Zigbee power plug with integrated power meter / ground support (european style)
Dear all,
I am new to the community and first of all I would like to thank the community for its hard work.
  • OpenHAB 4.x on RaspberryPi 3B
  • SONOFF ZigBee 3.0 USB Dongle Plus, EFR32MG21 Coordinator
  • SONOFF temparature and humidity sensors (x3)
Please note that I am a newbee, here is my question:
I would like to buy zigbee power-plugs with ground support (european style) and integrated power meter. I could not find any with such features. Could you outline compatible hardware?
Kind regards,
Welcome to openHAB.
Check the Blitzwolf brand:
Hello. Sorry, no power meter, no grounding.
This highlighted text means “track energy consumption”, which is the same as power metering. Are you looking for a display on the physical plug?
I’m in North America, but from what I know the contacts at the top and bottom are the ground wires in an EU socket.
Compatible with Zigbee2MQTT: Zigbee2MQTT
Correct :victory_hand:
Actually all his requirements are met, I am not sure anymore what he is looking for.
Judging from his name, he might be looking for something like Datei:French-power-socket.jpg – Wikipedia, e. g. Centralite 3200-fr control via MQTT | Zigbee2MQTT
I have this one:
Aubess WiFi/Zigbee Smart Socket Intelligent AU Plug With Power Monitor
It works with zigbee2mqtt.
https://www.innr.com/de/produkt/smart-plug-zigbee30/
Works with the ZigBee binding.
I purchased this one recently:
And finally got around to test it today: It works fine! I’m using it with ConBee II/deCONZ and the deCONZ binding.
It’s grounded German-style (Schuko) and has power meter, so it seems to fulfil your requirements.
