Hi all,
i am using Zigbee2MQTT with the Homeassistant integration, to get auto discovery within openHAB (version 4.2.2).
That works pretty well, but since some days (I’ve added another sensor in Zigbee2MQTT) I am getting this error message, when sending a new value to my thermostats:
[WARN ] [mqtt.generic.AbstractMQTTThingHandler] - Channel mqtt:homeassistant_zigbee2mqtt_5F0x54ef441000b8386b:79a431fa3b:zigbee2mqtt_5F0x54ef441000b8386b:temperature not supported!
Zigbee2MQTT is working fine. Curious is, that another thermostat is working correctly (same modell). Temperatur sensors working also fine.
What could be the problem? I’ve restartet everything a couple time (openHAB, Zigbee2MQTT, Mosqitto, the complete raspberry) and also deleted the thing and recreated it via auto discovery…
Thanks for any tips,
Vincent
