- Platform information:
- Hardware: iN305/32GB/512GB SSD
- OS: docker: openhab/openhab:latest (4.3.3)
- Java Runtime Environment: embedded
- openHAB version: 4.3.3
- Issue of the topic:
I appreciate all of the hard work that goes into making openHAB a reality. This is a fantastic product which should make all of the contributors proud. I appreciate how inclusive this community is and how helpful everyone is in the forums.
I’m getting quite a few of these in my openhab.log
2025-03-11 16:57:41.861 [WARN ] [l.HomeAssistantChannelTransformation] - Applying template {"latest_version":"{{ value_json['update']['latest_version'] }}","installed_version":"{{ value_json['update']['installed_version'] }}","update_percentage":{{ value_json['update'].get('progress', 'null') }},"in_progress":{{ (value_json['update']['state'] == 'updating')|lower }}} for component update/0x282c02bfffedf40a/update failed: Cannot find method get with 2 parameters in class com.hubspot.jinjava.objects.collections.SizeLimitingPyMap (class com.hubspot.jinjava.interpret.FatalTemplateErrorsException)
My Thing definition (automagically discovered and created) is:
UID: mqtt:homeassistant:8fd56e1f3c:zigbee2mqtt_5F0x282c02bfffedf40a
label: ThirdReality-Outlet-T2
thingTypeUID: mqtt:homeassistant_zigbee2mqtt_5F0x282c02bfffedf40a
configuration:
topics:
- select/0x282c02bfffedf40a/power_on_behavior
- sensor/0x282c02bfffedf40a/ac_frequency
- sensor/0x282c02bfffedf40a/current
- sensor/0x282c02bfffedf40a/energy
- sensor/0x282c02bfffedf40a/last_seen
- sensor/0x282c02bfffedf40a/linkquality
- sensor/0x282c02bfffedf40a/power
- sensor/0x282c02bfffedf40a/power_factor
- sensor/0x282c02bfffedf40a/voltage
- switch/0x282c02bfffedf40a/switch
- update/0x282c02bfffedf40a/update
basetopic: homeassistant
bridgeUID: mqtt:broker:8fd56e1f3c
channels:
- id: last_seen
channelTypeUID: mqtt:ha-string-advanced
label: Last seen
configuration:
component: sensor
- '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{
value_json.state
}}"},{"topic":"zigbee2mqtt/ThirdReality-Outlet-T2/availability","value_template":"{{
value_json.state
}}"}],"availability_mode":"all","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0x282c02bfffedf40a"],"manufacturer":"Third
Reality","model":"Zigbee / BLE smart plug with
power","model_id":"3RSP02028BZ","name":"ThirdReality-Outlet-T2","sw_version":"v1.00.74","via_device":"zigbee2mqtt_bridge_0xe0798dfffeb31d63"},"device_class":"timestamp","enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:clock","name":"Last
seen","object_id":"thirdreality-outlet-t2_last_seen","origin":{"name":"Zigbee2MQTT","sw":"2.1.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/ThirdReality-Outlet-T2","unique_id":"0x282c02bfffedf40a_last_seen_zigbee2mqtt","value_template":"{{
value_json.last_seen }}"}'
nodeid: "0x282c02bfffedf40a"
objectid:
- last_seen
- id: linkquality
channelTypeUID: mqtt:ha-number-advanced
label: Linkquality
configuration:
component: sensor
value_json.state
value_json.state
power","model_id":"3RSP02028BZ","name":"ThirdReality-Outlet-T2","sw_version":"v1.00.74","via_device":"zigbee2mqtt_bridge_0xe0798dfffeb31d63"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","name":"Linkquality","object_id":"thirdreality-outlet-t2_linkquality","origin":{"name":"Zigbee2MQTT","sw":"2.1.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/ThirdReality-Outlet-T2","unique_id":"0x282c02bfffedf40a_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{
value_json.linkquality }}"}'
objectid:
- linkquality
- id: current
label: MQTT Sensor
configuration:
component: sensor
value_json.state
value_json.state
power","model_id":"3RSP02028BZ","name":"ThirdReality-Outlet-T2","sw_version":"v1.00.74","via_device":"zigbee2mqtt_bridge_0xe0798dfffeb31d63"},"device_class":"current","enabled_by_default":false,"entity_category":"diagnostic","object_id":"thirdreality-outlet-t2_current","origin":{"name":"Zigbee2MQTT","sw":"2.1.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/ThirdReality-Outlet-T2","unique_id":"0x282c02bfffedf40a_current_zigbee2mqtt","unit_of_measurement":"A","value_template":"{{
value_json.current }}"}'
objectid:
- current
- id: ac_frequency
label: MQTT Sensor
configuration:
component: sensor
value_json.state
value_json.state
power","model_id":"3RSP02028BZ","name":"ThirdReality-Outlet-T2","sw_version":"v1.00.74","via_device":"zigbee2mqtt_bridge_0xe0798dfffeb31d63"},"device_class":"frequency","enabled_by_default":false,"entity_category":"diagnostic","object_id":"thirdreality-outlet-t2_ac_frequency","origin":{"name":"Zigbee2MQTT","sw":"2.1.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/ThirdReality-Outlet-T2","unique_id":"0x282c02bfffedf40a_ac_frequency_zigbee2mqtt","unit_of_measurement":"Hz","value_template":"{{
value_json.ac_frequency }}"}'
objectid:
- ac_frequency
- id: power
label: MQTT Sensor
configuration:
component: sensor
value_json.state
value_json.state
power","model_id":"3RSP02028BZ","name":"ThirdReality-Outlet-T2","sw_version":"v1.00.74","via_device":"zigbee2mqtt_bridge_0xe0798dfffeb31d63"},"device_class":"power","enabled_by_default":true,"entity_category":"diagnostic","object_id":"thirdreality-outlet-t2_power","origin":{"name":"Zigbee2MQTT","sw":"2.1.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/ThirdReality-Outlet-T2","unique_id":"0x282c02bfffedf40a_power_zigbee2mqtt","unit_of_measurement":"W","value_template":"{{
value_json.power }}"}'
objectid:
- power
- id: voltage
label: MQTT Sensor
configuration:
component: sensor
value_json.state
value_json.state
power","model_id":"3RSP02028BZ","name":"ThirdReality-Outlet-T2","sw_version":"v1.00.74","via_device":"zigbee2mqtt_bridge_0xe0798dfffeb31d63"},"device_class":"voltage","enabled_by_default":false,"entity_category":"diagnostic","object_id":"thirdreality-outlet-t2_voltage","origin":{"name":"Zigbee2MQTT","sw":"2.1.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/ThirdReality-Outlet-T2","unique_id":"0x282c02bfffedf40a_voltage_zigbee2mqtt","unit_of_measurement":"V","value_template":"{{
value_json.voltage }}"}'
objectid:
- voltage
- id: energy
label: MQTT Sensor
configuration:
component: sensor
value_json.state
value_json.state
power","model_id":"3RSP02028BZ","name":"ThirdReality-Outlet-T2","sw_version":"v1.00.74","via_device":"zigbee2mqtt_bridge_0xe0798dfffeb31d63"},"device_class":"energy","enabled_by_default":true,"object_id":"thirdreality-outlet-t2_energy","origin":{"name":"Zigbee2MQTT","sw":"2.1.3","url":"https://www.zigbee2mqtt.io"},"state_class":"total_increasing","state_topic":"zigbee2mqtt/ThirdReality-Outlet-T2","unique_id":"0x282c02bfffedf40a_energy_zigbee2mqtt","unit_of_measurement":"kWh","value_template":"{{
value_json.energy }}"}'
objectid:
- energy
- id: power_factor
label: Power factor
configuration:
component: sensor
value_json.state
value_json.state
power","model_id":"3RSP02028BZ","name":"ThirdReality-Outlet-T2","sw_version":"v1.00.74","via_device":"zigbee2mqtt_bridge_0xe0798dfffeb31d63"},"enabled_by_default":false,"entity_category":"diagnostic","name":"Power
factor","object_id":"thirdreality-outlet-t2_power_factor","origin":{"name":"Zigbee2MQTT","sw":"2.1.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/ThirdReality-Outlet-T2","unique_id":"0x282c02bfffedf40a_power_factor_zigbee2mqtt","value_template":"{{
value_json.power_factor }}"}'
objectid:
- power_factor
- id: power_on_behavior
label: Power-on behavior
configuration:
component: select
value_json.state
value_json.state
}}"}],"availability_mode":"all","command_topic":"zigbee2mqtt/ThirdReality-Outlet-T2/set/power_on_behavior","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0x282c02bfffedf40a"],"manufacturer":"Third
power","model_id":"3RSP02028BZ","name":"ThirdReality-Outlet-T2","sw_version":"v1.00.74","via_device":"zigbee2mqtt_bridge_0xe0798dfffeb31d63"},"entity_category":"config","icon":"mdi:power-settings","name":"Power-on
behavior","object_id":"thirdreality-outlet-t2_power_on_behavior","options":["off","previous","on"],"origin":{"name":"Zigbee2MQTT","sw":"2.1.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/ThirdReality-Outlet-T2","unique_id":"0x282c02bfffedf40a_power_on_behavior_zigbee2mqtt","value_template":"{{
value_json.power_on_behavior }}"}'
objectid:
- power_on_behavior
- id: switch
channelTypeUID: mqtt:ha-switch
configuration:
component: switch
value_json.state
value_json.state
}}"}],"availability_mode":"all","command_topic":"zigbee2mqtt/ThirdReality-Outlet-T2/set","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0x282c02bfffedf40a"],"manufacturer":"Third
power","model_id":"3RSP02028BZ","name":"ThirdReality-Outlet-T2","sw_version":"v1.00.74","via_device":"zigbee2mqtt_bridge_0xe0798dfffeb31d63"},"name":null,"object_id":"thirdreality-outlet-t2","origin":{"name":"Zigbee2MQTT","sw":"2.1.3","url":"https://www.zigbee2mqtt.io"},"payload_off":"OFF","payload_on":"ON","state_topic":"zigbee2mqtt/ThirdReality-Outlet-T2","unique_id":"0x282c02bfffedf40a_switch_zigbee2mqtt","value_template":"{{
value_json.state }}"}'
objectid:
- switch
Claude.ai has suggested making modifications to the Thing definition (which would mean going back to manually/textual .things, with something like this:
- id: update
label: Update
configuration:
component: update
- '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"},{"topic":"zigbee2mqtt/ThirdReality-Outlet-T2/availability","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0x282c02bfffedf40a"],"manufacturer":"Third Reality","model":"Zigbee / BLE smart plug with power","model_id":"3RSP02028BZ","name":"ThirdReality-Outlet-T2","sw_version":"v1.00.74","via_device":"zigbee2mqtt_bridge_0xe0798dfffeb31d63"},"entity_category":"diagnostic","name":"Update","object_id":"thirdreality-outlet-t2_update","origin":{"name":"Zigbee2MQTT","sw":"2.1.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/ThirdReality-Outlet-T2","unique_id":"0x282c02bfffedf40a_update_zigbee2mqtt","value_template":"{{ value_json[\"update\"][\"progress\"] if value_json[\"update\"][\"progress\"] is defined else (value_json[\"update\"][\"state\"] if value_json[\"update\"][\"state\"] is defined else \"\") }}"}'
objectid:
- update
or
updating my zigbee2mqtt config.yaml to something like this:
homeassistant:
discovery_topic: homeassistant
status_topic: homeassistant/status
legacy_entity_attributes: false
legacy_triggers: false
device_registry: true
# Add this section for customizing the update entity format
device_automation: true
customization:
device_reg:
"0x282c02bfffedf40a": # Your ThirdReality-Outlet's IEEE address
update:
enabled: false # This disables the update entity completely
# Or alternatively, use a simplified format
# value_template: "{{ value_json['state'] }}"
Neither of these options is very appealing to me because they both require a high degree of manual configuration across a large number of devices. I’m looking for a third way, or, I’m looking for a way to configure this for at least 20 devices without having to make manual adjustments for all of them. Or… maybe I just need to ignore them…
