Hello,I searched in vain how to write a post, that’s why I write to you directly inbox
i have problem with zigbee2mqtt.
i use xiaomi aqara device. For aqara switch, (wall switch, socket plug, wireless switch).. i don’t understand how to send command. i can’t control device via openhab. please help
.thing file
Bridge mqtt:broker:mybroker [ host="localhost", port=1883, secure=false ]
// Door sensors
Thing topic doorsensor1 "doorsensor1" {
Channels:
Type contact : contact "Contact" [ stateTopic="zigbee2mqtt/doorsensor1", transformationPattern="JS:getZigbeeContact2Contact.js"]
Type number : voltage "Voltage" [ stateTopic="zigbee2mqtt/doorsensor1", transformationPattern="JSONPATH:$.voltage"]
Type number : battery "Battery" [ stateTopic="zigbee2mqtt/doorsensor1", transformationPattern="JSONPATH:$.battery"]
Type number : linkquality "Linkquality" [ stateTopic="zigbee2mqtt/doorsensor1", transformationPattern="JSONPATH:$.linkquality" ]
Thing topic wirelessdoubleswitch1 "wirelessdoubleswitch1" {
Channels:
Type string : click "Click" [ stateTopic="zigbee2mqtt/wirelessdoubleswitch1", commandTopic="zigbee2mqtt/wirelessdoubleswitch1/system/set", transformationPattern="JS:getZigbeeClick.js" ]
Type number : voltage "Voltage" [ stateTopic="zigbee2mqtt/wirelessdoubleswitch1", transformationPattern="JSONPATH:$.voltage" ]
Type number : battery "Battery" [ stateTopic="zigbee2mqtt/wirelessdoubleswitch1", transformationPattern="JSONPATH:$.battery" ]
Type number : linkquality "Linkquality" [ stateTopic="zigbee2mqtt/wirelessdoubleswitch1", transformationPattern="JSONPATH:$.linkquality" ]
Thing topic wallsocketplug1 "wallsocketplug1" {
Channels:
Type switch : command "State" [ stateTopic="zigbee2mqtt/wallsocketplug1", commandTopic="zigbee2mqtt/wallsocketplug1/system/set", transformationPattern="JSONPATH:$.power" ]
Type number : power "Power" [ stateTopic="zigbee2mqtt/wallsocketplug1", transformationPattern="JSONPATH:$.power"]
Type number : voltage "Voltage" [ stateTopic="zigbee2mqtt/wallsocketplug1", transformationPattern="JSONPATH:$.consumption" ]
Type number : temperature "Temperature" [ stateTopic="zigbee2mqtt/wallsocketplug1", transformationPattern="JSONPATH:$.temperature"]
Type number : battery "Battery" [ stateTopic="zigbee2mqtt/wallsocketplug1", transformationPattern="JSONPATH:$.battery" ]
Type number : linkquality "Linkquality" [ stateTopic="zigbee2mqtt/wallsocketplug1", transformationPattern="JSONPATH:$.linkquality" ]
Thing topic wallsingleswitch1 "wallsingleswitch1" {
Channels:
Type switch : command "State" [ stateTopic="zigbee2mqtt/wallsingleswitch1", commandTopic="zigbee2mqtt/wallsingleswitch1/state" ]
Type number : power "Power" [ stateTopic="zigbee2mqtt/wallsingleswitch1", transformationPattern="JSONPATH:$.power"]
Type number : voltage "Voltage" [ stateTopic="zigbee2mqtt/wallsingleswitch1", transformationPattern="JSONPATH:$.consumption" ]
Type number : temperature "Temperature" [ stateTopic="zigbee2mqtt/wallsingleswitch1", transformationPattern="JSONPATH:$.temperature"]
Type number : battery "Battery" [ stateTopic="zigbee2mqtt/wallsingleswitch1", transformationPattern="JSONPATH:$.battery" ]
Type number : linkquality "Linkquality" [ stateTopic="zigbee2mqtt/wallsingleswitch1", transformationPattern="JSONPATH:$.linkquality" ]
Thing topic aqaradoorsensor2 "Door Sensor 2" @ "Upper Floor" {
Channels:
Type contact : status "Status" [ stateTopic="mqtt/zigbee2mqtt/Aqara_DoorSensor2", transformationPattern="JS:doorsensor.js" ]
Type number : voltage "Voltage"[ stateTopic="mqtt/zigbee2mqtt/Aqara_DoorSensor2", transformationPattern="JSONPATH:$.voltage" ]
Type number : battery "Battery"[ stateTopic="mqtt/zigbee2mqtt/Aqara_DoorSensor2", transformationPattern="JSONPATH:$.battery" ]
Type number : linkquality "RSSI"[ stateTopic="mqtt/zigbee2mqtt/Aqara_DoorSensor2", transformationPattern="JSONPATH:$.linkquality" ]
// Weather sensors
Thing topic humiditysensor1 "humiditysensor1" {
Channels:
Type number : temperature "Temperature" [ stateTopic="zigbee2mqtt/humiditysensor1", transformationPattern="JSONPATH:$.temperature"]
Type number : humidity "Humidity" [ stateTopic="zigbee2mqtt/humiditysensor1", transformationPattern="JSONPATH:$.humidity"]
Type number : pressure "Pressure" [ stateTopic="zigbee2mqtt/humiditysensor1", transformationPattern="JSONPATH:$.pressure"]
Type number : voltage "Voltage" [ stateTopic="zigbee2mqtt/humiditysensor1", transformationPattern="JSONPATH:$.voltage"]
Type number : battery "Battery" [ stateTopic="zigbee2mqtt/humiditysensor1", transformationPattern="JSONPATH:$.battery"]
Type number : linkquality "Linkquality" [ stateTopic="zigbee2mqtt/humiditysensor1", transformationPattern="JSONPATH:$.linkquality" ]
//Motion sensors
Thing topic motionsensor1 "motionsensor1" {
Channels:
Type switch : motion "Motion" [ stateTopic="zigbee2mqtt/motionsensor1", transformationPattern="JS:getZigbeeOccupancy2Switch.js"]
Type number : brightness "Brightness" [ stateTopic="zigbee2mqtt/motionsensor1", transformationPattern="JSONPATH:$.illuminance"]
Type number : voltage "Voltage" [ stateTopic="zigbee2mqtt/motionsensor1", transformationPattern="JSONPATH:$.voltage"]
Type number : battery "Battery" [ stateTopic="zigbee2mqtt/motionsensor1", transformationPattern="JSONPATH:$.battery"]
Type number : linkquality "Linkquality" [ stateTopic="zigbee2mqtt/motionsensor1", transformationPattern="JSONPATH:$.linkquality" ]
//Water Sensors
Thing topic watersensormeteringcloset "WaterSensorMeteringCloset" {
Channels:
Type contact : contact "Contact" [ stateTopic="zigbee2mqtt/LeakageMeteringCloset", transformationPattern="JS:getZigbeeLeak2Contact.js"]
Type number : voltage "Voltage" [ stateTopic="zigbee2mqtt/LeakageMeteringCloset", transformationPattern="JSONPATH:$.voltage"]
Type number : battery "Battery" [ stateTopic="zigbee2mqtt/LeakageMeteringCloset", transformationPattern="JSONPATH:$.battery"]
.items
// Xiaomi Aqara wireless buttons WXKG01LM
Group gZigbeeButton "Zigbee Buttons"
String WirelessDoubleSwitch1Button "Click [%s]" <button> (gZigbeeButton) ["Switchable"] { channel="mqtt:topic:mybroker:wirelessdoubleswitch1:click" }
Number WirelessDoubleSwitch1LinkQuality "Réseau [%d]" <network> (gZigbeeButton) { channel="mqtt:topic:mybroker:wirelessdoubleswitch1:linkquality" }
Number WirelessDoubleSwitch1Voltage "Voltage [%d mV]" <energy> (gZigbeeButton) { channel="mqtt:topic:mybroker:wirelessdoubleswitch1:voltage" }
Number WirelessDoubleSwitch1Battery "Batterie [%.1f %%]" <battery> (gZigbeeButton) { channel="mqtt:topic:mybroker:wirelessdoubleswitch1:battery" }
// Xiaomi Aqara temperature, humidity and pressure sensor WSDCGQ11LM
Group gZigbeeSensor "Zigbee Sensors"
Number HumiditySensor1Temperature "Temperature [%.2f °C]" <temperature> (gZigbeeSensor) ["CurrentTemperature"] { channel="mqtt:topic:mybroker:humiditysensor1:temperature" }
Number HumiditySensor1Humidity "Humidité [%.2f %%]" <humidity> (gZigbeeSensor) ["CurrentHumidity"] { channel="mqtt:topic:mybroker:humiditysensor1:humidity" }
Number HumiditySensor1Pressure "Pression [%d hPa]" <pressure> (gZigbeeSensor) { channel="mqtt:topic:mybroker:humiditysensor1:pressure" }
Number HumiditySensor1Voltage "Voltage [%d mV]" <energy> (gZigbeeSensor) { channel="mqtt:topic:mybroker:humiditysensor1:voltage" }
Number HumiditySensor1Battery "Batterie [%.1f %%]" <battery> (gZigbeeSensor) { channel="mqtt:topic:mybroker:humiditysensor1:battery" }
Number HumiditySensor1LinkQuality "Réseau [%d]" <qualityofservice> (gZigbeeSensor) { channel="mqtt:topic:mybroker:humiditysensor1:linkquality" }
Contact DoorSensor1 "Porte [%s]" <door> (gZigbeeSensor) ["Switchable"] { channel="mqtt:topic:mybroker:doorsensor1:contact" }
Number DoorSensor1Voltage "Voltage [%d mV]" <energy> (gZigbeeSensor) { channel="mqtt:topic:mybroker:doorsensor1:voltage" }
Number DoorSensor1Battery "Batterie [%.1f %%]" <battery> (gZigbeeSensor) { channel="mqtt:topic:mybroker:doorsensor1:battery" }
Number Doorsensor1LinkQuality "Réseau [%d]" <qualityofservice> (gZigbeeSensor) { channel="mqtt:topic:mybroker:doorsensor1:linkquality" }
String MotionSensor1 "Mouvement [%s]" <motion> (gZigbeeSensor) ["Switchable"] { channel="mqtt:topic:mybroker:motionsensor1:motion" }
Number MotionSensor1Brightness "Luminescance [%d lumen]" <sun> (gZigbeeSensor) { channel="mqtt:topic:mybroker:motionsensor1:brightness" }
Number MotionSensor1Voltage "Voltage [%d mV]" <energy> (gZigbeeSensor) { channel="mqtt:topic:mybroker:motionsensor1:voltage" }
Number MotionSensor1Battery "Batterie [%.1f %%]" <battery> (gZigbeeSensor) { channel="mqtt:topic:mybroker:motionsensor1:battery" }
Number MotionSensor1LinkQuality "Réseau [%d]" <qualityofservice> (gZigbeeSensor) { channel="mqtt:topic:mybroker:motionsensor1:linkquality" }
Switch WallSocketPlug1 "Etat [%s]" <poweroutlet_eu> (gZigbeeSensor) ["Switchable"] { channel="mqtt:topic:mybroker:wallsocketplug1:command" }
Number WallSocketPlug1Power "Puissance [%d watt]" <line> (gZigbeeSensor) { channel="mqtt:topic:mybroker:wallsocketplug1:power" }
Number WallSocketPlug1Voltage "Voltage [%d mV]" <energy> (gZigbeeSensor) { channel="mqtt:topic:mybroker:wallsocketplug1:voltage" }
Number WallSocketPlug1Temperature "Temperature [%.2f °C]" <temperature> (gZigbeeSensor) { channel="mqtt:topic:mybroker:wallsocketplug1:temperature" }
Number WallSocketPlug1Consumption "Batterie [%.1f %%]" <line> (gZigbeeSensor) { channel="mqtt:topic:mybroker:wallsocketplug1:consumption" }
Number WallSocketPlug1LinkQuality "Réseau [%d]" <qualityofservice> (gZigbeeSensor) { channel="mqtt:topic:mybroker:wallsocketplug1:linkquality" }
Switch WallSingleSwitch1 "Etat [%s]" <light> (gZigbeeSensor) ["Switchable"] { channel="mqtt:topic:mybroker:wallsingleswitch1:command:ON" }
Number WallSingleSwitch1Power "Puissance [%d watt]" <line> (gZigbeeSensor) { channel="mqtt:topic:mybroker:wallsingleswitch1:power" }
Number WallSingleSwitch1Voltage "Voltage [%d mV]" <energy> (gZigbeeSensor) { channel="mqtt:topic:mybroker:wallsingleswitch1:voltage" }
Number WallSingleSwitch1Temperature "Temperature [%.2f °C]" <temperature> (gZigbeeSensor) { channel="mqtt:topic:mybroker:wallsingleswitch1:temperature" }
Number WallSingleSwitch1Consumption "Batterie [%.1f %%]" <line> (gZigbeeSensor) { channel="mqtt:topic:mybroker:wallsingleswitch1:consumption" }
Number WallSingleSwitch1LinkQuality "Réseau [%d]" <qualityofservice> (gZigbeeSensor) { channel="mqtt:topic:mybroker:wallsingleswitch1:linkquality" }
