Sure do, running for weeks without issues:
Telegesis, BJ 6711U (x2), BJ 6715U, BJ 6735, BJ 6735/01, BJ 6736 (x2), Tradfri
hi chris,
Yes finally bundles are gone into active state in my workspace. I am currently using eclipse
smarthome 0.10- SNAPSHOT. I have been set COM PORT in Paper UI. But CC2531MEK
Coordinator not goint to ONLINE State. I have connected CC2538 device to COM Port. I got error
in log files.
11:47:46.317 ERROR [safeCall-14] An error occurred while calling method 'ThingHandler.initialize()' on 'org.openhab.binding.zigbee.cc2531.handler.CC2531Handler@7d56725f': com/zsmartsystems/zigbee/ZigBeeKey
java.lang.NoClassDefFoundError: com/zsmartsystems/zigbee/ZigBeeKey
at org.openhab.binding.zigbee.handler.ZigBeeCoordinatorHandler.initialize(ZigBeeCoordinatorHandler.java:231) ~[?:?]
at org.openhab.binding.zigbee.cc2531.handler.CC2531Handler.initialize(CC2531Handler.java:45) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [123:org.eclipse.smarthome.core:0.10.0.201808211930]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [123:org.eclipse.smarthome.core:0.10.0.201808211930]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:?]
at java.lang.Thread.run(Thread.java:745) [?:?]
11:47:46.325 ERROR [safeCall-14] Exception occurred while initializing handler of thing 'zigbee:coordinator_cc2531:eb379b38': com/zsmartsystems/zigbee/ZigBeeKey
11:47:46.326 INFO [safeCall-12] 'zigbee:coordinator_cc2531:eb379b38' updated: UNINITIALIZED (HANDLER_INITIALIZING_ERROR): com/zsmartsystems/zigbee/ZigBeeKey
11:47:46.339 INFO [safeCall-14] 'zigbee:coordinator_cc2531:eb379b38' changed from INITIALIZING to UNINITIALIZED (HANDLER_INITIALIZING_ERROR): com/zsmartsystems/zigbee/ZigBeeKey
Anything I have left in configuration in PaperUI.
Best Regards,
Amar.
Probably you have some sort of incompatibility between the libraries (the com.zsmartsystems.zigbee
files) and the openhab binding bundles. The current binding is not compatible with the latest libraries - Iām waiting for this change to be merged into openHAB (the PRs were made a week or more back, so we just have to wait).
If you want to test with the latest sources, then as I suggested previously, using the console is a LOT easier as there are a lot less parts of the machine that you have to get working.
Can I use previous libraries (com.zsmartsystems.zigbee-1.1.0
files).
No - the current version that works with the binding is 1.0.14 I think. The changes were made in 1.1.0.
Currently am using OpenHAB zigbee bindings are 2.4.0.qualifier.
Can you please tell us which have to use.( OpenHAB zigbee bindings)
I just did.
If you want to use the binding, then you need to use the versions that are currently used with the binding. This is 1.0.14.
I continually recommend to you to use the console, but you do not want to do this and you make things a lot more complicated for yourself.
I suggest that we stop the discussion on this thread since it is not really related. If you require further help, letās discuss elsewhere.
Sorry about thatā¦ I will switch to console.
But really didnāt get understand console. If you give some information about that for me easy to learn.
How to access the console.
Please lets stop the discussion here. Please start another thread specific to your issue, but please try and ask specific questions - not just āgive me some informationā or āhow to access consoleā as I have already told you this yesterday!
You need to work through the issue and try and solve your problems. If you have specific questions, then Iām happy to try and answer them, but please be specific.
chris i am new to this zigbee console application environment . I didnāt get understand properly.So thatās why asking continuously. I followed the your suggestion. I tried my self, how to run zigbee console application. But unable to run console application. I saw doc here. Do you mean run the console application in Command Prompt. Initially i can work in console application.
Then I will start work with openhab bindings.
Yes - using the console is a LOT easier. There is a LOT less infrustructure required to get it working. openHAB required a lot of additional bundles and debugging the low level zigbee libraries from within OH is very difficult.
Please letās take this conversation to another thread. Please!
@chris
Is it possible to delete a thing which has been added but not fully discovered (meaning, itĀ“s unknow). I cant seem to remove this by deleting the thing. The binding/coordinator still announce it next time I run the discovery.
@chris would it be too much hassle to add this flag (or set it, or whatever), so I can test if thats whats needed for the Trust motion sensor? I cant get it to release the trigger.
(I just started all over again, but this time I will not try add any Xiaomi devices, just to see if it continues to run for more than 2 days. Sofar I have the Philips Hue motion sensor, Trust motion sensor and Osram plug added without any problems).
hi,
I use the following components:
- a CC2531 stick with CC2531ZNP-Pro-Secure_LinkKeyJoin (from Z-Stack_Home_1.2.2a)
- ZigBee Binding 2.3.0
- these two Xiaomi Aqara devices:
https://www.aliexpress.com/item/New-Updated-Xiaomi-Aqara-Door-Window-Sensor-Zigbee-Wireless-Connection-Smart-Mini-door-sensor-Work-With/32816037464.html?spm=a2g0s.9042311.0.0.67634c4d6hcrRN
and
https://www.aliexpress.com/item/New-Original-Xiaomi-Aqara-Temperature-Humidity-Sensor-Smart-Home-Device-Air-Pressure-Work-With-Android-IOS/32887275362.html?spm=a2g0s.9042311.0.0.67634c4d6hcrRN
Both devices are dicovered but without battery channel and the door/window sensor ist discovered as a switch not as a contact:
Can I do something or is it up to the devices and/or the binding?
There is probably nothing that you can do.
The binding searches for a set list of features - if the device doesnāt support those features, then you donāt get to see them.
It looks like the device is reporting a binary switch, so the binding provides a switch. It is not reporting the more standard sensors from what I see here.
hi Chris,
thank you for your awnser.
Ok I understand that the the devices reports that it is a binary switch -> so it is a switch.
Iāve tested the devices with the CC2531stick in IoBroker and there I have the battery status:
So it is really not supported by the device? (perhaps the list of supported feature is no āstandardā so itās not provided by the binding)
It looks like it should show both battery percent and also voltage. The binding does support both of these channels (assuming of course they are the standard attributes, but I guess they are).
However, if the device was not awake when the binding did the discovery, then it may not have received the responses it needed to decide that this channel was supported.
These sensors tend to just send the data periodically - it may be that IoBroker is just displaying what it receives where the binding needs to scan the device to find out in advance what channels to present in ESH/OH.
While the binding did the discovery I pressed the button on the device all 3 seconds.
I removed the thing and tried to discover it again. Thatās the output in the log:
2018-09-03 17:36:18.280 [DEBUG] [internal.ZigBeeNodeServiceDiscoverer] - 00124B0014D9DE5F: Node SVC Discovery running
2018-09-03 17:36:18.282 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementRoutingRequest [0/0 -> 0/0, cluster=0032, TID=75, startIndex=0]
2018-09-03 17:36:18.284 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=0/0, profile=0000, cluster=50, addressMode=DEVICE, radius=31, sequence=117, payload=00 00]
2018-09-03 17:36:18.421 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=0/0, profile=0000, cluster=32818, addressMode=null, radius=0, sequence=0, payload=00 00 00 00 00]
2018-09-03 17:36:18.423 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ManagementRoutingResponse [0/0 -> 0/0, cluster=8032, TID=NULL, status=SUCCESS, routingTableEntries=0, startIndex=0, routingTableList=[]]
2018-09-03 17:36:18.429 [DEBUG] [internal.ZigBeeNodeServiceDiscoverer] - 00124B0014D9DE5F: Node SVC Discovery ManagementRoutingRequest returned CommandResult [SUCCESS, ManagementRoutingResponse [0/0 -> 0/0, cluster=8032, TID=NULL, status=SUCCESS, routingTableEntries=0, startIndex=0, routingTableList=[]]]
2018-09-03 17:36:18.431 [DEBUG] [com.zsmartsystems.zigbee.ZigBeeNode ] - 00124B0014D9DE5F: Routing table NEW: []
2018-09-03 17:36:18.433 [DEBUG] [com.zsmartsystems.zigbee.ZigBeeNode ] - 00124B0014D9DE5F: Routing table OLD: []
2018-09-03 17:36:18.435 [DEBUG] [com.zsmartsystems.zigbee.ZigBeeNode ] - 00124B0014D9DE5F: Routing table unchanged
2018-09-03 17:36:18.436 [DEBUG] [internal.ZigBeeNodeServiceDiscoverer] - 00124B0014D9DE5F: Node SVC Discovery request ROUTES successful. Advanced to null.
2018-09-03 17:36:18.438 [DEBUG] [internal.ZigBeeNodeServiceDiscoverer] - 00124B0014D9DE5F: Node SVC Discovery running
2018-09-03 17:36:18.444 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=0/0, profile=0000, cluster=32818, addressMode=null, radius=0, sequence=0, payload=00 00 00 00 00]
2018-09-03 17:36:18.446 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ManagementRoutingResponse [0/0 -> 0/0, cluster=8032, TID=NULL, status=SUCCESS, routingTableEntries=0, startIndex=0, routingTableList=[]]
2018-09-03 17:36:18.448 [DEBUG] [internal.ZigBeeNodeServiceDiscoverer] - 00124B0014D9DE5F: Node SVC Discovery complete
2018-09-03 17:36:18.450 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - 00124B0014D9DE5F: Node 0 update
2018-09-03 17:36:18.453 [DEBUG] [bee.discovery.ZigBeeDiscoveryService] - 00124B0014D9DE5F: Discovery notification
2018-09-03 17:36:18.458 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Saving ZigBee network state: Start.
2018-09-03 17:36:18.556 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Saving ZigBee network state: Done.
2018-09-03 17:36:19.492 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=53963/1, destinationAddress=0/1, profile=0104, cluster=0, addressMode=null, radius=0, sequence=0, payload=1C 5F 11 03 0A 05 00 42 16 6C 75 6D 69 2E 73 65 6E 73 6F 72 5F 6D 61 67 6E 65 74 2E 61 71 32 01 FF 42 1D 01 21 BD 0B 03 28 1E 04 21 A8 01 05 21 2E 01 06 24 00 00 00 00 00 0A 21 00 00 64 10 01]
2018-09-03 17:36:19.494 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=true, direction=SERVER_TO_CLIENT, disableDefaultResponse=true, manufacturerCode=4447, sequenceNumber=3, commandId=10]
2018-09-03 17:36:19.496 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ReportAttributesCommand [Basic: 53963/1 -> 0/1, cluster=0000, TID=03, reports=[Attribute Report: attributeDataType=CHARACTER_STRING, attributeIdentifier=5, attributeValue=lumi.sensor_magnet.aq2, Attribute Report: attributeDataType=CHARACTER_STRING, attributeIdentifier=65281, attributeValue=!Ā½
2018-09-03 17:36:19.498 [DEBUG] [.zsmartsystems.zigbee.zcl.ZclCluster] - 53963/1: Unknown attribute 65281 in cluster 0
2018-09-03 17:36:20.716 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=53963/1, destinationAddress=0/1, profile=0104, cluster=0, addressMode=null, radius=0, sequence=0, payload=1C 5F 11 04 0A 05 00 42 16 6C 75 6D 69 2E 73 65 6E 73 6F 72 5F 6D 61 67 6E 65 74 2E 61 71 32 01 FF 42 1D 01 21 BD 0B 03 28 1E 04 21 A8 01 05 21 2E 01 06 24 00 00 00 00 00 0A 21 00 00 64 10 01]
2018-09-03 17:36:20.719 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=true, direction=SERVER_TO_CLIENT, disableDefaultResponse=true, manufacturerCode=4447, sequenceNumber=4, commandId=10]
2018-09-03 17:36:20.722 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ReportAttributesCommand [Basic: 53963/1 -> 0/1, cluster=0000, TID=04, reports=[Attribute Report: attributeDataType=CHARACTER_STRING, attributeIdentifier=5, attributeValue=lumi.sensor_magnet.aq2, Attribute Report: attributeDataType=CHARACTER_STRING, attributeIdentifier=65281, attributeValue=!Ā½
2018-09-03 17:36:20.725 [DEBUG] [.zsmartsystems.zigbee.zcl.ZclCluster] - 53963/1: Unknown attribute 65281 in cluster 0
2018-09-03 17:36:21.894 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=53963/1, destinationAddress=0/1, profile=0104, cluster=0, addressMode=null, radius=0, sequence=0, payload=1C 5F 11 05 0A 05 00 42 16 6C 75 6D 69 2E 73 65 6E 73 6F 72 5F 6D 61 67 6E 65 74 2E 61 71 32 01 FF 42 1D 01 21 BD 0B 03 28 1E 04 21 A8 01 05 21 2E 01 06 24 00 00 00 00 00 0A 21 00 00 64 10 01]
2018-09-03 17:36:21.898 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=true, direction=SERVER_TO_CLIENT, disableDefaultResponse=true, manufacturerCode=4447, sequenceNumber=5, commandId=10]
2018-09-03 17:36:21.901 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ReportAttributesCommand [Basic: 53963/1 -> 0/1, cluster=0000, TID=05, reports=[Attribute Report: attributeDataType=CHARACTER_STRING, attributeIdentifier=5, attributeValue=lumi.sensor_magnet.aq2, Attribute Report: attributeDataType=CHARACTER_STRING, attributeIdentifier=65281, attributeValue=!Ā½
2018-09-03 17:36:21.905 [DEBUG] [.zsmartsystems.zigbee.zcl.ZclCluster] - 53963/1: Unknown attribute 65281 in cluster 0
2018-09-03 17:36:23.959 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=53963/1, destinationAddress=0/1, profile=0104, cluster=0, addressMode=null, radius=0, sequence=0, payload=1C 5F 11 06 0A 05 00 42 16 6C 75 6D 69 2E 73 65 6E 73 6F 72 5F 6D 61 67 6E 65 74 2E 61 71 32 01 FF 42 1D 01 21 BD 0B 03 28 1E 04 21 A8 01 05 21 2E 01 06 24 00 00 00 00 00 0A 21 00 00 64 10 01]
2018-09-03 17:36:23.963 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=true, direction=SERVER_TO_CLIENT, disableDefaultResponse=true, manufacturerCode=4447, sequenceNumber=6, commandId=10]
2018-09-03 17:36:23.967 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ReportAttributesCommand [Basic: 53963/1 -> 0/1, cluster=0000, TID=06, reports=[Attribute Report: attributeDataType=CHARACTER_STRING, attributeIdentifier=5, attributeValue=lumi.sensor_magnet.aq2, Attribute Report: attributeDataType=CHARACTER_STRING, attributeIdentifier=65281, attributeValue=!Ā½
2018-09-03 17:36:23.972 [DEBUG] [.zsmartsystems.zigbee.zcl.ZclCluster] - 53963/1: Unknown attribute 65281 in cluster 0
2018-09-03 17:36:28.618 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=53963/1, destinationAddress=0/1, profile=0104, cluster=0, addressMode=null, radius=0, sequence=0, payload=1C 5F 11 07 0A 05 00 42 16 6C 75 6D 69 2E 73 65 6E 73 6F 72 5F 6D 61 67 6E 65 74 2E 61 71 32 01 FF 42 1D 01 21 BD 0B 03 28 1E 04 21 A8 01 05 21 2E 01 06 24 00 00 00 00 00 0A 21 00 00 64 10 01]
2018-09-03 17:36:28.619 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=true, direction=SERVER_TO_CLIENT, disableDefaultResponse=true, manufacturerCode=4447, sequenceNumber=7, commandId=10]
2018-09-03 17:36:28.621 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ReportAttributesCommand [Basic: 53963/1 -> 0/1, cluster=0000, TID=07, reports=[Attribute Report: attributeDataType=CHARACTER_STRING, attributeIdentifier=5, attributeValue=lumi.sensor_magnet.aq2, Attribute Report: attributeDataType=CHARACTER_STRING, attributeIdentifier=65281, attributeValue=!Ā½
2018-09-03 17:36:28.623 [DEBUG] [.zsmartsystems.zigbee.zcl.ZclCluster] - 53963/1: Unknown attribute 65281 in cluster 0
2018-09-03 17:36:29.691 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=53963/1, destinationAddress=0/1, profile=0104, cluster=0, addressMode=null, radius=0, sequence=0, payload=1C 5F 11 08 0A 05 00 42 16 6C 75 6D 69 2E 73 65 6E 73 6F 72 5F 6D 61 67 6E 65 74 2E 61 71 32 01 FF 42 1D 01 21 BD 0B 03 28 1E 04 21 A8 01 05 21 2E 01 06 24 00 00 00 00 00 0A 21 00 00 64 10 01]
2018-09-03 17:36:29.694 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=true, direction=SERVER_TO_CLIENT, disableDefaultResponse=true, manufacturerCode=4447, sequenceNumber=8, commandId=10]
2018-09-03 17:36:29.696 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ReportAttributesCommand [Basic: 53963/1 -> 0/1, cluster=0000, TID=08, reports=[Attribute Report: attributeDataType=CHARACTER_STRING, attributeIdentifier=5, attributeValue=lumi.sensor_magnet.aq2, Attribute Report: attributeDataType=CHARACTER_STRING, attributeIdentifier=65281, attributeValue=!Ā½
2018-09-03 17:36:29.699 [DEBUG] [.zsmartsystems.zigbee.zcl.ZclCluster] - 53963/1: Unknown attribute 65281 in cluster 0
2018-09-03 17:36:33.103 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=53963/1, destinationAddress=0/1, profile=0104, cluster=0, addressMode=null, radius=0, sequence=0, payload=1C 5F 11 09 0A 05 00 42 16 6C 75 6D 69 2E 73 65 6E 73 6F 72 5F 6D 61 67 6E 65 74 2E 61 71 32 01 FF 42 1D 01 21 BD 0B 03 28 1E 04 21 A8 01 05 21 2E 01 06 24 00 00 00 00 00 0A 21 00 00 64 10 01]
2018-09-03 17:36:33.106 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=true, direction=SERVER_TO_CLIENT, disableDefaultResponse=true, manufacturerCode=4447, sequenceNumber=9, commandId=10]
2018-09-03 17:36:33.109 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ReportAttributesCommand [Basic: 53963/1 -> 0/1, cluster=0000, TID=09, reports=[Attribute Report: attributeDataType=CHARACTER_STRING, attributeIdentifier=5, attributeValue=lumi.sensor_magnet.aq2, Attribute Report: attributeDataType=CHARACTER_STRING, attributeIdentifier=65281, attributeValue=!Ā½
2018-09-03 17:36:33.112 [DEBUG] [.zsmartsystems.zigbee.zcl.ZclCluster] - 53963/1: Unknown attribute 65281 in cluster 0
2018-09-03 17:36:41.218 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=53963/1, destinationAddress=0/1, profile=0104, cluster=0, addressMode=null, radius=0, sequence=0, payload=1C 5F 11 0A 0A 05 00 42 16 6C 75 6D 69 2E 73 65 6E 73 6F 72 5F 6D 61 67 6E 65 74 2E 61 71 32 01 FF 42 1D 01 21 BD 0B 03 28 1E 04 21 A8 01 05 21 2E 01 06 24 00 00 00 00 00 0A 21 00 00 64 10 01]
2018-09-03 17:36:41.219 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=true, direction=SERVER_TO_CLIENT, disableDefaultResponse=true, manufacturerCode=4447, sequenceNumber=10, commandId=10]
2018-09-03 17:36:41.221 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ReportAttributesCommand [Basic: 53963/1 -> 0/1, cluster=0000, TID=0A, reports=[Attribute Report: attributeDataType=CHARACTER_STRING, attributeIdentifier=5, attributeValue=lumi.sensor_magnet.aq2, Attribute Report: attributeDataType=CHARACTER_STRING, attributeIdentifier=65281, attributeValue=!Ā½
2018-09-03 17:36:41.223 [DEBUG] [.zsmartsystems.zigbee.zcl.ZclCluster] - 53963/1: Unknown attribute 65281 in cluster 0
2018-09-03 17:36:52.862 [DEBUG] [e.dongle.cc2531.ZigBeeDongleTiCc2531] - Unhandled ZToolPacket type 0x45cb
2018-09-03 17:37:06.653 [me.event.InboxRemovedEvent] - Discovery Result with UID 'zigbee:device:616d64f3:00158d0002286a02' has been removed.
2018-09-03 17:37:06.668 [DEBUG] [org.openhab.binding.zigbee ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.ConfigDescriptionProvider}={service.id=419, service.bundleid=238, service.scope=singleton} - org.openhab.binding.zigbee
2018-09-03 17:37:06.697 [DEBUG] [org.openhab.binding.zigbee ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.firmware.FirmwareUpdateHandler}={service.id=420, service.bundleid=238, service.scope=singleton} - org.openhab.binding.zigbee
2018-09-03 17:37:06.707 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 00158D0002286A02: Initializing ZigBee thing handler zigbee:device:616d64f3:00158d0002286a02
2018-09-03 17:37:06.709 [hingStatusInfoChangedEvent] - 'zigbee:device:616d64f3:00158d0002286a02' changed from UNINITIALIZED to INITIALIZING
2018-09-03 17:37:06.715 [hingStatusInfoChangedEvent] - 'zigbee:device:616d64f3:00158d0002286a02' changed from INITIALIZING to OFFLINE
2018-09-03 17:37:06.717 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 00158D0002286A02: Coordinator status changed to ONLINE.
2018-09-03 17:37:06.720 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 00158D0002286A02: Coordinator is ONLINE. Starting device initialisation.
2018-09-03 17:37:06.723 [DEBUG] [bee.internal.ZigBeeNetworkDiscoverer] - 00158D0002286A02: NWK Discovery starting node rediscovery
2018-09-03 17:37:06.725 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: NetworkAddressRequest [0/0 -> 65533/0, cluster=0000, TID=76, ieeeAddr=00158D0002286A02, requestType=0, startIndex=0]
2018-09-03 17:37:06.728 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=65533/0, profile=0000, cluster=0, addressMode=DEVICE, radius=31, sequence=118, payload=00 02 6A 28 02 00 8D 15 00 00 00]
2018-09-03 17:37:06.741 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 00158D0002286A02: Start initialising ZigBee Thing handler
2018-09-03 17:37:06.744 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 00158D0002286A02: Checking endpoint 1 channels
2018-09-03 17:37:06.750 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 00158D0002286A02: Created 1 channels
2018-09-03 17:37:06.753 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 00158D0002286A02: Updating thing definition as channels have changed from [] to [zigbee:device:616d64f3:00158d0002286a02:00158D0002286A02_1_switch_onoff]
2018-09-03 17:37:06.829 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 00158D0002286A02: Initializing channel zigbee:device:616d64f3:00158d0002286a02:00158D0002286A02_1_switch_onoff with org.openhab.binding.zigbee.internal.converter.ZigBeeConverterSwitchOnoff@934127
2018-09-03 17:37:06.830 [me.event.ThingUpdatedEvent] - Thing 'zigbee:device:616d64f3:00158d0002286a02' has been updated.
2018-09-03 17:37:06.834 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: BindRequest [0/0 -> 53963/0, cluster=0021, TID=77, srcAddress=00158D0002286A02, srcEndpoint=1, bindCluster=6, dstAddrMode=3, dstAddress=00124B0014D9DE5F, dstEndpoint=1]
2018-09-03 17:37:06.840 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=53963/0, profile=0000, cluster=33, addressMode=DEVICE, radius=31, sequence=119, payload=00 02 6A 28 02 00 8D 15 00 01 06 00 03 5F DE D9 14 00 4B 12 00 01]
2018-09-03 17:37:06.989 [nt.FirmwareStatusInfoEvent] - Firmware status of thing zigbee:device:616d64f3:00158d0002286a02 changed to UNKNOWN.
2018-09-03 17:37:08.704 [DEBUG] [e.dongle.cc2531.ZigBeeDongleTiCc2531] - Unhandled ZToolPacket type 0x45a1
2018-09-03 17:37:08.711 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=53963/0, destinationAddress=0/0, profile=0000, cluster=32801, addressMode=null, radius=0, sequence=0, payload=00 00]
2018-09-03 17:37:08.715 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: BindResponse [53963/0 -> 0/0, cluster=8021, TID=NULL, status=SUCCESS]
2018-09-03 17:37:08.728 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ConfigureReportingCommand [On/Off: 0/0 -> 53963/1, cluster=0006, TID=78, records=[AttributeReportingConfigurationRecord: [attributeDataType=BOOLEAN, attributeIdentifier=0, direction=0, minimumReportingInterval=1, maximumReportingInterval=7200]]]
2018-09-03 17:37:08.730 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=false, direction=CLIENT_TO_SERVER, disableDefaultResponse=false, manufacturerCode=0, sequenceNumber=120, commandId=6]
2018-09-03 17:37:08.732 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0/1, destinationAddress=53963/1, profile=0104, cluster=6, addressMode=DEVICE, radius=31, sequence=120, payload=00 78 06 00 00 00 10 01 00 20 1C]
2018-09-03 17:37:12.549 [DEBUG] [e.dongle.cc2531.ZigBeeDongleTiCc2531] - Unhandled ZToolPacket type 0x45c9
2018-09-03 17:37:16.866 [DEBUG] [bee.internal.ZigBeeNetworkDiscoverer] - 00158D0002286A02: NWK Discovery node rediscovery request failed. Wait before retry.
2018-09-03 17:37:18.369 [DEBUG] [.zsmartsystems.zigbee.zcl.ZclCluster] - readSync request: ZclAttribute [cluster=ON_OFF, id=0, name=OnOff, dataType=BOOLEAN, lastValue=true, lastReportTime=Mon Sep 03 17:35:39 CEST 2018]
2018-09-03 17:37:18.369 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: NetworkAddressRequest [0/0 -> 65533/0, cluster=0000, TID=79, ieeeAddr=00158D0002286A02, requestType=0, startIndex=0]
2018-09-03 17:37:18.372 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ReadAttributesCommand [On/Off: 0/0 -> 53963/1, cluster=0006, TID=7A, identifiers=[0]]
2018-09-03 17:37:18.373 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=65533/0, profile=0000, cluster=0, addressMode=DEVICE, radius=31, sequence=121, payload=00 02 6A 28 02 00 8D 15 00 00 00]
2018-09-03 17:37:18.376 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=false, direction=CLIENT_TO_SERVER, disableDefaultResponse=false, manufacturerCode=0, sequenceNumber=122, commandId=0]
2018-09-03 17:37:18.379 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0/1, destinationAddress=53963/1, profile=0104, cluster=6, addressMode=DEVICE, radius=31, sequence=122, payload=00 7A 00 00 00]
2018-09-03 17:37:28.511 [DEBUG] [bee.internal.ZigBeeNetworkDiscoverer] - 00158D0002286A02: NWK Discovery node rediscovery request failed. Wait before retry.
2018-09-03 17:37:28.645 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 00158D0002286A02: Channel initialisation complete
2018-09-03 17:37:28.648 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 00158D0002286A02: ZigBee node property discovery start
2018-09-03 17:37:28.652 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 00158D0002286A02: ZigBee node property discovery using 53963/1
2018-09-03 17:37:28.655 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 00158D0002286A02: ZigBee node property discovery complete: {zigbee_logicaltype=END_DEVICE, zigbee_powerlevel=FULL, modelId=lumi.sensor_magnet.aq2, zigbee_networkaddress=53963, zigbee_powersource=DISPOSABLE_BATTERY, zigbee_stkversion=2, zigbee_datecode=20161128, zigbee_zclversion=1, vendor=LUMI, zigbee_powermode=RECEIVER_ON_IDLE, zigbee_powersources=[DISPOSABLE_BATTERY], hardwareVersion=2}
2018-09-03 17:37:28.668 [me.event.ThingUpdatedEvent] - Thing 'zigbee:device:616d64f3:00158d0002286a02' has been updated.
2018-09-03 17:37:28.675 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementBindRequest [0/0 -> 53963/0, cluster=0033, TID=7B, startIndex=0]
2018-09-03 17:37:28.677 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=53963/0, profile=0000, cluster=51, addressMode=DEVICE, radius=31, sequence=123, payload=00 00]
2018-09-03 17:37:30.014 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: NetworkAddressRequest [0/0 -> 65533/0, cluster=0000, TID=7C, ieeeAddr=00158D0002286A02, requestType=0, startIndex=0]
2018-09-03 17:37:30.018 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=65533/0, profile=0000, cluster=0, addressMode=DEVICE, radius=31, sequence=124, payload=00 02 6A 28 02 00 8D 15 00 00 00]
2018-09-03 17:37:38.808 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 00158D0002286A02: Error getting binding table
2018-09-03 17:37:38.818 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 00158D0002286A02: Polling initialised at 60220ms
2018-09-03 17:37:38.822 [hingStatusInfoChangedEvent] - 'zigbee:device:616d64f3:00158d0002286a02' changed from OFFLINE to ONLINE
2018-09-03 17:37:38.821 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 00158D0002286A02: Done initialising ZigBee Thing handler
2018-09-03 17:37:40.152 [DEBUG] [bee.internal.ZigBeeNetworkDiscoverer] - 00158D0002286A02: NWK Discovery node rediscovery request failed. Wait before retry.
2018-09-03 17:37:41.655 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: NetworkAddressRequest [0/0 -> 65533/0, cluster=0000, TID=7D, ieeeAddr=00158D0002286A02, requestType=0, startIndex=0]
2018-09-03 17:37:41.657 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=65533/0, profile=0000, cluster=0, addressMode=DEVICE, radius=31, sequence=125, payload=00 02 6A 28 02 00 8D 15 00 00 00]
2018-09-03 17:37:46.071 [DEBUG] [internal.ZigBeeNodeServiceDiscoverer] - 00158D0002320B4F: Node SVC Discovery running
2018-09-03 17:37:46.078 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementLqiRequest [0/0 -> 30442/0, cluster=0031, TID=7E, startIndex=0]
2018-09-03 17:37:46.084 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigB
Iād need to see the full log to know whatās happening - sorry. This is missing a lot of information.
@chris I got the ZigBee sniffer now (CC2531).
Unfortunately most traffic is shown as plain IEEE 802.15.4 traffic in WireShark when using ccsniffpiper, which I guess is not really useful to you?
