- Platform information:
- Hardware: Raspi4 2GB / SSD
- OS: latest version with Openhabian
- Java Runtime Environment: as installed by openhabian
- openHAB version:4.1
After installing MQTT Mosquitto with openhabian option 23 i tried to install zigbee2mqtt with openhabian option 2A.
The installtion aborts with failure:
mkdir -p /opt/zigbee2mqtt
+ mkdir -p /opt/zigbee2mqtt
+ return 0
+ cond_redirect chown openhabian /opt/zigbee2mqtt
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ chown openhabian /opt/zigbee2mqtt \033[39;49;00m'
+ chown openhabian /opt/zigbee2mqtt
chown: invalid user: openhabian
+ return 1
+ echo 'FAILED (chown /opt/zigbee2mqtt)'
openhabian is the user from MQTT, but i don’t have an user on system level with this name.
Is this an issue with openhabian or what else might be wrong?
here the a longe excerpt from the log:
+ choice2='2A | Zigbee2MQTT'
+ '[' 0 -eq 1 ']'
+ '[' 1 -eq 255 ']'
+ wait_for_apt_to_finish_update
+ local 'spin=-\|/'
+ local i
+ [[ -z 12055 ]]
++ timestamp
++ printf '%(%F_%T_%Z)T\n' -1
+ echo -n '2024-01-18_13:27:06_CET [openHABian] Updating Linux package information... '
2024-01-18_13:27:06_CET [openHABian] Updating Linux package information... + kill -0 12055
+ echo OK
OK
+ case "$choice2" in
+ zigbee2mqtt_setup install
+ local zigbee2mqttBase
+ local 'z2mInstalledText=A configuration for Zigbee2MQTT is already existing.\n\nWould you like to update Zigbee2MQTT to the latest version with this configuration?'
+ local 'introText=A MQTT-server is required for Zigbee2mqtt. If you haven'\''t installed one yet, please select <cancel> and come back after installing one (e.g. Mosquitto).\n\nZigbee2MQTT will be installed from the official repository.\n\nDuration is about 4 minutes... '
+ local 'installText=Zigbee2MQTT is installed from the official repository.\n\nPlease wait about 4 minutes... '
+ local 'uninstallText=Zigbee2MQTT is completely removed from the system.'
+ local 'adapterText=Please select your zigbee adapter:'
+ local 'mqttUserText=\nPlease enter your MQTT-User (default = openhabian):'
+ local 'mqttPWText=\nIf your MQTT-server requires a password, please enter it here:'
+ local my_adapters
+ local by_path_or_id
+ local mqttDefaultUser=openhabian
+ local mqttUser
+ local serverIP
+ local installSuccessText
+ local updateSuccessText
+ local loopSel=1
++ hostname -I
+ serverIP='xxxxxxxxxxxxxxx '
+ serverIP='xxxxxxxxxxxxxxx'
+ installSuccessText='Setup was successful. Zigbee2MQTT is now up and running.\n\nFor further Zigbee-settings open frontend (in 2 minutes): \nhttp://192.168.179.3 fd00::1:3c1e:97fa:84b7:8aea:8081.\n\nDocumentation of ZigBee2MQTT:\nhttps://www.zigbee2mqtt.io/guide/configuration'
+ updateSuccessText='Update successful. \n\nFor further Zigbee-settings open frontend (in 2 minutes): \nhttp://192.168.179.3 fd00::1:3c1e:97fa:84b7:8aea:8081.\n\nDocumentation of Zigbee2MQTT:\nhttps://www.zigbee2mqtt.io/guide/configuration'
+ [[ install == \r\e\m\o\v\e ]]
+ [[ install != \i\n\s\t\a\l\l ]]
+ [[ -e /opt/zigbee2mqtt/data/configuration.yaml ]]
+ IFS=
+ read -r line
++ ls /dev/serial/by-id
+ my_adapters=' usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230829110956-if00 1 '
+ by_path_or_id=by-id
+ loopSel=0
+ IFS=
+ read -r line
+ [[ usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230829110956-if00 1 == '' ]]
+ unset IFS
+ [[ -n 1 ]]
+ whiptail --title 'Zigbee2MQTT installation' --yes-button Continue --no-button Cancel --yesno 'A MQTT-server is required for Zigbee2mqtt. If you haven'\''t installed one yet, please select <cancel> and come back after installing one (e.g. Mosquitto).\n\nZigbee2MQTT will be installed from the official repository.\n\nDuration is about 4 minutes... ' 14 80
Zigbee2MQTT installation A MQTT-server is required for Zigbee2mqtt. If you haven't installed one yet, please select <cancel> and come back after installing one (e.g. Mosquitto). Zigbee2MQTT will be installed from the official repository. Duration is about 4 minutes... <Continue> <Cancel>
++ whiptail --noitem --title 'Zigbee2MQTT installation' --radiolist 'Please select your zigbee adapter:' 14 100 4 usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230829110956-if00 1
Zigbee2MQTT installation Please select your zigbee adapter: (*) usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230829110956-if00 <Ok> <Cancel> *<Ok>
+ selectedAdapter=usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230829110956-if00
++ whiptail --title 'MQTT User' --inputbox '\nPlease enter your MQTT-User (default = openhabian):' 10 80 openhabian
MQTT User Please enter your MQTT-User (default = openhabian): openhabian__________________________________________________________________ <Ok> <Cancel> <Ok>
+ mqttUser=openhabian
++ whiptail --title 'MQTT password' --passwordbox '\nIf your MQTT-server requires a password, please enter it here:' 10 80
MQTT password If your MQTT-server requires a password, please enter it here: ____________________________________________________________________________ <Ok> <Cancel> ********<Ok>
+ mqttPW='xxxxxxxxxxxx'
+ whiptail --title 'Zigbee2MQTT installation' --infobox 'Zigbee2MQTT is installed from the official repository.\n\nPlease wait about 4 minutes... ' 14 80
Zigbee2MQTT installation Zigbee2MQTT is installed from the official repository. Please wait about 4 minutes...
+ cond_redirect nodejs_setup
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ nodejs_setup \033[39;49;00m'
$ nodejs_setup
+ nodejs_setup
+ node_is_installed
++ command -v npm
+ [[ -x /usr/bin/npm ]]
++ node --version
+ [[ v18.17.1 =~ v1[6-9]* ]]
+ return 0
+ is_armv6l
+ [[ '' == \a\r\m\v\6\l ]]
+ case "$(uname -m)" in
++ uname -m
+ return 1
+ return 0
+ return 0
++ timestamp
+ echo -n '2024-01-18_13:27:47_CET [openHABian] Downloading Zigbee2MQTT... '
2024-01-18_13:27:47_CET [openHABian] Downloading Zigbee2MQTT... ++ npm list
++ head -n 1
+ zigbee2mqttBase=/opt/node_modules/zigbee2mqtt
+ [[ -d /opt/node_modules/zigbee2mqtt ]]
+ cond_redirect zigbee2mqtt_download /opt
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ zigbee2mqtt_download /opt \033[39;49;00m'
+ zigbee2mqtt_download /opt
++ timestamp
+ echo -n '2024-01-18_13:27:49_CET [openHABian] Downloading Zigbee2MQTT... '
2024-01-18_13:27:49_CET [openHABian] Downloading Zigbee2MQTT... + cond_redirect mkdir -p /opt/zigbee2mqtt
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ mkdir -p /opt/zigbee2mqtt \033[39;49;00m'
+ return 0
+ [[ -n '' ]]
+ return 1
+ cond_redirect chgrp openhab /opt/zigbee2mqtt
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ chgrp openhab /opt/zigbee2mqtt \033[39;49;00m'
+ chgrp openhab /opt/zigbee2mqtt
+ return 0
+ cond_redirect sudo -u habianadm git clone https://github.com/Koenkk/zigbee2mqtt.git /opt/zigbee2mqtt
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ sudo -u habianadm git clone https://github.com/Koenkk/zigbee2mqtt.git /opt/zigbee2mqtt \033[39;49;00m'
+ sudo -u habianadm git clone https://github.com/Koenkk/zigbee2mqtt.git /opt/zigbee2mqtt
Cloning into '/opt/zigbee2mqtt'...
/opt/zigbee2mqtt/.git: Permission denied
+ return 1
+ echo 'FAILED (git clone)'
FAILED (git clone)
+ return 1
+ return 1
+ echo 'FAILED (download)'
FAILED (download)
+ return 1
+ '[' 1 -ne 0 ']'
+ whiptail --msgbox 'There was an error or interruption during the execution of:\n "20 | Optional Components"\n\nPlease try again. If the error persists, please read /opt/openhabian/docs/openhabian-DEBUG.md or https://github.com/openhab/openhabian/blob/main/docs/openhabian-DEBUG.md how to proceed.' 14 80
There was an error or interruption during the execution of: "20 | Optional Components" Please try again. If the error persists, please read /opt/openhabian/docs/openhabian-DEBUG.md or https://github.com/openhab/openhabian/blob/main/docs/openhabian-DEBUG.md how to proceed. <Ok>
+ return 0
+ true
+ show_main_menu
+ local choice
+ local version
+++ get_git_revision
+++ local branch
+++ local commitDate
+++ local shorthash
++++ git -C /opt/openhabian rev-parse --abbrev-ref HEAD
+++ branch=openHAB
++++ git -C /opt/openhabian log --pretty=format:%aI -n 1
+++ commitDate=2023-12-31T13:09:51+01:00
++++ git -C /opt/openhabian log --pretty=format:%h -n 1
+++ shorthash=9ac4ddd
+++ echo '[openHAB]{2023-12-31T13:09:51+01:00}(9ac4ddd)'
++ whiptail --title 'openHABian Configuration Tool [openHAB]{2023-12-31T13:09:51+01:00}(9ac4ddd)' --menu 'Setup Options' 24 118 16 --cancel-button Exit --ok-button Execute '00 | About openHABian' 'Information about the openHABian project and this tool' '' '' '01 | Select Branch' 'Select the openHABian config tool version ("branch") to run' '02 | Upgrade System' 'Update all installed software packages (incl. openHAB) to their latest version' '03 | Install openHAB' 'Install or upgrade to latest openHAB' '04 | Import config' 'Import an openHAB configuration from file or URL' '' '' '10 | Apply Improvements' 'Apply the latest improvements to the basic openHABian setup ' '20 | Optional Components' 'Choose from a set of optional software components ' '30 | System Settings' 'A range of system and hardware related configuration steps ' '40 | openHAB Related' 'Switch the installed openHAB version or apply tweaks ' '50 | Backup/Restore' 'Manage backups and restore your system '
