCFFFEA3581D/1 | | Address | 0008:LEVEL_CONTROL
E29F0111E00BFDB0/2 | CCCCCCFFFEA3581D/1 | | Address | 0008:LEVEL_CONTROL
E29F0111E00BFDB0/3 | CCCCCCFFFEA3581D/1 | | Address | 0008:LEVEL_CONTROL
E29F0111E00BFDB0/4 | CCCCCCFFFEA3581D/1 | | Address | 0006:ON_OFF
E29F0111E00BFDB0/3 | CCCCCCFFFEA3581D/1 | | Address | 0006:ON_OFF
E29F0111E00BFDB0/4 | CCCCCCFFFEA3581D/1 | | Address | 0008:LEVEL_CONTROL
E29F0111E00BFDB0/2 | CCCCCCFFFEA3581D/1 | | Address | 0006:ON_OFF
E29F0111E00BFDB0/1 | CCCCCCFFFEA3581D/1 | | Address | 0006:ON_OFF
openhab> zigbee endpoint 55137/1
Endpoint : 1
Device Profile : 0xC05E, ZIGBEE_LIGHT_LINK
Device Type : 0x0000, ZLL_ON_OFF_LIGHT
Device Version : 1
Input Clusters : (Server)
0000 Basic
- APS Security disabled
S 0 r-- UNSIGNED_8_BIT_INTEGER ZCL Version Sat Jul 30 16:57:29 AEST 2022 3
S 1 r-- UNSIGNED_8_BIT_INTEGER Application Version Sat Jul 30 16:57:29 AEST 2022 1
S 2 r-- UNSIGNED_8_BIT_INTEGER Stack Version
S 3 r-- UNSIGNED_8_BIT_INTEGER HW Version Sat Jul 30 16:57:29 AEST 2022 1
S 4 r-- CHARACTER_STRING Manufacturer Name Sat Jul 30 16:57:29 AEST 2022 3A Smart Home DE
S 5 r-- CHARACTER_STRING Model Identifier Sat Jul 30 16:57:29 AEST 2022 LXN-4S27LX1.0
S 6 r-- CHARACTER_STRING Date Code Sat Jul 30 16:57:29 AEST 2022 20220512
S 7 r-- ENUMERATION_8_BIT Power Source
S 8 r-- ENUMERATION_8_BIT Generic Device Class
S 9 r-- ENUMERATION_8_BIT Generic Device Type
S 10 r-- CHARACTER_STRING Product Code
S 11 r-- CHARACTER_STRING Product URL
S 16 rw- CHARACTER_STRING Location Description
S 17 rw- ENUMERATION_8_BIT Physical Environment
S 18 rw- BOOLEAN Device Enabled
S 19 rw- BITMAP_8_BIT Alarm Mask
S 20 rw- BITMAP_8_BIT Disable Local Config
S 16384 r-- CHARACTER_STRING SW Build ID Sat Jul 30 16:57:29 AEST 2022 1.2.0
0003 Identify
S 0 rw- UNSIGNED_16_BIT_INTEGER Identify Time
0004 Groups
S 0 r-- BITMAP_8_BIT Name Support
0005 Scenes
S 0 r-- UNSIGNED_8_BIT_INTEGER Scene Count
S 1 r-- UNSIGNED_8_BIT_INTEGER Current Scene
S 2 r-- UNSIGNED_16_BIT_INTEGER Current Group
S 3 r-- BOOLEAN Scene Valid
S 4 r-- BITMAP_8_BIT Name Support
S 5 r-- IEEE_ADDRESS Last Configured By
0006 On/Off
S 0 r-s BOOLEAN On Off Sat Jul 30 17:08:28 AEST 2022 false
S 16384 r-- BOOLEAN Global Scene Control
S 16385 rw- UNSIGNED_16_BIT_INTEGER On Time
S 16386 rw- UNSIGNED_16_BIT_INTEGER Off Wait Time
S 16387 rw- ENUMERATION_8_BIT Start Up On Off
0008 Level Control
S 0 r-s UNSIGNED_8_BIT_INTEGER Current Level Sat Jul 30 17:07:10 AEST 2022 254
S 1 r-- UNSIGNED_16_BIT_INTEGER Remaining Time
S 2 r-- UNSIGNED_8_BIT_INTEGER Minimum Level
S 3 r-- UNSIGNED_8_BIT_INTEGER Maximum Level
S 4 r-s UNSIGNED_16_BIT_INTEGER Current Frequency
S 5 r-- UNSIGNED_16_BIT_INTEGER Minimum Frequency
S 6 r-- UNSIGNED_16_BIT_INTEGER Maximum Frequency
S 15 r-- BITMAP_8_BIT Options
S 16 rw- UNSIGNED_16_BIT_INTEGER On Off Transition Time
S 17 rw- UNSIGNED_8_BIT_INTEGER On Level
S 18 rw- UNSIGNED_16_BIT_INTEGER On Transition Time
S 19 rw- UNSIGNED_16_BIT_INTEGER Off Transition Time
S 20 rw- UNSIGNED_16_BIT_INTEGER Default Move Rate
S 16384 rw- UNSIGNED_8_BIT_INTEGER Start Up Current Level
1000
Output Clusters : (Client)
0000 Basic
0006 On/Off
Groups Supported : 10
Groups Configured : 0
manually turning the light on , then running the following command
openhab> zigbee read 55137/1 0x0006 0x0
Reading endpoint D761/1, cluster server cluster On/Off (0006), attributes On Off
Response for cluster 0x0006
Attribute 0 On Off BOOLEAN true
openhab> zigbee read 55137/1 0x0008 0x0
Reading endpoint D761/1, cluster server cluster Level Control (0008), attributes Current Level
Response for cluster 0x0008
Attribute 0 Current Level UNSIGNED_8_BIT_INTEGER 196
manually turning the light off , then running the following command
Attribute 0 On Off BOOLEAN false
openhab> zigbee read 55137/2 0x0008 0x0
Reading endpoint D761/2, cluster server cluster Level Control (0008), attributes Current Level
Attribute 0 Current Level UNSIGNED_8_BIT_INTEGER 0
