I recently installed a new usb device on my raspberry pi and it seems to have changed the port bindings. My zigbee port changed from /dev/ttyUSB0 to /dev/ttyUSB1.
I tried updating the thing configuration but it keeps reporting
zigbee:coordinator_ember:48ed089711’ changed from UNKNOWN to OFFLINE: Failed to open communications port.
How do I fix this? Do I need to delete all my zigbee items/things and start over?
You get the numbers to use by running command lsusb in this examplebelow it would be: 0403:6001
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 004: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
Bus 002 Device 003: ID 0bda:2838 Realtek Semiconductor Corp. RTL2838 DVB-T
Bus 002 Device 002: ID 1941:8021 Dream Link WH1080 Weather Station / USB Missile Launcher
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 0627:0001 Adomax Technology Co., Ltd QEMU USB Tablet
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
After you add the file restart the udev process.
sudo systemctl restart udev.service
You will tell if it has worked by running:
ls -l /dev/rfxcom
lrwxrwxrwx 1 root root 7 Jul 8 11:03 /dev/rfxcom → ttyUSB1
It shows that /dev/rfxcom is really /dev/ttyUSB1
You would then put /dev/rfxcom into your thing serial port instead of the real port name.
