Hi Chris - I saw this happening every ~30 minutes so I was able to capture the log. I can provide more log if needed but included some before and after. Not sure if it directly relates to the previous exception this thread was created for. This one is very repeatable (for now).
2023-11-04 09:29:02.583 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker reset for handler with thingUID=zigbee:device:ZigBee_Bridge:000d6f000a7ba835
2023-11-04 09:29:02.585 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker cancelled task for thingUID=zigbee:device:ZigBee_Bridge:000d6f000a7ba835
2023-11-04 09:29:02.586 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker scheduled task for thingUID=zigbee:device:ZigBee_Bridge:000d6f000a7ba835 in 1830 seconds
2023-11-04 09:29:02.628 [DEBUG] [ZigBeeConverterMeasurementRmsCurrent] - 000D6F000B2E7519: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1285, name=RMS Voltage, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=117, lastReportTime=Sat Nov 04 09:29:02 PDT 2023, implemented=true]
2023-11-04 09:29:02.628 [DEBUG] [rter.ZigBeeConverterMeasurementPower] - 000D6F000B2E7519: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1285, name=RMS Voltage, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=117, lastReportTime=Sat Nov 04 09:29:02 PDT 2023, implemented=true]
2023-11-04 09:29:02.629 [DEBUG] [ZigBeeConverterMeasurementRmsVoltage] - 000D6F000B2E7519: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1285, name=RMS Voltage, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=117, lastReportTime=Sat Nov 04 09:29:02 PDT 2023, implemented=true]
2023-11-04 09:29:02.630 [DEBUG] [converter.ZigBeeBaseChannelConverter] - 000D6F000B2E7519: Channel zigbee:device:ZigBee_Bridge:000d6f000b2e7519:000D6F000B2E7519_1_voltage updated to 11 V
2023-11-04 09:29:02.632 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 000D6F000B2E7519: Updating ZigBee channel state zigbee:device:ZigBee_Bridge:000d6f000b2e7519:000D6F000B2E7519_1_voltage to 11 V
2023-11-04 09:29:02.633 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker reset for handler with thingUID=zigbee:device:ZigBee_Bridge:000d6f000b2e7519
2023-11-04 09:29:02.635 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker cancelled task for thingUID=zigbee:device:ZigBee_Bridge:000d6f000b2e7519
2023-11-04 09:29:02.636 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker scheduled task for thingUID=zigbee:device:ZigBee_Bridge:000d6f000b2e7519 in 1830 seconds
2023-11-04 09:29:02.812 [DEBUG] [ZigBeeConverterMeasurementRmsVoltage] - 000D6F000B2D9BBD: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1288, name=RMS Current, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=173, lastReportTime=Sat Nov 04 09:29:02 PDT 2023, implemented=true]
2023-11-04 09:29:02.812 [DEBUG] [rter.ZigBeeConverterMeasurementPower] - 000D6F000B2D9BBD: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1288, name=RMS Current, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=173, lastReportTime=Sat Nov 04 09:29:02 PDT 2023, implemented=true]
2023-11-04 09:29:02.813 [DEBUG] [ZigBeeConverterMeasurementRmsCurrent] - 000D6F000B2D9BBD: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1288, name=RMS Current, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=173, lastReportTime=Sat Nov 04 09:29:02 PDT 2023, implemented=true]
2023-11-04 09:29:02.815 [DEBUG] [converter.ZigBeeBaseChannelConverter] - 000D6F000B2D9BBD: Channel zigbee:device:ZigBee_Bridge:000d6f000b2d9bbd:000D6F000B2D9BBD_1_current updated to 17 A
2023-11-04 09:29:02.816 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 000D6F000B2D9BBD: Updating ZigBee channel state zigbee:device:ZigBee_Bridge:000d6f000b2d9bbd:000D6F000B2D9BBD_1_current to 17 A
2023-11-04 09:29:02.819 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker reset for handler with thingUID=zigbee:device:ZigBee_Bridge:000d6f000b2d9bbd
2023-11-04 09:29:02.820 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker cancelled task for thingUID=zigbee:device:ZigBee_Bridge:000d6f000b2d9bbd
2023-11-04 09:29:02.822 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker scheduled task for thingUID=zigbee:device:ZigBee_Bridge:000d6f000b2d9bbd in 1830 seconds
2023-11-04 09:29:03.563 [DEBUG] [ZigBeeConverterMeasurementRmsVoltage] - 000D6F000A7BA835: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1291, name=Active Power, dataType=SIGNED_16_BIT_INTEGER, lastValue=45, lastReportTime=Sat Nov 04 09:29:03 PDT 2023, implemented=true]
2023-11-04 09:29:03.563 [DEBUG] [rter.ZigBeeConverterMeasurementPower] - 000D6F000A7BA835: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1291, name=Active Power, dataType=SIGNED_16_BIT_INTEGER, lastValue=45, lastReportTime=Sat Nov 04 09:29:03 PDT 2023, implemented=true]
2023-11-04 09:29:03.564 [DEBUG] [ZigBeeConverterMeasurementRmsCurrent] - 000D6F000A7BA835: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1291, name=Active Power, dataType=SIGNED_16_BIT_INTEGER, lastValue=45, lastReportTime=Sat Nov 04 09:29:03 PDT 2023, implemented=true]
2023-11-04 09:29:03.565 [DEBUG] [converter.ZigBeeBaseChannelConverter] - 000D6F000A7BA835: Channel zigbee:device:ZigBee_Bridge:000d6f000a7ba835:000D6F000A7BA835_1_activepower updated to 4 W
2023-11-04 09:29:03.567 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 000D6F000A7BA835: Updating ZigBee channel state zigbee:device:ZigBee_Bridge:000d6f000a7ba835:000D6F000A7BA835_1_activepower to 4 W
2023-11-04 09:29:03.569 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker reset for handler with thingUID=zigbee:device:ZigBee_Bridge:000d6f000a7ba835
2023-11-04 09:29:03.570 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker cancelled task for thingUID=zigbee:device:ZigBee_Bridge:000d6f000a7ba835
2023-11-04 09:29:03.572 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker scheduled task for thingUID=zigbee:device:ZigBee_Bridge:000d6f000a7ba835 in 1830 seconds
2023-11-04 09:29:03.816 [DEBUG] [ZigBeeConverterMeasurementRmsCurrent] - 000D6F000B2D9BBD: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1291, name=Active Power, dataType=SIGNED_16_BIT_INTEGER, lastValue=123, lastReportTime=Sat Nov 04 09:29:03 PDT 2023, implemented=true]
2023-11-04 09:29:03.816 [DEBUG] [ZigBeeConverterMeasurementRmsVoltage] - 000D6F000B2D9BBD: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1291, name=Active Power, dataType=SIGNED_16_BIT_INTEGER, lastValue=123, lastReportTime=Sat Nov 04 09:29:03 PDT 2023, implemented=true]
2023-11-04 09:29:03.816 [DEBUG] [rter.ZigBeeConverterMeasurementPower] - 000D6F000B2D9BBD: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1291, name=Active Power, dataType=SIGNED_16_BIT_INTEGER, lastValue=123, lastReportTime=Sat Nov 04 09:29:03 PDT 2023, implemented=true]
2023-11-04 09:29:03.818 [DEBUG] [converter.ZigBeeBaseChannelConverter] - 000D6F000B2D9BBD: Channel zigbee:device:ZigBee_Bridge:000d6f000b2d9bbd:000D6F000B2D9BBD_1_activepower updated to 12 W
2023-11-04 09:29:03.819 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 000D6F000B2D9BBD: Updating ZigBee channel state zigbee:device:ZigBee_Bridge:000d6f000b2d9bbd:000D6F000B2D9BBD_1_activepower to 12 W
2023-11-04 09:29:03.821 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker reset for handler with thingUID=zigbee:device:ZigBee_Bridge:000d6f000b2d9bbd
2023-11-04 09:29:03.824 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker cancelled task for thingUID=zigbee:device:ZigBee_Bridge:000d6f000b2d9bbd
2023-11-04 09:29:03.826 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker scheduled task for thingUID=zigbee:device:ZigBee_Bridge:000d6f000b2d9bbd in 1830 seconds
2023-11-04 09:29:05.444 [DEBUG] [rter.ZigBeeConverterMeasurementPower] - 24FD5B000108787A: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1285, name=RMS Voltage, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=1219, lastReportTime=Sat Nov 04 09:29:05 PDT 2023, implemented=true]
2023-11-04 09:29:05.444 [DEBUG] [ZigBeeConverterMeasurementRmsVoltage] - 24FD5B000108787A: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1285, name=RMS Voltage, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=1219, lastReportTime=Sat Nov 04 09:29:05 PDT 2023, implemented=true]
2023-11-04 09:29:05.444 [DEBUG] [ZigBeeConverterMeasurementRmsCurrent] - 24FD5B000108787A: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1285, name=RMS Voltage, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=1219, lastReportTime=Sat Nov 04 09:29:05 PDT 2023, implemented=true]
2023-11-04 09:29:05.447 [DEBUG] [converter.ZigBeeBaseChannelConverter] - 24FD5B000108787A: Channel zigbee:device:ZigBee_Bridge:24fd5b000108787a:24FD5B000108787A_1_voltage updated to 121 V
2023-11-04 09:29:05.448 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 24FD5B000108787A: Updating ZigBee channel state zigbee:device:ZigBee_Bridge:24fd5b000108787a:24FD5B000108787A_1_voltage to 121 V
2023-11-04 09:29:05.451 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker reset for handler with thingUID=zigbee:device:ZigBee_Bridge:24fd5b000108787a
2023-11-04 09:29:05.454 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker cancelled task for thingUID=zigbee:device:ZigBee_Bridge:24fd5b000108787a
2023-11-04 09:29:05.455 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker scheduled task for thingUID=zigbee:device:ZigBee_Bridge:24fd5b000108787a in 1830 seconds
2023-11-04 09:29:05.601 [DEBUG] [ZigBeeConverterMeasurementRmsVoltage] - 000D6F000A7BA835: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1288, name=RMS Current, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=66, lastReportTime=Sat Nov 04 09:29:05 PDT 2023, implemented=true]
2023-11-04 09:29:05.601 [DEBUG] [ZigBeeConverterMeasurementRmsCurrent] - 000D6F000A7BA835: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1288, name=RMS Current, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=66, lastReportTime=Sat Nov 04 09:29:05 PDT 2023, implemented=true]
2023-11-04 09:29:05.601 [DEBUG] [rter.ZigBeeConverterMeasurementPower] - 000D6F000A7BA835: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1288, name=RMS Current, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=66, lastReportTime=Sat Nov 04 09:29:05 PDT 2023, implemented=true]
2023-11-04 09:29:05.603 [DEBUG] [converter.ZigBeeBaseChannelConverter] - 000D6F000A7BA835: Channel zigbee:device:ZigBee_Bridge:000d6f000a7ba835:000D6F000A7BA835_1_current updated to 6 A
2023-11-04 09:29:05.604 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 000D6F000A7BA835: Updating ZigBee channel state zigbee:device:ZigBee_Bridge:000d6f000a7ba835:000D6F000A7BA835_1_current to 6 A
2023-11-04 09:29:05.606 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker reset for handler with thingUID=zigbee:device:ZigBee_Bridge:000d6f000a7ba835
2023-11-04 09:29:05.608 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker cancelled task for thingUID=zigbee:device:ZigBee_Bridge:000d6f000a7ba835
2023-11-04 09:29:05.609 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker scheduled task for thingUID=zigbee:device:ZigBee_Bridge:000d6f000a7ba835 in 1830 seconds
2023-11-04 09:29:05.639 [DEBUG] [ZigBeeConverterMeasurementRmsVoltage] - 000D6F000B2E7519: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1285, name=RMS Voltage, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=118, lastReportTime=Sat Nov 04 09:29:05 PDT 2023, implemented=true]
2023-11-04 09:29:05.639 [DEBUG] [ZigBeeConverterMeasurementRmsCurrent] - 000D6F000B2E7519: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1285, name=RMS Voltage, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=118, lastReportTime=Sat Nov 04 09:29:05 PDT 2023, implemented=true]
2023-11-04 09:29:05.639 [DEBUG] [rter.ZigBeeConverterMeasurementPower] - 000D6F000B2E7519: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1285, name=RMS Voltage, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=118, lastReportTime=Sat Nov 04 09:29:05 PDT 2023, implemented=true]
2023-11-04 09:29:05.642 [DEBUG] [converter.ZigBeeBaseChannelConverter] - 000D6F000B2E7519: Channel zigbee:device:ZigBee_Bridge:000d6f000b2e7519:000D6F000B2E7519_1_voltage updated to 11 V
2023-11-04 09:29:05.643 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 000D6F000B2E7519: Updating ZigBee channel state zigbee:device:ZigBee_Bridge:000d6f000b2e7519:000D6F000B2E7519_1_voltage to 11 V
2023-11-04 09:29:05.646 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker reset for handler with thingUID=zigbee:device:ZigBee_Bridge:000d6f000b2e7519
2023-11-04 09:29:05.648 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker cancelled task for thingUID=zigbee:device:ZigBee_Bridge:000d6f000b2e7519
2023-11-04 09:29:05.649 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker scheduled task for thingUID=zigbee:device:ZigBee_Bridge:000d6f000b2e7519 in 1830 seconds
2023-11-04 09:29:05.812 [DEBUG] [ZigBeeConverterMeasurementRmsVoltage] - 000D6F000B2D9BBD: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1288, name=RMS Current, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=172, lastReportTime=Sat Nov 04 09:29:05 PDT 2023, implemented=true]
2023-11-04 09:29:05.812 [DEBUG] [rter.ZigBeeConverterMeasurementPower] - 000D6F000B2D9BBD: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1288, name=RMS Current, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=172, lastReportTime=Sat Nov 04 09:29:05 PDT 2023, implemented=true]
2023-11-04 09:29:05.812 [DEBUG] [ZigBeeConverterMeasurementRmsCurrent] - 000D6F000B2D9BBD: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1288, name=RMS Current, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=172, lastReportTime=Sat Nov 04 09:29:05 PDT 2023, implemented=true]
2023-11-04 09:29:05.814 [DEBUG] [converter.ZigBeeBaseChannelConverter] - 000D6F000B2D9BBD: Channel zigbee:device:ZigBee_Bridge:000d6f000b2d9bbd:000D6F000B2D9BBD_1_current updated to 17 A
2023-11-04 09:29:05.816 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 000D6F000B2D9BBD: Updating ZigBee channel state zigbee:device:ZigBee_Bridge:000d6f000b2d9bbd:000D6F000B2D9BBD_1_current to 17 A
2023-11-04 09:29:05.817 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker reset for handler with thingUID=zigbee:device:ZigBee_Bridge:000d6f000b2d9bbd
2023-11-04 09:29:05.819 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker cancelled task for thingUID=zigbee:device:ZigBee_Bridge:000d6f000b2d9bbd
2023-11-04 09:29:05.820 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker scheduled task for thingUID=zigbee:device:ZigBee_Bridge:000d6f000b2d9bbd in 1830 seconds
2023-11-04 09:29:06.560 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - null: Polling [zigbee:device:ZigBee_Bridge:0022a3000011cf86:0022A3000011CF86_1_batteryvoltage] channels...
2023-11-04 09:29:06.561 [DEBUG] [ZigBeeConverterMeasurementRmsVoltage] - 000D6F000A7BA835: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1291, name=Active Power, dataType=SIGNED_16_BIT_INTEGER, lastValue=44, lastReportTime=Sat Nov 04 09:29:06 PDT 2023, implemented=true]
2023-11-04 09:29:06.561 [DEBUG] [rter.ZigBeeConverterMeasurementPower] - 000D6F000A7BA835: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1291, name=Active Power, dataType=SIGNED_16_BIT_INTEGER, lastValue=44, lastReportTime=Sat Nov 04 09:29:06 PDT 2023, implemented=true]
2023-11-04 09:29:06.562 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - null: Polling zigbee:device:ZigBee_Bridge:0022a3000011cf86:0022A3000011CF86_1_batteryvoltage
2023-11-04 09:29:06.562 [DEBUG] [ZigBeeConverterMeasurementRmsCurrent] - 000D6F000A7BA835: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1291, name=Active Power, dataType=SIGNED_16_BIT_INTEGER, lastValue=44, lastReportTime=Sat Nov 04 09:29:06 PDT 2023, implemented=true]
2023-11-04 09:29:06.563 [DEBUG] [converter.ZigBeeBaseChannelConverter] - 000D6F000A7BA835: Channel zigbee:device:ZigBee_Bridge:000d6f000a7ba835:000D6F000A7BA835_1_activepower updated to 4 W
2023-11-04 09:29:06.565 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 000D6F000A7BA835: Updating ZigBee channel state zigbee:device:ZigBee_Bridge:000d6f000a7ba835:000D6F000A7BA835_1_activepower to 4 W
2023-11-04 09:29:06.564 [WARN ] [ng.zigbee.handler.ZigBeeThingHandler] - null: Polling aborted due to exception
at com.zsmartsystems.zigbee.zcl.ZclCluster.readSync(ZclCluster.java:1727) ~[bundleFile:?]
at com.zsmartsystems.zigbee.zcl.clusters.ZclPowerConfigurationCluster.getBatteryVoltage(ZclPowerConfigurationCluster.java:762) ~[bundleFile:?]
at org.openhab.binding.zigbee.internal.converter.ZigBeeConverterBatteryVoltage.handleRefresh(ZigBeeConverterBatteryVoltage.java:111) ~[bundleFile:?]
at org.openhab.binding.zigbee.handler.ZigBeeThingHandler$2.run(ZigBeeThingHandler.java:607) [bundleFile:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
2023-11-04 09:29:06.567 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker reset for handler with thingUID=zigbee:device:ZigBee_Bridge:000d6f000a7ba835
2023-11-04 09:29:06.568 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker cancelled task for thingUID=zigbee:device:ZigBee_Bridge:000d6f000a7ba835
2023-11-04 09:29:06.570 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker scheduled task for thingUID=zigbee:device:ZigBee_Bridge:000d6f000a7ba835 in 1830 seconds
2023-11-04 09:29:06.632 [DEBUG] [converter.ZigBeeConverterTemperature] - 0022A30000133E18: ZigBee attribute reports ZclAttribute [cluster=Temperature Measurement, id=0, name=Measured Value, dataType=SIGNED_16_BIT_INTEGER, lastValue=3412, lastReportTime=Sat Nov 04 09:29:06 PDT 2023, implemented=false]
2023-11-04 09:29:06.633 [DEBUG] [converter.ZigBeeBaseChannelConverter] - 0022A30000133E18: Channel zigbee:device:ZigBee_Bridge:0022a30000133e18:0022A30000133E18_1_temperature updated to 34.12 °C
2023-11-04 09:29:06.634 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 0022A30000133E18: Updating ZigBee channel state zigbee:device:ZigBee_Bridge:0022a30000133e18:0022A30000133E18_1_temperature to 34.12 °C
2023-11-04 09:29:06.637 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker reset for handler with thingUID=zigbee:device:ZigBee_Bridge:0022a30000133e18
2023-11-04 09:29:06.637 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker cancelled task for thingUID=zigbee:device:ZigBee_Bridge:0022a30000133e18
2023-11-04 09:29:06.638 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker scheduled task for thingUID=zigbee:device:ZigBee_Bridge:0022a30000133e18 in 1830 seconds
2023-11-04 09:29:07.823 [DEBUG] [ZigBeeConverterMeasurementRmsVoltage] - 000D6F000B2D9BBD: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1291, name=Active Power, dataType=SIGNED_16_BIT_INTEGER, lastValue=126, lastReportTime=Sat Nov 04 09:29:07 PDT 2023, implemented=true]
2023-11-04 09:29:07.823 [DEBUG] [rter.ZigBeeConverterMeasurementPower] - 000D6F000B2D9BBD: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1291, name=Active Power, dataType=SIGNED_16_BIT_INTEGER, lastValue=126, lastReportTime=Sat Nov 04 09:29:07 PDT 2023, implemented=true]
2023-11-04 09:29:07.823 [DEBUG] [ZigBeeConverterMeasurementRmsCurrent] - 000D6F000B2D9BBD: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1291, name=Active Power, dataType=SIGNED_16_BIT_INTEGER, lastValue=126, lastReportTime=Sat Nov 04 09:29:07 PDT 2023, implemented=true]
2023-11-04 09:29:07.824 [DEBUG] [converter.ZigBeeBaseChannelConverter] - 000D6F000B2D9BBD: Channel zigbee:device:ZigBee_Bridge:000d6f000b2d9bbd:000D6F000B2D9BBD_1_activepower updated to 12 W
2023-11-04 09:29:07.825 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 000D6F000B2D9BBD: Updating ZigBee channel state zigbee:device:ZigBee_Bridge:000d6f000b2d9bbd:000D6F000B2D9BBD_1_activepower to 12 W
2023-11-04 09:29:07.826 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker reset for handler with thingUID=zigbee:device:ZigBee_Bridge:000d6f000b2d9bbd
2023-11-04 09:29:07.827 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker cancelled task for thingUID=zigbee:device:ZigBee_Bridge:000d6f000b2d9bbd
2023-11-04 09:29:07.828 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker scheduled task for thingUID=zigbee:device:ZigBee_Bridge:000d6f000b2d9bbd in 1830 seconds
2023-11-04 09:29:08.462 [DEBUG] [ZigBeeConverterMeasurementRmsCurrent] - 24FD5B000108787A: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1285, name=RMS Voltage, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=1218, lastReportTime=Sat Nov 04 09:29:08 PDT 2023, implemented=true]
2023-11-04 09:29:08.462 [DEBUG] [ZigBeeConverterMeasurementRmsVoltage] - 24FD5B000108787A: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1285, name=RMS Voltage, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=1218, lastReportTime=Sat Nov 04 09:29:08 PDT 2023, implemented=true]
2023-11-04 09:29:08.462 [DEBUG] [rter.ZigBeeConverterMeasurementPower] - 24FD5B000108787A: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1285, name=RMS Voltage, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=1218, lastReportTime=Sat Nov 04 09:29:08 PDT 2023, implemented=true]
2023-11-04 09:29:08.464 [DEBUG] [converter.ZigBeeBaseChannelConverter] - 24FD5B000108787A: Channel zigbee:device:ZigBee_Bridge:24fd5b000108787a:24FD5B000108787A_1_voltage updated to 121 V
2023-11-04 09:29:08.465 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 24FD5B000108787A: Updating ZigBee channel state zigbee:device:ZigBee_Bridge:24fd5b000108787a:24FD5B000108787A_1_voltage to 121 V
2023-11-04 09:29:08.467 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker reset for handler with thingUID=zigbee:device:ZigBee_Bridge:24fd5b000108787a
2023-11-04 09:29:08.468 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker cancelled task for thingUID=zigbee:device:ZigBee_Bridge:24fd5b000108787a
2023-11-04 09:29:08.470 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker scheduled task for thingUID=zigbee:device:ZigBee_Bridge:24fd5b000108787a in 1830 seconds
2023-11-04 09:29:08.553 [DEBUG] [rter.ZigBeeConverterMeasurementPower] - 000D6F000A7BA835: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1288, name=RMS Current, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=71, lastReportTime=Sat Nov 04 09:29:08 PDT 2023, implemented=true]
2023-11-04 09:29:08.553 [DEBUG] [ZigBeeConverterMeasurementRmsCurrent] - 000D6F000A7BA835: ZigBee attribute reports ZclAttribute [cluster=Electrical Measurement, id=1288, name=RMS Current, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=71, lastReportTime=Sat Nov 04 09:29:08 PDT 2023, implemented=true]
