- Platform information: Openhabian with RP3B
I have a Philips Hue Dimmer Switch RWL021 with a Nortek Security & Control HUSBZB-1 Usb Stick. The Hue Switch becomes offline after 12 hours approximately. The only way to make it operational again is to put it in a setup mode and do the pairing again. Does anyone have the same problem?
I also have hue sensors , an ikea outlet plug, and some ikea bulbs. The other zigbee devices never go offline.
I borrowed a xiaomi sensor from a friend and I notice that the same problem occurs also with xiaomi sensors but I read at the forum that the xiaomi sensors are not very compatible with zigbee
I am new to openhab and I might be looking it from the wrong angle but I have noticed that
- the zigbee devices that are plugged into an outlet do not have the same problem
- the battery devices that exchange frequently info with the coordinator do not have the same problem
- The problem occurs only with devices that remain idle for longer period of time (devices with smaller batteries)
is the problem the longer idle times or is ti something else
