I never used the ZigBee binding in OpenHAB before and can’t get it to work. I’m running OH 3.0.2 with a lot of different bindings (also Z-Wave USB stick with may devices) and everything works great - but I have no experience with ZigBee. I love Z-Wave, but I’ve bought a smart vertical blind wand which only supports ZigBee, so I’ve bought a ZigBee stick and hoped it will be as easy as with Z-Wave - but it’s not (or maybe not for me).
My OH 3.0.2 runs in a docker container already with Z-Wave USB on port /dev/ttyACM0 and I’ve set up the correct drivers also for the new ZigBee USB stick on port /dev/ttyUSB0
Access rights are ok and the status in the things view is “green”, online.
It’s a Bitron Video, ZigBee USB Radio Stick, AV2010/10
dmesg
[353525.652220] usb 2-4: new full-speed USB device number 10 using xhci_hcd
[353525.805694] usb 2-4: New USB device found, idVendor=10c4, idProduct=8b34, bcdDevice= 1.00
[353525.805697] usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[353525.805698] usb 2-4: Product: BV 2010/10
[353525.805700] usb 2-4: Manufacturer: Silicon Labs
[353525.805701] usb 2-4: SerialNumber: 013E75C1
[353525.807169] cp210x 2-4:1.0: cp210x converter detected
[353525.810338] usb 2-4: cp210x converter now attached to ttyUSB0
I’ve set all ZigBee log levels to debug and I see NO error, warnings, info messages and none of the debug messages indicates an error or problem, everything looks ok for me. Here is are the ZigBee log entries after a fresh restart of my OH 3.0.2 (it’s not complete to be accepted for a post, so I’ve deleted some lines in the middle with other debug success messages):
2021-07-20 18:06:34.973 [DEBUG] [bee.discovery.ZigBeeDiscoveryService] - Starting ZigBeeDiscoveryService
2021-07-20 18:06:45.888 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initializing ZigBee network [zigbee:coordinator_ember:c7b0cb48f4].
2021-07-20 18:06:45.912 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Channel 25
2021-07-20 18:06:45.913 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - PANID 48261
2021-07-20 18:06:45.914 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - EPANID EEE8BCB7B2C846E6
2021-07-20 18:06:45.923 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Network Key A72D3A4D4425C3F891CCD1587A1326F4
2021-07-20 18:06:45.940 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Link Key 5A6967426565416C6C69616E63653039
2021-07-20 18:06:45.944 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Config: zigbee_initialise found, initializeNetwork=false
2021-07-20 18:06:45.960 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Network Key String A72D3A4D4425C3F891CCD1587A1326F4
2021-07-20 18:06:45.962 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Network key final array A72D3A4D4425C3F891CCD1587A1326F4
2021-07-20 18:06:45.963 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Link Key String 5A6967426565416C6C69616E63653039
2021-07-20 18:06:45.964 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Link key final array 5A6967426565416C6C69616E63653039
2021-07-20 18:06:45.992 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - Initializing ZigBee Ember serial bridge handler.
2021-07-20 18:06:46.106 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - ZigBee Ember Coordinator opening Port:'/dev/ttyUSB0' PAN:bc85, EPAN:EEE8BCB7B2C846E6, Channel:25
2021-07-20 18:06:46.119 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - Ember end device poll timeout set to (169 * 2^9) = 86528 seconds
2021-07-20 18:06:46.131 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Scheduling ZigBee start
2021-07-20 18:06:47.144 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee network starting
2021-07-20 18:06:47.145 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
2021-07-20 18:06:47.202 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - Default: Set profile to ZigBeeTransactionProfile [maxOutstandingTransactions=1, interTransactionDelay=50, maxRetries=2]
2021-07-20 18:06:47.228 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - ZigBeeNetworkManager initialize: networkState=UNINITIALISED
2021-07-20 18:06:47.241 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Network state is updated to INITIALISING
2021-07-20 18:06:47.261 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=INITIALISING
2021-07-20 18:06:47.321 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - 000D6F000DB9E768: ZigBee reading network state complete.
2021-07-20 18:06:47.329 [DEBUG] [atabase.ZigBeeNetworkDatabaseManager] - 000D6F000DB9E768: Data store: Node was restored.
2021-07-20 18:06:47.330 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - 000D6F000DB9E768: Updating node NWK=0000
2021-07-20 18:06:47.331 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP Dongle: Initialize with protocol ASH2.
2021-07-20 18:06:47.332 [DEBUG] [nding.zigbee.serial.ZigBeeSerialPort] - Connecting to serial port [/dev/ttyUSB0] at 57600 baud, flow control FLOWCONTROL_OUT_XONOFF.
2021-07-20 18:06:47.490 [DEBUG] [nding.zigbee.serial.ZigBeeSerialPort] - Serial port [/dev/ttyUSB0] is initialized.
2021-07-20 18:06:49.833 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Ember: Link State change to true, initialised=false, networkStateUp=false
2021-07-20 18:06:49.833 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Ember: Link State change to true ignored.
2021-07-20 18:06:49.845 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspVersionResponse [networkId=0, protocolVersion=4, stackType=2, stackVersion=5810]
2021-07-20 18:06:49.845 [DEBUG] [systems.zigbee.dongle.ember.EmberNcp] - EzspVersionResponse [networkId=0, protocolVersion=4, stackType=2, stackVersion=5810]
2021-07-20 18:06:49.860 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetStandaloneBootloaderVersionPlatMicroPhyResponse [networkId=0, bootloaderVersion=5810, nodePlat=4, nodeMicro=14, nodePhy=3]
2021-07-20 18:06:50.513 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=6]
2021-07-20 18:06:50.513 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_SUPPORTED_NETWORKS = 1
2021-07-20 18:06:50.527 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_MAX_HOPS = 30
2021-07-20 18:06:50.540 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetPolicyResponse [networkId=0, status=EZSP_SUCCESS, decisionId=01]
2021-07-20 18:06:50.621 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Policy state EZSP_MESSAGE_CONTENTS_IN_CALLBACK_POLICY = EZSP_MESSAGE_TAG_ONLY_IN_CALLBACK [40]
2021-07-20 18:06:50.622 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Policy state EZSP_BINDING_MODIFICATION_POLICY = EZSP_DISALLOW_BINDING_MODIFICATION [10]
2021-07-20 18:06:50.623 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Policy state EZSP_APP_KEY_REQUEST_POLICY = EZSP_ALLOW_APP_KEY_REQUESTS [61]
2021-07-20 18:06:50.623 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Policy state EZSP_TC_KEY_REQUEST_POLICY = EZSP_DENY_TC_KEY_REQUESTS [50]
2021-07-20 18:06:50.629 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Policy state EZSP_TRUST_CENTER_POLICY = EZSP_ALLOW_PRECONFIGURED_KEY_JOINS [01]
2021-07-20 18:06:51.204 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
2021-07-20 18:06:51.801 [DEBUG] [systems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=9]
2021-07-20 18:06:51.802 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_SUPPORTED_NETWORKS = 1
2021-07-20 18:06:51.836 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetPolicyResponse [networkId=0, status=EZSP_SUCCESS]
2021-07-20 18:06:52.026 [DEBUG] [systems.zigbee.dongle.ember.EmberNcp] - EzspGetPolicyResponse [networkId=0, status=EZSP_SUCCESS, decisionId=60]
2021-07-20 18:06:52.027 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Policy state EZSP_MESSAGE_CONTENTS_IN_CALLBACK_POLICY = EZSP_MESSAGE_TAG_ONLY_IN_CALLBACK [40]
2021-07-20 18:06:52.027 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Policy state EZSP_BINDING_MODIFICATION_POLICY = EZSP_CHECK_BINDING_MODIFICATIONS_ARE_VALID_ENDPOINT_CLUSTERS [12]
2021-07-20 18:06:52.028 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Policy state EZSP_APP_KEY_REQUEST_POLICY = EZSP_DENY_APP_KEY_REQUESTS [60]
2021-07-20 18:06:52.028 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Policy state EZSP_TC_KEY_REQUEST_POLICY = EZSP_ALLOW_TC_KEY_REQUESTS_AND_SEND_CURRENT_KEY [51]
2021-07-20 18:06:52.029 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Policy state EZSP_TRUST_CENTER_POLICY = EZSP_ALLOW_PRECONFIGURED_KEY_JOINS [01]
2021-07-20 18:06:52.051 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Ember initial network parameters are EmberNetworkParameters [extendedPanId=EEE8BCB7B2C846E6, panId=BC85, radioTxPower=-1, radioChannel=25, joinMethod=EMBER_USE_MAC_ASSOCIATION, nwkManagerId=0000, nwkUpdateId=0, channels=07FFF800]
2021-07-20 18:06:52.051 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetNetworkParametersResponse [networkId=0, status=EMBER_SUCCESS, nodeType=EMBER_COORDINATOR, parameters=EmberNetworkParameters [extendedPanId=EEE8BCB7B2C846E6, panId=BC85, radioTxPower=-1, radioChannel=25, joinMethod=EMBER_USE_MAC_ASSOCIATION, nwkManagerId=0000, nwkUpdateId=0, channels=07FFF800]]
2021-07-20 18:06:52.087 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetEui64Response [networkId=0, eui64=000D6F000DB9E768]
2021-07-20 18:06:52.090 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Ember local IEEE Address is 000D6F000DB9E768
2021-07-20 18:06:52.107 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetNetworkParametersResponse [networkId=0, status=EMBER_SUCCESS, nodeType=EMBER_COORDINATOR, parameters=EmberNetworkParameters [extendedPanId=EEE8BCB7B2C846E6, panId=BC85, radioTxPower=-1, radioChannel=25, joinMethod=EMBER_USE_MAC_ASSOCIATION, nwkManagerId=0000, nwkUpdateId=0, channels=07FFF800]]
2021-07-20 18:06:52.109 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP Dongle: initialize done
2021-07-20 18:06:52.111 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Mesh Update Period 86400
2021-07-20 18:06:52.114 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Adding supported client cluster 0500
2021-07-20 18:06:52.117 [DEBUG] [stems.zigbee.internal.ClusterMatcher] - ClusterMatcher starting for endpoint 1 with profile ID 0104 (ZIGBEE_HOME_AUTOMATION)
2021-07-20 18:06:52.118 [DEBUG] [stems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding client cluster 0500
2021-07-20 18:06:52.119 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Adding supported server cluster 0019
2021-07-20 18:06:52.215 [DEBUG] [stems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding server cluster 0000
2021-07-20 18:06:52.217 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee Initialise: Previous device configuration was: channel=CHANNEL_25, PanID=48261, EPanId=EEE8BCB7B2C846E6
2021-07-20 18:06:52.217 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Config: zigbee_trustcentremode=TC_JOIN_INSECURE
2021-07-20 18:06:52.228 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetPolicyResponse [networkId=0, status=EZSP_SUCCESS]
2021-07-20 18:06:52.232 [DEBUG] [systems.zigbee.dongle.ember.EmberNcp] - EzspSetPolicyResponse [networkId=0, status=EZSP_SUCCESS]
2021-07-20 18:06:52.248 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetConcentratorResponse [networkId=0, status=EZSP_SUCCESS]
2021-07-20 18:06:52.249 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - EzspSetConcentratorResponse [networkId=0, status=EZSP_SUCCESS]
2021-07-20 18:06:52.249 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - ZigBeeNetworkManager startup: reinitialize=false, networkState=INITIALISING
2021-07-20 18:06:52.250 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP Dongle: Startup - reinitialize=false
2021-07-20 18:06:52.251 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP Adding Endpoint: ProfileID=0104, DeviceID=0050
2021-07-20 18:06:52.251 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP Adding Endpoint: Input Clusters 0000
2021-07-20 18:06:52.252 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP Adding Endpoint: Output Clusters 0000
2021-07-20 18:06:52.272 [DEBUG] [systems.zigbee.dongle.ember.EmberNcp] - EzspAddEndpointResponse [networkId=0, status=EZSP_SUCCESS]
2021-07-20 18:06:52.272 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspAddEndpointResponse [networkId=0, status=EZSP_SUCCESS]
2021-07-20 18:06:52.317 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspNetworkInitResponse [networkId=0, status=EMBER_SUCCESS]
2021-07-20 18:06:52.319 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspStackStatusHandler [networkId=0, status=EMBER_NETWORK_UP]
2021-07-20 18:06:52.320 [DEBUG] [systems.zigbee.dongle.ember.EmberNcp] - EzspNetworkInitResponse [networkId=0, status=EMBER_SUCCESS]
2021-07-20 18:06:52.320 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Ember: Link State change to true, initialised=false, networkStateUp=false
2021-07-20 18:06:52.320 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Ember: Link State change to true ignored.
2021-07-20 18:06:52.346 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetCurrentSecurityStateResponse [networkId=0, status=EMBER_SUCCESS, state=EmberCurrentSecurityState [bitmask=[EMBER_GLOBAL_LINK_KEY, EMBER_TRUST_CENTER_USES_HASHED_LINK_KEY, EMBER_HAVE_TRUST_CENTER_LINK_KEY], trustCenterLongAddress=000D6F000DB9E768]]
2021-07-20 18:06:52.347 [DEBUG] [systems.zigbee.dongle.ember.EmberNcp] - EzspGetCurrentSecurityStateResponse [networkId=0, status=EMBER_SUCCESS, state=EmberCurrentSecurityState [bitmask=[EMBER_GLOBAL_LINK_KEY, EMBER_TRUST_CENTER_USES_HASHED_LINK_KEY, EMBER_HAVE_TRUST_CENTER_LINK_KEY], trustCenterLongAddress=000D6F000DB9E768]]
2021-07-20 18:06:52.365 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP networkStateResponse EMBER_JOINED_NETWORK
2021-07-20 18:06:52.385 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetNetworkParametersResponse [networkId=0, status=EMBER_SUCCESS, nodeType=EMBER_COORDINATOR, parameters=EmberNetworkParameters [extendedPanId=EEE8BCB7B2C846E6, panId=BC85, radioTxPower=-1, radioChannel=25, joinMethod=EMBER_USE_MAC_ASSOCIATION, nwkManagerId=0000, nwkUpdateId=0, channels=07FFF800]]
2021-07-20 18:06:52.410 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP networkState after online wait EMBER_JOINED_NETWORK
2021-07-20 18:06:52.432 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetCurrentSecurityStateResponse [networkId=0, status=EMBER_SUCCESS, state=EmberCurrentSecurityState [bitmask=[EMBER_GLOBAL_LINK_KEY, EMBER_TRUST_CENTER_USES_HASHED_LINK_KEY, EMBER_HAVE_TRUST_CENTER_LINK_KEY], trustCenterLongAddress=000D6F000DB9E768]]
2021-07-20 18:06:52.432 [DEBUG] [systems.zigbee.dongle.ember.EmberNcp] - EzspGetCurrentSecurityStateResponse [networkId=0, status=EMBER_SUCCESS, state=EmberCurrentSecurityState [bitmask=[EMBER_GLOBAL_LINK_KEY, EMBER_TRUST_CENTER_USES_HASHED_LINK_KEY, EMBER_HAVE_TRUST_CENTER_LINK_KEY], trustCenterLongAddress=000D6F000DB9E768]]
2021-07-20 18:06:52.433 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP Current Security State = EmberCurrentSecurityState [bitmask=[EMBER_GLOBAL_LINK_KEY, EMBER_TRUST_CENTER_USES_HASHED_LINK_KEY, EMBER_HAVE_TRUST_CENTER_LINK_KEY], trustCenterLongAddress=000D6F000DB9E768]
2021-07-20 18:06:52.449 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetRadioPowerResponse [networkId=0, status=EMBER_SUCCESS]
2021-07-20 18:06:52.469 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetNodeIdResponse [networkId=0, nodeId=0000]
2021-07-20 18:06:52.470 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP Dongle: Startup complete. NWK Address = 0000, State = EMBER_JOINED_NETWORK
2021-07-20 18:06:52.470 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Ember: Link State change to true, initialised=true, networkStateUp=false
2021-07-20 18:06:52.472 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Ember: Link State up running
2021-07-20 18:06:52.496 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSendManyToOneRouteRequestResponse [networkId=0, status=EMBER_SUCCESS]
2021-07-20 18:06:52.497 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Network state is updated to ONLINE
2021-07-20 18:06:52.498 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee initialise done. channel=CHANNEL_25, PanId=48261 EPanId=EEE8BCB7B2C846E6
2021-07-20 18:06:52.500 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Network state ONLINE: Process running. 1 Nodes in network.
2021-07-20 18:06:52.500 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - 000D6F000DB9E768: Adding local node to network, NWK=0000
2021-07-20 18:06:52.501 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - 000D6F000DB9E768: Updating node NWK=0000
2021-07-20 18:06:52.501 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - 000D6F000DB9E768: Node update. NWK Address=0000
2021-07-20 18:06:52.501 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - 000D6F000DB9E768: Node 0000 is not updated
2021-07-20 18:06:52.503 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Permit join to FFFC/0 for 0 seconds.
2021-07-20 18:06:52.511 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - Broadcast: Added transaction to queue, len=1, transaction=ZigBeeTransaction [ieeeAddress=null queueTime=0, state=WAITING, sendCnt=0, command=ManagementPermitJoiningRequest [0000/0 -> FFFC/0, cluster=0036, TID=--, permitDuration=0, tcSignificance=true]]
2021-07-20 18:06:52.532 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetNodeIdResponse [networkId=0, nodeId=0000]
2021-07-20 18:06:52.532 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=0, outstandingQueues=1, sleepy=0/3
2021-07-20 18:06:52.537 [DEBUG] [transaction.ZigBeeTransactionManager] - FFFC/0: Sending ZigBeeTransaction [ieeeAddress=null queueTime=25, state=WAITING, sendCnt=0, command=ManagementPermitJoiningRequest [0000/0 -> FFFC/0, cluster=0036, TID=00, permitDuration=0, tcSignificance=true]]
2021-07-20 18:06:52.538 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 1 outstanding
2021-07-20 18:06:52.544 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - ZigBeeNetworkManager transport state updated to ONLINE
2021-07-20 18:06:52.556 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementPermitJoiningRequest [0000/0 -> FFFC/0, cluster=0036, TID=00, permitDuration=0, tcSignificance=true]
2021-07-20 18:06:52.578 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/0, destinationAddress=FFFC/0, profile=0000, cluster=0036, addressMode=DEVICE, radius=8, apsSecurity=false, ackRequest=true, apsCounter=00, rssi=--, lqi=--, payload=00 00 01]
2021-07-20 18:06:52.592 [DEBUG] [transaction.ZigBeeTransactionManager] - 000D6F000DB9E768: Creating new Transaction Queue
2021-07-20 18:06:52.593 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - 000D6F000DB9E768: Set profile to ZigBeeTransactionProfile [maxOutstandingTransactions=1, interTransactionDelay=50, maxRetries=2]
2021-07-20 18:06:52.594 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - 000D6F000DB9E768: Added transaction to queue, len=1, transaction=ZigBeeTransaction [ieeeAddress=000D6F000DB9E768 queueTime=0, state=WAITING, sendCnt=0, command=ManagementPermitJoiningRequest [0000/0 -> 0000/0, cluster=0036, TID=--, permitDuration=0, tcSignificance=true]]
2021-07-20 18:06:52.594 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=1, outstandingQueues=1, sleepy=0/3
2021-07-20 18:06:52.595 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSendBroadcastResponse [networkId=0, status=EMBER_SUCCESS, sequence=B6]
2021-07-20 18:06:52.595 [DEBUG] [transaction.ZigBeeTransactionManager] - 0000/0: Sending ZigBeeTransaction [ieeeAddress=000D6F000DB9E768 queueTime=1, state=WAITING, sendCnt=0, command=ManagementPermitJoiningRequest [0000/0 -> 0000/0, cluster=0036, TID=01, permitDuration=0, tcSignificance=true]]
2021-07-20 18:06:52.596 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 2 outstanding
2021-07-20 18:06:52.596 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementPermitJoiningRequest [0000/0 -> 0000/0, cluster=0036, TID=01, permitDuration=0, tcSignificance=true]
2021-07-20 18:06:52.597 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/0, destinationAddress=0000/0, profile=0000, cluster=0036, addressMode=DEVICE, radius=8, apsSecurity=false, ackRequest=true, apsCounter=01, rssi=--, lqi=--, payload=01 00 01]
2021-07-20 18:06:52.597 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingMessageHandler [networkId=0, type=EMBER_INCOMING_BROADCAST_LOOPBACK, apsFrame=EmberApsFrame [profileId=0000, clusterId=0036, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=B6], lastHopLqi=255, lastHopRssi=0, sender=0000, bindingIndex=255, addressIndex=255, messageContents=00 00 01]
2021-07-20 18:06:52.608 [DEBUG] [p.discovery.ZigBeeDiscoveryExtension] - DISCOVERY Extension: Startup
2021-07-20 18:06:52.611 [DEBUG] [pp.discovery.ZigBeeNetworkDiscoverer] - Network discovery task: starting
2021-07-20 18:06:52.615 [DEBUG] [pp.discovery.ZigBeeNetworkDiscoverer] - NWK Discovery for 0000 scheduling node discovery
2021-07-20 18:06:52.622 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSendUnicastResponse [networkId=0, status=EMBER_SUCCESS, sequence=B7]
2021-07-20 18:06:52.626 [DEBUG] [pp.discovery.ZigBeeNetworkDiscoverer] - NWK Discovery for 0000 starting node discovery
2021-07-20 18:06:52.628 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Network state ONLINE: Notifying node 000D6F000DB9E768 [0000]
2021-07-20 18:06:52.644 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - 000D6F000DB9E768: Added transaction to queue, len=1, transaction=ZigBeeTransaction [ieeeAddress=000D6F000DB9E768 queueTime=0, state=WAITING, sendCnt=0, command=IeeeAddressRequest [0000/0 -> 0000/0, cluster=0001, TID=--, nwkAddrOfInterest=0000, requestType=1, startIndex=0]]
2021-07-20 18:06:52.645 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=2, outstandingQueues=1, sleepy=0/3
2021-07-20 18:06:52.645 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingMessageHandler [networkId=0, type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0000, clusterId=0036, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=B7], lastHopLqi=255, lastHopRssi=0, sender=0000, bindingIndex=255, addressIndex=255, messageContents=01 00 01]
2021-07-20 18:06:52.648 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=0000/0, destinationAddress=0000/0, profile=0000, cluster=0036, addressMode=DEVICE, radius=0, apsSecurity=false, ackRequest=false, apsCounter=B7, rssi=0, lqi=FF, payload=01 00 01]
2021-07-20 18:06:52.652 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - 000D6F000DB9E768: NodeDescriptor passed to Ember NCP NodeDescriptor [apsFlags=0, bufferSize=82, complexDescriptorAvailable=false, manufacturerCode=ABCD, logicalType=COORDINATOR, serverCapabilities=[PRIMARY_TRUST_CENTER, NETWORK_MANAGER], incomingTransferSize=128, outgoingTransferSize=128, userDescriptorAvailable=false, frequencyBands=[FREQ_2400_MHZ], macCapabilities=[ALTERNATIVE_PAN, FULL_FUNCTION_DEVICE, MAINS_POWER, RECEIVER_ON_WHEN_IDLE], extendedEndpointListAvailable=false, extendedSimpleDescriptorListAvailable=false, stackCompliance=21]
2021-07-20 18:06:52.656 [DEBUG] [atabase.ZigBeeNetworkDatabaseManager] - 000D6F000DB9E768: Data store: Deferring write for 250ms.
2021-07-20 18:06:52.672 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=ONLINE
2021-07-20 18:06:52.673 [DEBUG] [p.discovery.ZigBeeDiscoveryExtension] - DISCOVERY Extension: Starting mesh update
2021-07-20 18:06:52.712 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - 000D6F000DB9E768: Set profile to ZigBeeTransactionProfile [maxOutstandingTransactions=1, interTransactionDelay=50, maxRetries=2]
2021-07-20 18:06:52.751 [DEBUG] [p.discovery.ZigBeeDiscoveryExtension] - 000D6F000DB9E768: DISCOVERY Extension: Adding discoverer for node
2021-07-20 18:06:52.766 [DEBUG] [iscovery.ZigBeeNodeServiceDiscoverer] - 000D6F000DB9E768: Node SVC Discovery: created discoverer
2021-07-20 18:06:52.767 [DEBUG] [iscovery.ZigBeeNodeServiceDiscoverer] - 000D6F000DB9E768: Node SVC Discovery: start discovery
2021-07-20 18:06:52.781 [DEBUG] [iscovery.ZigBeeNodeServiceDiscoverer] - 000D6F000DB9E768: Node SVC Discovery: starting new tasks []
2021-07-20 18:06:52.782 [DEBUG] [iscovery.ZigBeeNodeServiceDiscoverer] - 000D6F000DB9E768: Node SVC Discovery: has no new tasks to perform
2021-07-20 18:06:52.795 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ManagementPermitJoiningRequest [0000/0 -> 0000/0, cluster=0036, TID=01, permitDuration=0, tcSignificance=true]
2021-07-20 18:06:52.796 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: ManagementPermitJoiningRequest [0000/0 -> 0000/0, cluster=0036, TID=01, permitDuration=0, tcSignificance=true]
2021-07-20 18:06:52.809 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingMessageHandler [networkId=0, type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0000, clusterId=8036, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=B8], lastHopLqi=255, lastHopRssi=0, sender=0000, bindingIndex=255, addressIndex=255, messageContents=01 00]
2021-07-20 18:06:52.810 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=0000/0, destinationAddress=0000/0, profile=0000, cluster=8036, addressMode=DEVICE, radius=0, apsSecurity=false, ackRequest=false, apsCounter=B8, rssi=0, lqi=FF, payload=01 00]
2021-07-20 18:06:52.811 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ManagementPermitJoiningResponse [0000/0 -> 0000/0, cluster=8036, TID=01, status=SUCCESS]
2021-07-20 18:06:52.812 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: ManagementPermitJoiningResponse [0000/0 -> 0000/0, cluster=8036, TID=01, status=SUCCESS]
2021-07-20 18:06:52.821 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspMessageSentHandler [networkId=0, type=EMBER_OUTGOING_DIRECT, indexOrDestination=0000, apsFrame=EmberApsFrame [profileId=0000, clusterId=0036, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=B7], messageTag=01, status=EMBER_SUCCESS, messageContents=]
2021-07-20 18:06:52.822 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX STA: msgTag=01 state=RX_ACK
2021-07-20 18:06:52.823 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionProgress: TID=01, state=RX_ACK, outstanding=2
2021-07-20 18:06:52.829 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=000D6F000DB9E768 queueTime=235, state=COMPLETE, sendCnt=1, command=ManagementPermitJoiningRequest [0000/0 -> 0000/0, cluster=0036, TID=01, permitDuration=0, tcSignificance=true]]
2021-07-20 18:06:52.830 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 1 outstanding
2021-07-20 18:06:52.830 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - 000D6F000DB9E768: transactionComplete, state=COMPLETE, outstanding=0
2021-07-20 18:06:52.830 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=1, outstandingQueues=1, sleepy=0/3
2021-07-20 18:06:52.831 [DEBUG] [transaction.ZigBeeTransactionManager] - 0000/0: Sending ZigBeeTransaction [ieeeAddress=000D6F000DB9E768 queueTime=187, state=WAITING, sendCnt=0, command=IeeeAddressRequest [0000/0 -> 0000/0, cluster=0001, TID=02, nwkAddrOfInterest=0000, requestType=1, startIndex=0]]
2021-07-20 18:06:52.831 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 2 outstanding
2021-07-20 18:06:52.844 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: IeeeAddressRequest [0000/0 -> 0000/0, cluster=0001, TID=02, nwkAddrOfInterest=0000, requestType=1, startIndex=0]
2021-07-20 18:06:52.844 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/0, destinationAddress=0000/0, profile=0000, cluster=0001, addressMode=DEVICE, radius=8, apsSecurity=false, ackRequest=true, apsCounter=02, rssi=--, lqi=--, payload=02 00 00 01 00]
2021-07-20 18:06:52.856 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction state changed: nwk=0000, TID=01, event=RX_ACK, state=COMPLETE
2021-07-20 18:06:52.857 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSendUnicastResponse [networkId=0, status=EMBER_SUCCESS, sequence=B9]
2021-07-20 18:06:52.880 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingMessageHandler [networkId=0, type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0000, clusterId=0001, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=B9], lastHopLqi=255, lastHopRssi=0, sender=0000, bindingIndex=255, addressIndex=255, messageContents=02 00 00 01 00]
2021-07-20 18:06:52.881 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=0000/0, destinationAddress=0000/0, profile=0000, cluster=0001, addressMode=DEVICE, radius=0, apsSecurity=false, ackRequest=false, apsCounter=B9, rssi=0, lqi=FF, payload=02 00 00 01 00]
2021-07-20 18:06:52.882 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: IeeeAddressRequest [0000/0 -> 0000/0, cluster=0001, TID=02, nwkAddrOfInterest=0000, requestType=1, startIndex=0]
2021-07-20 18:06:52.882 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: IeeeAddressRequest [0000/0 -> 0000/0, cluster=0001, TID=02, nwkAddrOfInterest=0000, requestType=1, startIndex=0]
2021-07-20 18:06:52.883 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingMessageHandler [networkId=0, type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0000, clusterId=8001, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=BA], lastHopLqi=255, lastHopRssi=0, sender=0000, bindingIndex=255, addressIndex=255, messageContents=02 00 68 E7 B9 0D 00 6F 0D 00 00 00 00]
2021-07-20 18:06:52.884 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=0000/0, destinationAddress=0000/0, profile=0000, cluster=8001, addressMode=DEVICE, radius=0, apsSecurity=false, ackRequest=false, apsCounter=BA, rssi=0, lqi=FF, payload=02 00 68 E7 B9 0D 00 6F 0D 00 00 00 00]
2021-07-20 18:06:52.885 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: IeeeAddressResponse [0000/0 -> 0000/0, cluster=8001, TID=02, status=SUCCESS, ieeeAddrRemoteDev=000D6F000DB9E768, nwkAddrRemoteDev=0000, startIndex=null, nwkAddrAssocDevList=[]]
2021-07-20 18:06:52.886 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: IeeeAddressResponse [0000/0 -> 0000/0, cluster=8001, TID=02, status=SUCCESS, ieeeAddrRemoteDev=000D6F000DB9E768, nwkAddrRemoteDev=0000, startIndex=null, nwkAddrAssocDevList=[]]
2021-07-20 18:06:52.893 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=000D6F000DB9E768 queueTime=248, state=COMPLETE, sendCnt=1, command=IeeeAddressRequest [0000/0 -> 0000/0, cluster=0001, TID=02, nwkAddrOfInterest=0000, requestType=1, startIndex=0]]
2021-07-20 18:06:52.893 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 1 outstanding
2021-07-20 18:06:52.893 [DEBUG] [pp.discovery.ZigBeeNetworkDiscoverer] - NWK Discovery for 0000 IeeeAddressRequest returned IeeeAddressResponse [0000/0 -> 0000/0, cluster=8001, TID=02, status=SUCCESS, ieeeAddrRemoteDev=000D6F000DB9E768, nwkAddrRemoteDev=0000, startIndex=null, nwkAddrAssocDevList=[]]
2021-07-20 18:06:52.894 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - 000D6F000DB9E768: transactionComplete, state=COMPLETE, outstanding=0
2021-07-20 18:06:52.894 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=1, outstandingQueues=0, sleepy=0/3
2021-07-20 18:06:52.895 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspMessageSentHandler [networkId=0, type=EMBER_OUTGOING_DIRECT, indexOrDestination=0000, apsFrame=EmberApsFrame [profileId=0000, clusterId=0001, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=B9], messageTag=02, status=EMBER_SUCCESS, messageContents=]
2021-07-20 18:06:52.895 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX STA: msgTag=02 state=RX_ACK
2021-07-20 18:06:52.895 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionProgress: TID=02, state=RX_ACK, outstanding=1
2021-07-20 18:06:52.907 [DEBUG] [atabase.ZigBeeNetworkDatabaseManager] - 000D6F000DB9E768: Data store: Writing node.
2021-07-20 18:06:52.953 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - 000D6F000DB9E768: ZigBee saving network state complete.
2021-07-20 18:06:53.629 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspMessageSentHandler [networkId=0, type=EMBER_OUTGOING_BROADCAST, indexOrDestination=FFFC, apsFrame=EmberApsFrame [profileId=0000, clusterId=0036, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=B6], messageTag=00, status=EMBER_DELIVERY_FAILED, messageContents=]
2021-07-20 18:06:53.629 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX STA: msgTag=00 state=RX_NAK
2021-07-20 18:06:53.630 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionProgress: TID=00, state=RX_NAK, outstanding=1
2021-07-20 18:06:53.630 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=null queueTime=1119, state=FAILED, sendCnt=1, command=ManagementPermitJoiningRequest [0000/0 -> FFFC/0, cluster=0036, TID=00, permitDuration=0, tcSignificance=true]]
2021-07-20 18:06:53.630 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 0 outstanding
2021-07-20 18:06:53.631 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - Broadcast: transactionComplete, state=FAILED, outstanding=0
2021-07-20 18:06:53.631 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - Broadcast: transactionComplete exceeded max retries 1
2021-07-20 18:06:53.631 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction cancelled: ZigBeeTransaction [ieeeAddress=null queueTime=1120, state=CANCELLED, sendCnt=1, command=ManagementPermitJoiningRequest [0000/0 -> FFFC/0, cluster=0036, TID=00, permitDuration=0, tcSignificance=true]]
2021-07-20 18:06:53.632 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=null queueTime=1120, state=CANCELLED, sendCnt=1, command=ManagementPermitJoiningRequest [0000/0 -> FFFC/0, cluster=0036, TID=00, permitDuration=0, tcSignificance=true]]
2021-07-20 18:06:53.632 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 0 outstanding
2021-07-20 18:06:53.632 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - Broadcast: transactionComplete but not outstanding, state=CANCELLED, outstanding=0
2021-07-20 18:06:53.632 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=0, outstandingQueues=0, sleepy=0/3
2021-07-20 18:06:53.633 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=0, outstandingQueues=0, sleepy=0/3
2021-07-20 18:06:53.633 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction state changed: nwk=FFFC, TID=00, event=RX_NAK, state=CANCELLED
When I start the scanning for new ZigBee devices in OH, I see the following log entries:
2021-07-20 18:13:40.185 [DEBUG] [bee.discovery.ZigBeeDiscoveryService] - Starting ZigBee scan for zigbee:coordinator_ember:c7b0cb48f4
2021-07-20 18:13:40.187 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Permit join to FFFC/0 for 60 seconds.
2021-07-20 18:13:40.188 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - Broadcast: Added transaction to queue, len=1, transaction=ZigBeeTransaction [ieeeAddress=null queueTime=0, state=WAITING, sendCnt=0, command=ManagementPermitJoiningRequest [0000/0 -> FFFC/0, cluster=0036, TID=--, permitDuration=60, tcSignificance=true]]
2021-07-20 18:13:40.189 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=0, outstandingQueues=1, sleepy=0/3
2021-07-20 18:13:40.190 [DEBUG] [transaction.ZigBeeTransactionManager] - FFFC/0: Sending ZigBeeTransaction [ieeeAddress=null queueTime=2, state=WAITING, sendCnt=0, command=ManagementPermitJoiningRequest [0000/0 -> FFFC/0, cluster=0036, TID=03, permitDuration=60, tcSignificance=true]]
2021-07-20 18:13:40.190 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 1 outstanding
2021-07-20 18:13:40.191 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementPermitJoiningRequest [0000/0 -> FFFC/0, cluster=0036, TID=03, permitDuration=60, tcSignificance=true]
2021-07-20 18:13:40.192 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/0, destinationAddress=FFFC/0, profile=0000, cluster=0036, addressMode=DEVICE, radius=8, apsSecurity=false, ackRequest=true, apsCounter=03, rssi=--, lqi=--, payload=03 3C 01]
2021-07-20 18:13:40.193 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - 000D6F000DB9E768: Added transaction to queue, len=1, transaction=ZigBeeTransaction [ieeeAddress=000D6F000DB9E768 queueTime=0, state=WAITING, sendCnt=0, command=ManagementPermitJoiningRequest [0000/0 -> 0000/0, cluster=0036, TID=--, permitDuration=60, tcSignificance=true]]
2021-07-20 18:13:40.194 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=1, outstandingQueues=1, sleepy=0/3
2021-07-20 18:13:40.198 [DEBUG] [transaction.ZigBeeTransactionManager] - 0000/0: Sending ZigBeeTransaction [ieeeAddress=000D6F000DB9E768 queueTime=5, state=WAITING, sendCnt=0, command=ManagementPermitJoiningRequest [0000/0 -> 0000/0, cluster=0036, TID=04, permitDuration=60, tcSignificance=true]]
2021-07-20 18:13:40.199 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 2 outstanding
2021-07-20 18:13:40.200 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementPermitJoiningRequest [0000/0 -> 0000/0, cluster=0036, TID=04, permitDuration=60, tcSignificance=true]
2021-07-20 18:13:40.201 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/0, destinationAddress=0000/0, profile=0000, cluster=0036, addressMode=DEVICE, radius=8, apsSecurity=false, ackRequest=true, apsCounter=04, rssi=--, lqi=--, payload=04 3C 01]
2021-07-20 18:13:40.213 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSendBroadcastResponse [networkId=0, status=EMBER_SUCCESS, sequence=BB]
2021-07-20 18:13:40.214 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingMessageHandler [networkId=0, type=EMBER_INCOMING_BROADCAST_LOOPBACK, apsFrame=EmberApsFrame [profileId=0000, clusterId=0036, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=BB], lastHopLqi=255, lastHopRssi=0, sender=0000, bindingIndex=255, addressIndex=255, messageContents=03 3C 01]
2021-07-20 18:13:40.254 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSendUnicastResponse [networkId=0, status=EMBER_SUCCESS, sequence=BC]
2021-07-20 18:13:40.275 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingMessageHandler [networkId=0, type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0000, clusterId=0036, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=BC], lastHopLqi=255, lastHopRssi=0, sender=0000, bindingIndex=255, addressIndex=255, messageContents=04 3C 01]
2021-07-20 18:13:40.276 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=0000/0, destinationAddress=0000/0, profile=0000, cluster=0036, addressMode=DEVICE, radius=0, apsSecurity=false, ackRequest=false, apsCounter=BC, rssi=0, lqi=FF, payload=04 3C 01]
2021-07-20 18:13:40.278 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ManagementPermitJoiningRequest [0000/0 -> 0000/0, cluster=0036, TID=04, permitDuration=60, tcSignificance=true]
2021-07-20 18:13:40.278 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: ManagementPermitJoiningRequest [0000/0 -> 0000/0, cluster=0036, TID=04, permitDuration=60, tcSignificance=true]
2021-07-20 18:13:40.280 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingMessageHandler [networkId=0, type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0000, clusterId=8036, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=BD], lastHopLqi=255, lastHopRssi=0, sender=0000, bindingIndex=255, addressIndex=255, messageContents=04 00]
2021-07-20 18:13:40.280 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=0000/0, destinationAddress=0000/0, profile=0000, cluster=8036, addressMode=DEVICE, radius=0, apsSecurity=false, ackRequest=false, apsCounter=BD, rssi=0, lqi=FF, payload=04 00]
2021-07-20 18:13:40.281 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ManagementPermitJoiningResponse [0000/0 -> 0000/0, cluster=8036, TID=04, status=SUCCESS]
2021-07-20 18:13:40.281 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: ManagementPermitJoiningResponse [0000/0 -> 0000/0, cluster=8036, TID=04, status=SUCCESS]
2021-07-20 18:13:40.283 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspMessageSentHandler [networkId=0, type=EMBER_OUTGOING_DIRECT, indexOrDestination=0000, apsFrame=EmberApsFrame [profileId=0000, clusterId=0036, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=BC], messageTag=04, status=EMBER_SUCCESS, messageContents=]
2021-07-20 18:13:40.283 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX STA: msgTag=04 state=RX_ACK
2021-07-20 18:13:40.284 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionProgress: TID=04, state=RX_ACK, outstanding=2
2021-07-20 18:13:40.284 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=000D6F000DB9E768 queueTime=91, state=COMPLETE, sendCnt=1, command=ManagementPermitJoiningRequest [0000/0 -> 0000/0, cluster=0036, TID=04, permitDuration=60, tcSignificance=true]]
2021-07-20 18:13:40.285 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 1 outstanding
2021-07-20 18:13:40.285 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - 000D6F000DB9E768: transactionComplete, state=COMPLETE, outstanding=0
2021-07-20 18:13:40.286 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=1, outstandingQueues=0, sleepy=0/3
2021-07-20 18:13:40.286 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction state changed: nwk=0000, TID=04, event=RX_ACK, state=COMPLETE
2021-07-20 18:13:41.158 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspMessageSentHandler [networkId=0, type=EMBER_OUTGOING_BROADCAST, indexOrDestination=FFFC, apsFrame=EmberApsFrame [profileId=0000, clusterId=0036, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=BB], messageTag=03, status=EMBER_DELIVERY_FAILED, messageContents=]
2021-07-20 18:13:41.159 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX STA: msgTag=03 state=RX_NAK
2021-07-20 18:13:41.160 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionProgress: TID=03, state=RX_NAK, outstanding=1
2021-07-20 18:13:41.161 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=null queueTime=973, state=FAILED, sendCnt=1, command=ManagementPermitJoiningRequest [0000/0 -> FFFC/0, cluster=0036, TID=03, permitDuration=60, tcSignificance=true]]
2021-07-20 18:13:41.162 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 0 outstanding
2021-07-20 18:13:41.162 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - Broadcast: transactionComplete, state=FAILED, outstanding=0
2021-07-20 18:13:41.162 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - Broadcast: transactionComplete exceeded max retries 1
2021-07-20 18:13:41.163 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction cancelled: ZigBeeTransaction [ieeeAddress=null queueTime=975, state=CANCELLED, sendCnt=1, command=ManagementPermitJoiningRequest [0000/0 -> FFFC/0, cluster=0036, TID=03, permitDuration=60, tcSignificance=true]]
2021-07-20 18:13:41.163 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=null queueTime=975, state=CANCELLED, sendCnt=1, command=ManagementPermitJoiningRequest [0000/0 -> FFFC/0, cluster=0036, TID=03, permitDuration=60, tcSignificance=true]]
2021-07-20 18:13:41.163 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 0 outstanding
2021-07-20 18:13:41.164 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - Broadcast: transactionComplete but not outstanding, state=CANCELLED, outstanding=0
2021-07-20 18:13:41.164 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=0, outstandingQueues=0, sleepy=0/3
2021-07-20 18:13:41.165 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=0, outstandingQueues=0, sleepy=0/3
2021-07-20 18:13:41.165 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction state changed: nwk=FFFC, TID=03, event=RX_NAK, state=CANCELLED
While scanning is in progress, I try to set the ZigBee device in JOIN mode, but nothing happens - no logging, no device found while scanning. My first guess was a problem with my smart blind wand and so I’ve bought a cheap ZigBee smart plug to try it with a different device. But same problem, nothing found!
I’ve tried to play around with different ZigBee channels (because of possible Wi-Fi interference), also changed join modes secure to insecure and other things, but nothing helped so far. Usually I set up all things manually via things file, but after that fails I’ve also tried it with the GUI, but also without success. Here is the thing definition used with my last test:
UID: zigbee:coordinator_ember:c7b0cb48f4
label: Ember EM35x Coordinator
thingTypeUID: zigbee:coordinator_ember
configuration:
zigbee_port: /dev/ttyUSB0
zigbee_initialise: false
zigbee_channel: 25
zigbee_concentrator: 1
zigbee_trustcentremode: TC_JOIN_INSECURE
zigbee_extendedpanid: EEE8BCB7B2C846E6
zigbee_flowcontrol: 2
zigbee_baud: 57600
zigbee_panid: 48261
zigbee_powermode: 1
zigbee_txpower: 0
zigbee_networksize: 25
zigbee_linkkey: 5A6967426565416C6C69616E63653039
zigbee_childtimeout: 86400
zigbee_networkkey: A72D3A4D4425C3F891CCD1587A1326F4
zigbee_meshupdateperiod: 86400
Does somebody has any idea what may cause this problem?
Btw, does anyone know about the blue status LED on this ZigBee stick, it stays always on - no blinking, no color changing, etc. - is this usual? On my Z-Wave stick, I can see status information on the LED, but not on this ZigBee stick…
Thank’s in advance,
Frank
