I am moving from openhab 2 to openhab 4. During this change, I replaced all my rollershutter modules working on enocean to the same model but on zigbee.
I planned to used the homeassistant compatibility from zigbee2mqtt and openhab for easy setup.
I fact, it does not work out of the box because things are always offline.
Anotehr issue (for me) is that MQTT topics are using the IEEE address of the module. I prefer to use the friendly name of course (also because I use several other zigbee devices that can be replaced/moved, like bulbs or sensors).
I tried to use the MQTT thing directly, with partial success. Thing definition is like this :
UID: mqtt:topic:mosquitto:volet_cuisine
label: Volet Cuisine
thingTypeUID: mqtt:topic
configuration:
payloadNotAvailable: '{"state":"offline"}'
availabilityTopic: zigbee2mqtt/volet_cuisine/availability
payloadAvailable: '{"state":"online"}'
bridgeUID: mqtt:broker:mosquitto
channels:
- id: volet_cuisine_position
channelTypeUID: mqtt:rollershutter
label: Volet Cuisine Position
configuration:
commandTopic: zigbee2mqtt/volet_cuisine/set/position
stop: STOP
stateTopic: zigbee2mqtt/volet_cuisine/position
off: "100.0"
on: "0.0"
Why partial success ? Because the STOP command cannot be handled through the position topic.
So I edited the thing definition :
configuration:
channels:
configuration:
commandTopic: zigbee2mqtt/volet_cuisine/set/position_proxy
stop: STOP
off: "100.0"
on: "0.0"
Then I use NodeRED to convert the command if it catches a “STOP” and send to correct topic.
Easy, but this setup relies on 4 pieces of software : OpenHAB, Mosquitto, Z2M and NodeRED
It works, but do you think I can avoid the NodeRED part ?
I already tried formatBeforePublish
, but it is not supported on rollershutter.
