Hi Folks,
on a Fedora-35 system with OH v3.2.0 installed from the Fedora repo, I am trying to get OH to use a POPP “ZB-Stick”. When I plug it in, I immediately see a new /dev/ttyUSB0 device. lsusb shows me this:
Bus 001 Device 012: ID 1a86:7523 QinHeng Electronics CH340 serial converter
I am following the instructions provided by POPP for using their ZB-Stick with OH, which are here:
I installed the “openHAB ZigBee Binding”, then went to “things”, clicked on the “plus” button, and chose the “ZigBee Binding”. At this point I saw:
I chose the “Ember Coordinator”, and configured:
Port: /dev/ttyUSB0
Flow control: None
Baud Rate: 115200
and left the rest at their defaults. Then I started OH and observed that the Ember Coordinator oscillates between the “ERROR: COMM” and “UNKNOWN” states.
Looking in /var/log/openhab/openhab.log I see the error message:
[DEBUG] [nding.zigbee.serial.ZigBeeSerialPort] - No communication ports found, cannot connect to [/dev/ttyUSB0]
(see below for longer excerpt).
I have set SELinux to Permissive mode to rule that out. The OH process is running as the “openhab” user, and /dev/ttyUSB0 is owned by the “dialout” group, of which the “openhab” user is a member. Nevertheless I set the perms on /dev/ttyUSB0 to 666. These things did not help.
Using the Aeotec firmware utility I can “probe” the device and get what seems to be a reasonable answer:
$ python3 Elelabs_EzspFwUtility.py probe -p /dev/ttyUSB0
2022/05/19 15:23:25 Elelabs_EzspFwUtility: Elelabs Zigbee adapter detected:
2022/05/19 15:23:25 Elelabs_EzspFwUtility: Adapter: ELU013
2022/05/19 15:23:25 Elelabs_EzspFwUtility: Firmware: 6.10.0-169
2022/05/19 15:23:25 Elelabs_EzspFwUtility: EZSP v8
So it seems to be working properly.
I guess I’m doing something wrong… but what?
/treefrob
Larger excerpt from /var/log/openhab/openhab.log:
2022-05-19 16:07:41.513 [INFO ] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee dongle inactivity timer. Reinitializing ZigBee
2022-05-19 16:07:41.513 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - ZigBeeNetworkManager shutdown: networkState=OFFLINE
2022-05-19 16:07:41.513 [DEBUG] [atabase.ZigBeeNetworkDatabaseManager] - Data store: Deferred Write Time set to 0ms
2022-05-19 16:07:41.513 [DEBUG] [atabase.ZigBeeNetworkDatabaseManager] - Data store: Deferred Write Time set less than Max Deferred Write Time
2022-05-19 16:07:41.513 [DEBUG] [atabase.ZigBeeNetworkDatabaseManager] - Data store: Max Deferred Write Time set to 0ms
2022-05-19 16:07:41.514 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Network state is updated to SHUTDOWN
2022-05-19 16:07:41.514 [DEBUG] [atabase.ZigBeeNetworkDatabaseManager] - Data store: Shutdown
2022-05-19 16:07:41.514 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=SHUTDOWN
2022-05-19 16:07:41.514 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP Dongle: Shutdown
2022-05-19 16:07:41.514 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP Dongle: Shutdown frameHandler is null
2022-05-19 16:07:41.514 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Shutdown
2022-05-19 16:07:41.514 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - Broadcast: Queue shutdown
2022-05-19 16:07:41.514 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - Multicast: Queue shutdown
2022-05-19 16:07:41.514 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - Initializing ZigBee Ember serial bridge handler.
2022-05-19 16:07:41.515 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - ZigBee Ember Coordinator opening Port:’/dev/ttyUSB0’ PAN:d8cf, EPAN:BFF5B16EEC444044, Channel:11
2022-05-19 16:07:41.515 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - Ember end device poll timeout set to (169 * 2^9) = 86528 seconds
2022-05-19 16:07:41.515 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Scheduling ZigBee start
2022-05-19 16:07:42.515 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee network starting
2022-05-19 16:07:42.516 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
2022-05-19 16:07:42.516 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - Default: Set profile to ZigBeeTransactionProfile [maxOutstandingTransactions=1, interTransactionDelay=50, maxRetries=2]
2022-05-19 16:07:42.516 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - Broadcast: Set profile to ZigBeeTransactionProfile [maxOutstandingTransactions=2, interTransactionDelay=4000, maxRetries=0]
2022-05-19 16:07:42.517 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - Multicast: Set profile to ZigBeeTransactionProfile [maxOutstandingTransactions=3, interTransactionDelay=1200, maxRetries=0]
2022-05-19 16:07:42.517 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - ZigBeeNetworkManager initialize: networkState=UNINITIALISED
2022-05-19 16:07:42.517 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Network state is updated to INITIALISING
2022-05-19 16:07:42.518 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP Dongle: Initialize with protocol ASH2.
2022-05-19 16:07:42.518 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=INITIALISING
2022-05-19 16:07:42.518 [DEBUG] [nding.zigbee.serial.ZigBeeSerialPort] - Connecting to serial port [/dev/ttyUSB0] at 115200 baud, flow control FLOWCONTROL_OUT_NONE.
2022-05-19 16:07:42.521 [DEBUG] [nding.zigbee.serial.ZigBeeSerialPort] - No communication ports found, cannot connect to [/dev/ttyUSB0]
2022-05-19 16:07:42.521 [ERROR] [zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP Dongle: Unable to open serial port
2022-05-19 16:07:42.521 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Network state is updated to OFFLINE
2022-05-19 16:07:42.521 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=OFFLINE
