Zigbee2Mqtt - error: z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
I upgraded from OH 4 to 5 now and I have a lot of trouble getting ZIGBEE2MQTT to work. I´m using a Sonoff Dongle-P, flashed the latest firmware and I can´t get it to work with Zigbee2Mqtt, always getting this error:
I can easily shutdown my pi and switch back to my OH 4 Installation and the Zigbee2Mqtt and the dongle work flawless, so it´s no technical malfunction.
Here is my configuration.yaml:
version: 4
mqtt:
  base_topic: zigbee2mqtt
  server: mqtt://localhost:1883
  user: XXX
  password: 'XXX'
serial:
  port: /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_a40d71e4ea93eb11810ba85b3d98b6d1-if00-port0
  adapter: zstack
  baudrate: 115200
  rtscts: false
advanced:
  network_key:
    - 72
    - 162
    - 196
    - 72
    - 249
    - 85
    - 238
    - 111
    - 193
    - 89
    - 94
    - 244
    - 15
    - 169
    - 31
    - 26
  pan_id: 16782
  ext_pan_id:
    - 106
    - 253
    - 34
    - 187
    - 253
    - 26
    - 66
    - 70
  log_directory: /var/log/zigbee2mqtt/%TIMESTAMP%
  log_file: log.txt
  log_level: warning
  channel: 26
frontend:
  enabled: true
  package: zigbee2mqtt-frontend
  port: 8081
homeassistant:
  enabled: false
onboarding: false
I´m trying for 2 days now, but I can´t find the problem. Maybe someone has an idea here?
thx in advance!
Zigbee2mqtt has its own forum which is linked on Homepage of zigbee2mqtt or you may have a look in the users guide of z2m
yes, but I´m not quite sure if this is also a OH5 problem!? Maybe someone is here who uses a Rpi4, Sonoff Dongle-P and OH 5 just like me but without those problems…
edit:
Ok, after chatting a week with ChatGPT, I finally found the problem now: piVCCU3 !!
The raw-uart seems to reset all serial devices every few seconds… After
sudo systemctl stop pivccu
Z2M just started! Well, solved one problem, created a new one: I absolutely need piVCCU because of my homematic devices…
edit: Ok, I switched from piVCCU3 to debmatic, now it works all fine!! Thx!
