Release = Raspbian GNU/Linux 11 (bullseye)
Kernel = Linux 5.15.84-v7l+
Platform = Raspberry Pi 4 Model B Rev 1.2
openHAB 3.4.1 - Release Build
Hello there,
After I got some troubles with DeConz, which can’t be fixed atm (github issue)
I decided to give the workaround using Zigbee2Tasmota a try.
I’ve bought a SONOFF Zigbee Bridge Pro and flashed Tasmota on it. → works fine
Already I’ve discovered devices with Tasmota which work within the tasmota surroundings fine
My Problem is, I really don’t know how to configure the Zigbee2Tasmota as a Bridge into OH3.
I’ve found some topics from 2019/2020 that didn’t help me a lot.
It is possible that I am just too helpless to understand the threads.
My biggest problem is, how to configure the MQTT Explorer so that I am able to “see” my devices from the Tasmota Bridge.
And how to configure the Zigbee Bridge in OH3.
Also, I am not able to TELNET to the Tasmota device, some People write about opening the TCP Port 8888, which I think needs to be open.
My last try was to follow the instruction of an older thread to create a Zigbee Bridge (Ember Coordinator) where the Serial Port Configuration should be " /dev/ttyzbbridge
This doesn’t exist in OH3 for me anymore.
I think everyone sees I don’t have any clue what to do and where to start.
There is too much cryptic information available for me to get a clearly start.
Maybe someone would be so kind give me some hints on where to start and how to start
I would be very happy.
