Zigbee Tuya devices integration with SLZB-06M coordinator
Dear Community, Happy New Year to you All !!
I have an unclear image of what is the right setup to have Tuya Zigbee devices controlled with OH 4.3.1 with SLZB-06M coordinator. I tried to find the answer in the community discussions but haven’t found the answers, my apologize if its there and missed it.
Current setup:
  • OH 4.3.1 running on Qnap in Docker
  • Tuya Binding installed and online (including cloud account)
  • Zigbee Binding installed
  • SLZB06M Coordinator as Thing online in OH
My question is:
  • with the above setup, is it possible to have Tuya zigbee devices controlled with OH?
    a. If YES: is this setup complete, or do I need to add something else to it?
    b. If YES: even those devices marked as compatible only with Tuya zigbee gateway?
Thank you kindly for your answer(s), if there is already a topic answering this question, thanks to direct me to it.
Many thanks!
I will leave my own answer here, for those who might struggle with the same questions :grin:
The short aswer is that you don’t need anything else beside the zigbee coordinator and binding (great binding by the way!!!).
You just have to have the coordinator online and Allow all joins (at least for me this was the turning point).
Tuya zigbee devices are discovered, connected and in some cases using some transformation addons, you can use all their functions ( no need for mqtt broker or z2m or whaever).
Thanks for the great support of this community!
