chris
(Chris Jackson)
February 10, 2019, 1:19pm
1928
Unfortunately the logs don’t help too much. In general, the events log is of no use for debugging, and while the openhab log file is normally useful (if debug information has been added?), in this case it is short and only shows that the port can’t be opened.
Recommended steps -:
Ensure that you enable debug logging (see the bottom of the ZigBee binding doc)
Once debug logging is enabled, then restart the binding and periodically wake up the device (eg let’s say wake it up every 5 seconds for a couple of minutes - just so that we know it is awake ). I suspect with this device, this is done by pressing a button on the device.
Check if it is still not working as the restart may make it start working as it will reinitialise the bindings and reporting configuration
Provide this log (it may be large so you may need to dump it in dropbox or something similar)
Provide the network.xml file from the {userdata}/zigbee folder
chris
(Chris Jackson)
February 10, 2019, 1:34pm
1929
I’ve just updated the low level ZigBee libraries. This fixes an important bug (thanks @puzzle-star ) so it would be work updating to the latest version (1.1.10) using @5ivers super upgrade script .
For those feeling a little more adventurous, you might like to try the snapshot version (1.1.11-SNAPSHOT). This has the same bug fix and enhancements as 1.1.10, but additionally has the first cut of a new transaction manager. This is intended to ultimately improve the sending of messages to devices by queuing frames and only releasing messages as required. This should help reduce problems associated with sending too many broadcasts at once, or sending messages to a device too quickly. This is still WIP, and will hopefully also add some more features such as prioritisation, but I’d welcome any comments from users to see if it at least is no worse than the current implementation
TedCorrell
(Ted Correll)
February 10, 2019, 4:12pm
1930
Thanks Chris,
I have enabled debugging per the ZigBee binding doc, I restated all the bundles that had ZigBee in their names and pushed the button on the device every few seconds for a couple minutes. I checked to see if anything changed, and saved the log and network.xml. There are 3 of them in the Zigbee folder, 2 are really small, I’ve uploaded the biggest, and most recently updated to Dropbox , along with the log file. Before posting, I just rechecked the Things page, and their status is “UNINITIALIZED - HANDLER_INITIALIZING_ERROR” and looking at each device, it still doesn’t have humidity as a channel.
5iver
(Scott Rushworth)
February 10, 2019, 4:50pm
1931
chris:
I upgraded the binding and libraries, but when the binding was starting I got an error that the serial port was already in use. Restarting the binding didn’t help, but restarting OH got it running. I’ve never seen this before after an update… maybe just my setup or a one time glitch. We’ll see next time I update.
As for the libraries, everything appears to be functioning so far!
chris
(Chris Jackson)
February 10, 2019, 4:52pm
1932
Thanks @5iver . The serial port issue shouldn’t be related to the changes, so I’m gonna put it down to a one off (even if it happens again ).
Let me know if you notice any difference (better or worse) - even if it’s just a feeling…
5iver
(Scott Rushworth)
February 10, 2019, 5:29pm
1933
The serial issue is repeatable.
I also had garbage jars come down… but maybe a build was running.
chris
(Chris Jackson)
February 10, 2019, 5:57pm
1934
Strange - looking at the list of changes in the binding, nothing should impact the serial port -:
What was the previous version you were using?
5iver
(Scott Rushworth)
February 10, 2019, 6:07pm
1935
I just recently posted the versions here…
I use the same controller and have 17 of these bulbs. They used to be flaky, then very flaky, but now they are working pretty well. Every now and then, they will no longer respond and will need to be power cycled or deleted, reset, and rediscovered. Be sure to configure the controller for software flow control, and set the Power Mode to Boost, and the Transmit Power to High. I also have the Mesh Update Period and Child Aging Timeout set to 1 day. If you leave the bulb in the inbox for a while, …
It will be interesting if others see this, or if it is just my setup. I had been using a compiled version of nrjavaserial to get around lock issues, but took that out about a month ago, IIRC. And I thought I’d upgraded a few times since then. I have some more investigation to do… actually, this will be a good one for my wife to look at!
polo89
(Polo89)
February 11, 2019, 5:28pm
1936
Hello Chris,
no the dimmer isn’t working with the zigbee binding, here is a log.
|18:11:44.<small>810</small>|38703|[<small>RX 84 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18577)|
|18:11:44.<small>820</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18578)|
|18:11:46.<small>829</small>|38703|[<small>RX 87 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18588)|
|18:11:46.<small>853</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18589)|
|18:11:47.<small>614</small>|38703|[<small>TX 9E ReadAttributesCommand cluster=ON_OFF **identifiers** =[0]</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18590)|
|18:11:49.<small>867</small>|38703|[<small>RX 8E ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18603)|
|18:11:49.<small>893</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18604)|
|18:11:51.<small>858</small>|38703|[<small>RX 91 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18610)|
|18:11:51.<small>878</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18611)|
|18:11:52.<small>256</small>||[<small>STATE UPDATE zigbee:device:05001B6B:d0cf5efffe72cf68:D0CF5EFFFE72CF68_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18621)|
|18:11:54.<small>822</small>|38703|[<small>RX 98 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18637)|
|18:11:54.<small>835</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18638)|
|18:11:55.<small>614</small>|38703|[<small>TIMEOUT 9E ReadAttributesCommand cluster=ON_OFF **identifiers** =[0]</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18639)|
|18:11:55.<small>630</small>|38703|[<small>TX A2 ReadAttributesCommand cluster=LEVEL_CONTROL **identifiers** =[0]</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18640)|
|18:11:56.<small>862</small>|38703|[<small>RX 9B ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18648)|
|18:11:56.<small>892</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18649)|
|18:11:59.<small>891</small>|38703|[<small>RX A2 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18657)|
|18:11:59.<small>925</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18658)|
|18:12:01.<small>868</small>|38703|[<small>RX A5 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18666)|
|18:12:01.<small>894</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18667)|
|18:12:03.<small>162</small>||[<small>COMMAND RECEIVED zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 28 [PercentType]</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18672)|
|18:12:03.<small>182</small>|38703|[<small>TX A5 MoveToLevelWithOnOffCommand **level** =71 **transitionTime** =10</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18673)|
|18:12:04.<small>699</small>||[<small>STATE UPDATE zigbee:device:05001B6B:000b57fffeb92eb9:000B57FFFEB92EB9_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18692)|
|18:12:04.<small>991</small>|38703|[<small>RX AC ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18697)|
|18:12:05.<small>005</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18699)|
|18:12:06.<small>889</small>|38703|[<small>RX AF ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18713)|
|18:12:06.<small>917</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18714)|
|18:12:09.<small>870</small>|38703|[<small>RX B6 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18722)|
|18:12:09.<small>886</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18723)|
|18:12:10.<small>394</small>||[<small>STATE UPDATE zigbee:device:05001B6B:90fd9ffffe320172:90FD9FFFFE320172_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18733)|
|18:12:11.<small>182</small>|38703|[<small>TIMEOUT A5 MoveToLevelWithOnOffCommand **level** =71 **transitionTime** =10</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18743)|
|18:12:11.<small>833</small>|38703|[<small>RX B9 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18749)|
|18:12:11.<small>850</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18751)|
|18:12:14.<small>630</small>||[<small>STATE UPDATE zigbee:device:05001B6B:000b57fffed5da47:000B57FFFED5DA47_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18768)|
|18:12:14.<small>931</small>|38703|[<small>RX C0 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18774)|
|18:12:14.<small>959</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18775)|
|18:12:15.<small>331</small>||[<small>STATE UPDATE zigbee:device:05001B6B:d0cf5efffe1fa5e9:D0CF5EFFFE1FA5E9_1_colortemperature 50</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18789)|
|18:12:15.<small>671</small>||[<small>STATE UPDATE zigbee:device:05001B6B:d0cf5efffe1fa5e9:D0CF5EFFFE1FA5E9_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18798)|
|18:12:16.<small>549</small>||[<small>COMMAND RECEIVED zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 0 [PercentType]</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18808)|
|18:12:16.<small>564</small>|38703|[<small>TX OffCommand</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18809)|
|18:12:16.<small>918</small>|38703|[<small>RX C3 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18816)|
|18:12:16.<small>945</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18817)|
|18:12:19.<small>671</small>|38703|[<small>RX C9 QueryNextImageCommand</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18829)|
|18:12:19.<small>819</small>|38703|[<small>RX CB ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18832)|
|18:12:19.<small>832</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18833)|
|18:12:21.<small>873</small>|38703|[<small>RX CE ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18838)|
|18:12:21.<small>898</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18839)|
|18:12:24.<small>564</small>|38703|[<small>TIMEOUT OffCommand</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18847)|
|18:12:24.<small>851</small>|38703|[<small>RX D5 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18850)|
|18:12:24.<small>878</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18851)|
|18:12:26.<small>852</small>|38703|[<small>RX D8 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18857)|
|18:12:26.<small>864</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18858)|
|18:12:30.<small>027</small>|38703|[<small>RX DF ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18865)|
|18:12:30.<small>035</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18866)|
|18:12:31.<small>811</small>|38703|[<small>RX E2 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18873)|
|18:12:31.<small>820</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18874)|
|18:12:34.<small>831</small>|38703|[<small>RX E9 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18886)|
|18:12:34.<small>854</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18887)|
|18:12:36.<small>838</small>|38703|[<small>RX EC ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18892)|
|18:12:36.<small>857</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18893)|
|18:12:37.<small>765</small>|38703|[<small>RX EE QueryNextImageCommand</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18899)|
|18:12:37.<small>818</small>||[<small>STATE UPDATE zigbee:device:05001B6B:90fd9ffffe0f19b7:90FD9FFFFE0F19B7_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18906)|
|18:12:38.<small>356</small>||[<small>STATE UPDATE zigbee:device:05001B6B:d0cf5efffeb35f9b:D0CF5EFFFEB35F9B_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18923)|
|18:12:39.<small>883</small>|38703|[<small>RX F4 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18937)|
|18:12:39.<small>896</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18939)|
|18:12:41.<small>874</small>|38703|[<small>RX F7 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18953)|
|18:12:41.<small>883</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18954)|
|18:12:44.<small>869</small>|38703|[<small>RX FE ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18967)|
|18:12:44.<small>893</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18969)|
|18:12:46.<small>898</small>|38703|[<small>RX 01 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18978)|
|18:12:46.<small>917</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18979)|
|18:12:49.<small>841</small>|38703|[<small>RX 08 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18991)|
|18:12:49.<small>858</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18992)|
|18:12:51.<small>828</small>|38703|[<small>RX 0B ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18998)|
|18:12:51.<small>841</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18999)|
|18:12:53.<small>413</small>|38703|[<small>TX C2 ReadAttributesCommand cluster=ON_OFF **identifiers** =[0]</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19003)|
|18:12:54.<small>869</small>|38703|[<small>RX 12 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19013)|
|18:12:54.<small>883</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19014)|
|18:12:55.<small>654</small>|38703|[<small>RX 13 QueryNextImageCommand</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19017)|
|18:12:56.<small>174</small>||[<small>STATE UPDATE zigbee:device:05001B6B:d0cf5efffe72cf68:D0CF5EFFFE72CF68_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19027)|
|18:12:56.<small>827</small>|38703|[<small>RX 16 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19037)|
|18:12:56.<small>841</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19038)|
|18:12:59.<small>826</small>|38703|[<small>RX 1D ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19048)|
|18:12:59.<small>843</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19049)|
|18:13:01.<small>413</small>|38703|[<small>TIMEOUT C2 ReadAttributesCommand cluster=ON_OFF **identifiers** =[0]</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19052)|
|18:13:01.<small>418</small>|38703|[<small>TX C6 ReadAttributesCommand cluster=LEVEL_CONTROL **identifiers** =[0]</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19053)|
|18:13:01.<small>819</small>|38703|[<small>RX 20 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19060)|
|18:13:01.<small>827</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19061)|
|18:13:04.<small>914</small>|38703|[<small>RX 27 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19076)|
|18:13:04.<small>940</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19078)|
|18:13:04.<small>996</small>||[<small>STATE UPDATE zigbee:device:05001B6B:000b57fffeb92eb9:000B57FFFEB92EB9_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19084)|
|18:13:06.<small>831</small>|38703|[<small>RX 2A ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19097)|
|18:13:06.<small>846</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19098)|
|18:13:09.<small>418</small>|38703|[<small>TIMEOUT C6 ReadAttributesCommand cluster=LEVEL_CONTROL **identifiers** =[0]</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19103)|
|18:13:09.<small>853</small>|38703|[<small>RX 31 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19106)|
|18:13:09.<small>871</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19107)|
|18:13:10.<small>970</small>||[<small>STATE UPDATE zigbee:device:05001B6B:90fd9ffffe320172:90FD9FFFFE320172_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19116)|
|18:13:11.<small>842</small>|38703|[<small>RX 34 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19134)|
|18:13:11.<small>859</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19135)|
|18:13:14.<small>827</small>|38703|[<small>RX 3B ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19143)|
|18:13:14.<small>845</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19144)|
|18:13:16.<small>477</small>||[<small>STATE UPDATE zigbee:device:05001B6B:000b57fffed5da47:000B57FFFED5DA47_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19155)|
|18:13:16.<small>975</small>|38703|[<small>RX 3E ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19170)|
|18:13:16.<small>991</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19172)|
|18:13:17.<small>624</small>||[<small>STATE UPDATE zigbee:device:05001B6B:d0cf5efffe1fa5e9:D0CF5EFFFE1FA5E9_1_colortemperature 50</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19181)|
|18:13:17.<small>924</small>||[<small>STATE UPDATE zigbee:device:05001B6B:d0cf5efffe1fa5e9:D0CF5EFFFE1FA5E9_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19191)|
|18:13:19.<small>840</small>|38703|[<small>RX 45 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19205)|
|18:13:19.<small>865</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19206)|
|18:13:21.<small>822</small>|38703|[<small>RX 48 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19212)|
|18:13:21.<small>829</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19213)|
|18:13:24.<small>833</small>|38703|[<small>RX 4F ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19221)|
|18:13:24.<small>849</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19222)|
|18:13:26.<small>830</small>|38703|[<small>RX 52 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19228)|
|18:13:26.<small>844</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19229)|
|18:13:29.<small>854</small>|38703|[<small>RX 59 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19240)|
|18:13:29.<small>865</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19241)|
|18:13:31.<small>826</small>|38703|[<small>RX 5C ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19247)|
|18:13:31.<small>841</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19248)|
|18:13:34.<small>849</small>|38703|[<small>RX 63 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19263)|
|18:13:34.<small>872</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19264)|
|18:13:36.<small>830</small>|38703|[<small>RX 66 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19270)|
|18:13:36.<small>843</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19272)|
|18:13:39.<small>828</small>|38703|[<small>RX 6D ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19282)|
|18:13:39.<small>846</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19283)|
|18:13:41.<small>872</small>||[<small>STATE UPDATE zigbee:device:05001B6B:90fd9ffffe0f19b7:90FD9FFFFE0F19B7_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19295)|
|18:13:42.<small>145</small>|38703|[<small>RX 70 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19302)|
|18:13:42.<small>153</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19304)|
|18:13:42.<small>209</small>||[<small>STATE UPDATE zigbee:device:05001B6B:d0cf5efffeb35f9b:D0CF5EFFFEB35F9B_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19313)|
|18:13:44.<small>659</small>|38703|[<small>RX 76 QueryNextImageCommand</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19335)|
|18:13:44.<small>830</small>|38703|[<small>RX 78 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19338)|
|18:13:44.<small>844</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19339)|
|18:13:46.<small>826</small>|38703|[<small>RX 7B ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19348)|
|18:13:46.<small>839</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19349)|
|18:13:49.<small>860</small>|38703|[<small>RX 82 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19357)|
|18:13:49.<small>874</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19358)|
|18:13:51.<small>860</small>|38703|[<small>RX 85 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19365)|
|18:13:51.<small>873</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19366)|
|18:13:54.<small>843</small>|38703|[<small>RX 8C ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19375)|
|18:13:54.<small>863</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19376)|
zolakk
(zolakk)
February 11, 2019, 6:43pm
1937
jfrank1845:
Has anyone else noticed their color bulbs going to an “UNDEF” state in the most recent version of the code? I’ll work on getting some debug code but I’m hoping this maybe obvious enough as I have never seen an UNDEF state before - only null. Items do this constantly and seem to go to and from the state without any interaction - I’m dead asleep at the time block I pulled this log from.
Edit: logs uploaded. You can see the channel converter setting it to UNDEF.
2019-01-31 17:13:26.011 [DEBUG] [converter.ZigBeeBaseChannelConverter] - 8418260000092447: Channel zigbee:device:86496f67:8418260000092447:8418260000092447_3_color updated to UNDEF
https://the-hive.dynu.net/nextcloud/index.php/s/f4RTs75aipJLmaH
thanks!
2019-01-31 03:39:15.227 [vent.ItemStateChangedEvent] - raw_TV_CC changed from 0,0,0 to UNDEF
2019-01-31 03:39:17.306 [vent.ItemStateChangedEvent] - raw_TV_CC changed from UNDEF to 0,0,0
2019-01-31 03:40:58.228 [vent.ItemStateChangedEvent] - raw_Dine1_CC changed from 0,0,0 to UNDEF
2019-01-31 03:41:01.185 [vent.ItemStateChangedEvent] - raw_Dine1_CC changed from UNDEF to 0,0,0
2019-01-31 03:41:57.221 [vent.ItemStateChangedEvent] - raw_Dine3_CC changed from 0,0,0 to UNDEF
2019-01-31 03:42:38.743 [vent.ItemStateChangedEvent] - raw_Dine3_CC changed from UNDEF to 0,0,0
2019-01-31 03:43:00.454 [vent.ItemStateChangedEvent] - raw_Desk2_CC changed from 0,0,0 to UNDEF
2019-01-31 03:43:20.079 [vent.ItemStateChangedEvent] - raw_Entry_CC changed from 0,0,0 to UNDEF
2019-01-31 03:43:52.149 [vent.ItemStateChangedEvent] - raw_Desk2_CC changed from UNDEF to 0,0,0
2019-01-31 03:44:08.144 [vent.ItemStateChangedEvent] - raw_Entry_CC changed from UNDEF to 0,0,0
2019-01-31 03:44:09.205 [vent.ItemStateChangedEvent] - raw_Dine2_CC changed from 0,0,0 to UNDEF
2019-01-31 03:44:39.002 [vent.ItemStateChangedEvent] - raw_Dine2_CC changed from UNDEF to 0,0,0
2019-01-31 03:44:42.069 [vent.ItemStateChangedEvent] - raw_Desk1_CC changed from 0,0,0 to UNDEF
2019-01-31 03:45:32.841 [vent.ItemStateChangedEvent] - raw_Desk1_CC changed from UNDEF to 0,0,0
I’ve noticed the same too, but in my case it seems to only be one of my three color bulbs. The other two don’t have this issue for some reason.
chris
(Chris Jackson)
February 11, 2019, 7:25pm
1938
This is still being worked on, but UNDEF will be displayed in future when a color bulb is in CT mode.
jfrank1845
(Jared Frank)
February 12, 2019, 3:13pm
1939
Chris - if that is the case - how are we supposed to know if a bulb is on or not / get the brightness?
(my angle: I use a rule that auto adjusts CT throughout the day so I have daylight cool white during the day and then it shifts at night to warm white based on either the actual sunset or my alarm clock for the next day - whichever is earlier. Because of that I loop through and update the CT value for online bulbs only to save on network traffic/ If a bulb receives a change in CT i believe it powers up. My guess is that whenever offline I would still aways get a 0,0,0 from the color item? I think thats what I’ve noticed so at it least prevents me from sending the signal to offline bulbs still. My workaround has been to just send the CT whenever I get an UNDEF color item state)
chris
(Chris Jackson)
February 12, 2019, 3:35pm
1940
You would need to look at the CT channel I guess. This will work the same - if the bulb is in Color mode then the CT channel will show UNDEF. This is what was implemented for the Hue binding so the Qivicon guys also make the change in the ZigBee binding.
CT is also a dimmer so it will also be able to show the on off state.
jfrank1845
(Jared Frank)
February 12, 2019, 3:40pm
1941
Ah ok - that makes sense then I guess… so when offline Color item should show 0,0,0 ? I am a bit confused as to how we can get any information out of the CT item though as the Dimmer is for the CT only showing warm(100) to cool(0) - where would the brightness or on/off info be stored in that item - would we just need to cast it to something to get that info?
chris
(Chris Jackson)
February 12, 2019, 5:19pm
1942
No - I believe it would show UNDEF as it is undefined.
Good question - this is probably missing
Maybe it is worth discussing this further on the github issues -:
opened 03:19PM - 03 Dec 18 UTC
closed 10:14AM - 14 Jan 19 UTC
This issue is related to the PR https://github.com/eclipse/smarthome/pull/5762
We want to recognize if the color of the bulb has been set via color scheme or via color temperature scheme. In the Hue binding this has been solved by setting the color temperature to `UnDefType.NULL` when the color mode is not 'color temperature' (see linked PR). We would like to do the same in the ZigBee binding.
Here the idea: In the method `ZigBeeConverterColorTemperature.attributeUpdated(ZclAttribute attribute)` when `attribute` is `ColorMode` and its value is not '0x02' (ColorTemperatureMireds) then we would set the channel status to `UnDefType.NULL`. The additional code could look like this
if (attribute.getCluster() == ZclClusterType.COLOR_CONTROL
&& attribute.getId() == ZclColorControlCluster.ATTR_COLORMODE) {
Integer colorMode = (Integer) attribute.getLastValue();
if (colorMode != ColorModeEnum.COLORTEMPERATURE.getKey()) {
updateChannelState(UnDefType.NULL);
But I faced an issue when I investigated this approach. When you switch from color to color temperature and vice versa then `ColorMode` is not updated automatically (I checked it in the console) and so the listener is not called. I tried then to read `ColorMode` with a console command and in that moment its value was updated and the listener was called.
How can we solve this issue? Is it an option to (force-)update `ColorMode` by calling `com.zsmartsystems.zigbee.zcl.ZclCluster.read(int)` when either HSB or the color temperature changes?
openhab:master
← TomTravaglino:326-Recognize-color-mode-of-color-bulb
opened 02:49PM - 13 Dec 18 UTC
Resolves #326
This is an approach to recognize if the color has been set via … color scheme or via color temperature scheme. It corresponds to the solution realized in https://github.com/eclipse/smarthome/pull/5762 which sets the color temperature to UnDefType.NULL when the color mode is not "color temperature".
Your feedback is welcome.
I don’t really think OH has a good concept for CT channels so maybe this requires more discussion in general.
zolakk
(zolakk)
February 12, 2019, 6:18pm
1943
Strangely, my bulbs (IKEA of Sweden TRADFRI bulb E26 CWS opal 600lm) don’t have a CT channel, only color so i’m not sure if they support CT. There also used to be a separate dimmer and switch channels but those went away with one of the binding updates.
chris
(Chris Jackson)
February 12, 2019, 6:46pm
1944
Yes - that is correct. This was removed quite a long time ago. There will now only be a dimmer, and not a dimmer and a switch as it is not needed to have both (and against OH rules).
zolakk
(zolakk)
February 12, 2019, 8:55pm
1945
What about the CT channel though? I see reference above to a separate channel for that in which the CT channel would have a value when in temperature mode (setting the color channel to UNDEF) and when color is set, the CT channel is set to UNDEF - or am I misunderstanding? Just trying to wrap my head around under what circumstances my bulbs would be going into a CT mode when they only support Color and not Color Temperature from what I understand.
chris
(Chris Jackson)
February 12, 2019, 8:57pm
1946
This is a separate channel - there will be two channels - color and color temperature. When in color mode, CT is set to UNDEF and vice versa.
jfrank1845
(Jared Frank)
February 12, 2019, 9:44pm
1947
I think your confusion lies in that the remaining dimmer and color channel that Chris is referring to is actually the CT channel dimmer.
The issue with this is that we lose all visibility into the brightness dimmer and therefore on/off state as well whenever we are in CT mode as Color channel goes undef and CT can only indicate color temperature
