Hi hopefully someone can help shed some light on a problem I am having with a device that has stopped working.
- Platform information:
- RPi 4 with SONOFF Zigbee 3.0 USB Dongle Plus
- OPENHABIAN 3.3.0 Release Build
I have a Frient Motion Sensor Pro (which Zigbee2mqtt identifies as a Develco MOSZB-140 and states it is supported) until recently it used to work fine displaying: Occupancy, illuminance, Temperature, Battery state etc. However since I ran an update in openhab-config the device has stopped working with the frontail log showing:
2022-10-13 10:18:14.177 [WARN ] [t.generic.ChannelStateTransformation] - Executing the JINJA-transformation failed: An error occurred while transformation. UnknownTokenException: Unknown token found: value_json.temperature
2022-10-13 10:18:14.180 [WARN ] [t.generic.ChannelStateTransformation] - Executing the JINJA-transformation failed: An error occurred while transformation. UnknownTokenException: Unknown token found: value_json.led_control
2022-10-13 10:18:14.188 [WARN ] [t.generic.ChannelStateTransformation] - Executing the JINJA-transformation failed: An error occurred while transformation. UnknownTokenException: Unknown token found: value_json.illuminance_lux
2022-10-13 10:18:14.191 [WARN ] [t.generic.ChannelStateTransformation] - Executing the JINJA-transformation failed: An error occurred while transformation. UnknownTokenException: Unknown token found: value_json.occupancy_timeout
It would appear that the values for temperature and illuminance are null. I suspect that the problem may be with teh Zigbee2mqtt interface.
Does anyone have any suggestions as to what the problem may me and how I might fix it?
Cheers
Ken
