Since some days I receive the following error every few hours. Every time, a byte is missing (expected 7, received 6, or expected 10, received 9).
I use the Elelabs Zigbee USB stick. All devices seem to work fine. Only few commands are sent - just a on/off command every few hours or days.
Is this a known issue?
[WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: received IOException in serial port event
java.io.IOException: Expected to be able to read 10 bytes, but saw error after 9
at org.openhab.binding.zigbee.handler.ZigBeeSerialPort.serialEvent(ZigBeeSerialPort.java:303) [bundleFile:?]
at org.eclipse.smarthome.io.transport.serial.rxtx.RxTxSerialPort$1.serialEvent(RxTxSerialPort.java:81) [bundleFile:?]
at gnu.io.RXTXPort.sendEvent(RXTXPort.java:780) [bundleFile:3.15.0.OH2]
at gnu.io.RXTXPort.eventLoop(Native Method) [bundleFile:3.15.0.OH2]
at gnu.io.RXTXPort$MonitorThread.run(RXTXPort.java:1611) [bundleFile:3.15.0.OH2]
