Raspberry Pi 4 2gb
Openhab 3.4.4 - Debian
Openhabian
i’ve just bought a Aeotec Zi-Stick, and I want to install it on my system that fondamentally has a Aeotec Ziwave 5 installet as the first dongle.
I follow these process:
1- plug the zi-stick into the usb of my raspberry
2- find the tty* with ssh (tty/USB0)
3- install the zigbee binding
4- into intems install embercoordinator as describe into the Aeotec manual, and into the description of the binding (there a difference about the acceleration hardware or not…)
5- But the result is the same:
2024-03-06 22:38:05.625 [INFO ] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee dongle inactivity timer. Reinitializing ZigBee
2024-03-06 22:38:06.649 [ERROR] [nding.zigbee.serial.ZigBeeSerialPort] - Serial Error: Port [/dev/ttyUSB0] does not exist.
2024-03-06 22:38:06.651 [ERROR] [zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP Dongle: Unable to open serial port
2024-03-06 22:38:06.656 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_ember:ce52cadfdc' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE: Failed to open communications port
2024-03-06 22:38:06.659 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_ember:ce52cadfdc' changed from OFFLINE: Failed to open communications port to OFFLINE (COMMUNICATION_ERROR)
2024-03-06 22:38:11.658 [INFO ] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee dongle inactivity timer. Reinitializing ZigBee
2024-03-06 22:38:12.684 [ERROR] [nding.zigbee.serial.ZigBeeSerialPort] - Serial Error: Port [/dev/ttyUSB0] does not exist.
2024-03-06 22:38:12.685 [ERROR] [zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP Dongle: Unable to open serial port
2024-03-06 22:38:12.691 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_ember:ce52cadfdc' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE: Failed to open communications port
2024-03-06 22:38:12.694 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_ember:ce52cadfdc' changed from OFFLINE: Failed to open communications port to OFFLINE (COMMUNICATION_ERROR)
2024-03-06 22:38:15.493 [INFO ] [org.openhab.rule.22740c0dbc ] - Il conteggio di energia dalla rete è:
2024-03-06 22:38:15.495 [ERROR] [d4j.internal.RRD4jPersistenceService] - Could not create rrd4j database file '/var/lib/openhab/persistence/rrd4j/SolarLogMeter_ConsumptionPAC.rrd': Invalid file header. File [/var/lib/openhab/persistence/rrd4j/SolarLogMeter_ConsumptionPAC.rrd] is not a RRD4J RRD file
2024-03-06 22:38:15.495 [INFO ] [org.openhab.rule.22740c0dbc ] - 2469 kWh
2024-03-06 22:38:15.514 [ERROR] [d4j.internal.RRD4jPersistenceService] - Could not create rrd4j database file '/var/lib/openhab/persistence/rrd4j/Solar_Rete_IN.rrd': Invalid file header. File [/var/lib/openhab/persistence/rrd4j/Solar_Rete_IN.rrd] is not a RRD4J RRD file
Some one has a idea how to solve it?
