Hi all,
is there a way to “ignore” errors that happen due to a THING on a zigbee2mqtt device that has a JSON value for the battery (.battery). The problem is that not every message includes the JSON value for battery. so an error happens, like this…
2024-03-26 22:51:59.762 [WARN ] [t.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.battery' in '{"battery_low":false,"linkquality":72,"tamper":false,"water_leak":false}'
I understand the problem, but is there any way smarter to better handle this so its not enforced to look and alarm if this parameter is not included with every message received from MOSQUITTO.
Cheers, Thanks Norbert
