Hi All,
After getting my zigbee binding to work i migrated my tradfri bulbs from the gateway to the zigbee binding via the bitron stick. All is well and bulbs respond instantly to command send thru the binding.
One of the bulbs seems to be a lot less bright though when connected to the binding. It looses brightness as soon as a command is sent by the binding.
My White scale bulbs seem fine, the color ones drop in brightness:
The bulb is correctly detected as:
TRADFRI bulb E27 CWS opal 600lm
Once i reset the bulb it goes back to full blast. And when initially paired it stays there. As soon as a color change is sent or the bulbs brightness is adjusted down and up again it never goes back to full power.
The only commands i can send to the bulb is a percentage. And when sending 100 the bulb only seems to go up to 400 - 500 lumens (estimate. i guess its at least 20% less strong).
Is there anything i can do to get these bulbs to go to their full protentional?
Thanks for your response!!
