@chris
no I actually found out its a Mi IO problem
the issue gone from the Mi IO Binding as Marc provided a fix and threads are back to normal.
however I still see a extremely volatile performance on zigbee
few times its almost instant … but often it seems to timeout fully
I put the binding to debug but dont see as much as for zwave in the log
is there more from the zigbee bundles I need to put into debug?
I’m not sure what you’ve already done, so it’s hard to say if you need to add more… Check the binding docs - that provides the debugging log information.
So I created a log when the performance was very low or the devices just do not react.
Could you look at it if you find something?
I see retries and adress unknown e.g.
I have a very small zigbee network of 3 mains devices.
It is very volatile … sometimes instant (mostly after a restart of openhab) and then it gets worse up to devices just don’t react anymore to any actions
I can’t see any reason for any delays - it seems most of the time (in this log at least) it works well and the delays are minimal (ie there are no delays other than what you’d expect) -:
In each of these commands, the response is received around 125ms after the command.
I do spot one command that seems to take longer, but there’s no clear reason why. There is no retry, so I can only guess there are delays outside of the binding somewhere.
@chris phew.
I moved one plug really close to the coordinator.
like 2 meters… works better now. when the first mains device was like 5 meters away I barely could switch that plug. so either my xbee sucks or zigbee range
well it works sometimes…
where do you read poor signal in the device information in the graphic (lqi?) and is it related to the old zigbee standard from the devices or any tips what could help?
Yes, but you are asking me why it’s not working, and I can say it is due to poor signal. It’s quite clear.
Yes, LQI - Link Quality Indicator - it should be well above 200, and I see numbers like 20 in your system.
No - it’s related to poor wireless conditions. Either poor signal, or interference. LQI is link quality - not signal strength. So it’s an indicator of the number of packets that will successfully be received. Generally these values should be well above 200 - even at 200, the packet throughput is likely to result in 20% loss - at values around 50, you’re going to have a very high loss.
For information, below is what Silabs say about LQI for the Ember that you have -:
thanks - its helpful for me to further look how I can solve it.
considering that even my close to coordinator wallplug has “only” and lqi ~200 this seems really strange.
I even switched the coordinator to channel 25 to get away from crowded wifi channels and I don’t have relevant bluetooth devices
I tried and turned of my own wifi from the router which is close to the openhab server…
the devices are much more responsive. however LQI does not show that improvement. not sure if that value is maybe updated only when the mesh heal is done.
so I need
a) find a better channel
b) find another location for my openhab server
or
c) solve it with a zigbee dongle which has more power
I think the xbee has 4dbm and the bitron says their stick has 20dbm
It’s updated periodically - there’s a setting in the coordinator that sets how often this is updated.
This probably won’t help - it’s not about the server - it also affects other links.
As @rossko57 said, increasing the power in the dongle won’t help - you can see that in one device you have a depth = 2, and LQI=20. This means that this device is 2 hops away, and therefore increasing the coordinator power most likely won’t help. It might (maybe!) allow the coordinator to talk directly to a device, but it doesn’t mean that the device can talk directly back again as the link budget will only be improved in one direction.
I have a Intel NUC with a wifi card that is not used. Turning off wifi radio with rfkill improved zigbee quite a bit.
Likewise I see some people use a stright USB cable to get the stick at some distance from wifi radio.
I guess some oscillators is running and creates interference.
Rf shielding was something we had in the past century…
Edit: But it would not help much 2 zigbee hops from the stick.
Only for interference between wifi radio and zigbee stick when they are close.
Anyway; Shutting down unused radios is a good thing
Well I see that RFKILL actually shows already wifi and bluetooth as BLOCKED for my system
So I think the soft off from ubuntu itself did the job.
If I ever attach again a monitor to the server I would also disable it in the bios
the LQI is still the same and was not updated yet.
I looked up the the debug when the stick is initalized to see what parameter it is and what it is set to but did not see a specific parameter for this.
The “Mesh update intervall” I tried to change from the UI (my Coordinator is created via UI not a things file).
If I change the intervall there I see
So I got a set of 4 mains plugs to have a better mesh… at least what I was hopeing for.
What I see now is my debug is spammed with NetworkAdressRequests
I don’t find a solution here. Could the Digi XBEE be the problem?
Edit: to add 1 More Observation I Made.
When I Switch the Plug on the Device it Instantly Updates the Status in openhab. When I try to Switch the Device from openhab it Takes very Long / multiple times to get it through
thanks
I see very few of these in your log . There are 4 in the log over a 1 minute period - this seems normal. If the device doesn’t respond, the binding asks again and it’s only happening every 10 seconds or so so I don’t really thing is is spam?
If you provide a log showing this issue I’ll take a look. It’s hard to comment otherwise - it is presumably because the device has other communications going on, or the network is not good since that’s the normal reason.
