if the Bulbs are connected to the HUE bridge (2.0) I can set inside the app a “power on behavior”.
This select what the light should do when powered on by a classic light switch or after a power outage.
Can i set this also without the Bridge using the Zigbee Binding or something similar?
It depends on the bulb. If the bulb supports this, then it can be possible, but currently the zigbee binding only supports this for On/Off bulbs (not dimmable bulbs or color bulbs). I’m currently adding this for color bulbs and it will be in the binding soon and I will also add this for dimmers.
However, the bulb needs to also support this in the standard zigbee way, and that’s not the case with all bulbs.
thanks a lot for that update.
I own lots of bulbs that are on CCT (Tuneable white).
I hope the new Binding will support them too.
If you need a tester I could assist.
