I have been wanting to upgrade to OH3 for some time and tried to upgrade to this version.
I’ve used OH2 so far and haven’t had many problems.
This time, because I decided to additionally run zigbee communication on Sonoff bridge with the Tasmot version,
I was able to run everything correctly in the Tasmot range, I can see the sensors, I can see MQTT communication but OH does not read the sensor data in any way.
On Tasmota, I have the topic / tasmota2mqtt / Salon / SENSOR and the following data:
{“ZbReceived”: {“Salon”: {“Device”: “0x3740”, “Name”: “Salon”, “Humidity”: 61.03, “Endpoint”: 1, “LinkQuality”: 97}}}
I created things with this code:
UID: mqtt:topic:615f38407a:9cf1f8f55e
label: Salon Temperatura
thingTypeUID: mqtt:topic
configuration: {}
bridgeUID: mqtt:broker:615f38407a
channels:
channelTypeUID: mqtt:number
label: Temperatura w salonie
description: “”
configuration:
stateTopic: /tasmota2mqtt/Salon/SENSOR
unit: “‘°C’”
and JSON transformation:
‘JSONPATH:$.ZbReceived.Salon.Humidity’
Unfortunately, I can’t read anything, in addition, I can’t find the logs in OH3? Is there no web log version here?
the slash may be unusual but it shouldn’t cause problems, I have other devices with themes (not zibgee) and here it works
I have the JSONPATH add-on installed but for some reason it doesn’t transform my data
There was a nice version of the logs on the website in OH2, now there’s only a file or data in the console?
No, there wasn’t. Did you use openhabian perhaps, or otherwise install a log viewer add-on? Fronttail is popular for this use.
Maybe it’s not getting any data to transform. No mention of transformation in your channels config, are you trying to use a profile instead?
Note that you cannot pass a JSON message to a profile through a number or datetime type channels, they’ll only pass numbers or datetimes.
If you must pass the whole message to a profile, you’ll need a string channel.
I ran my sara installation with MQTT1.x binding and this configuration: Number TempSalon "Salon [%.2f °C]"<video>(Temperatura, TempParter, Salon) {mqtt="<[home:/tasmota2mqtt/Salon/SENSOR:state:JSONPATH($.ZbReceived.Salon.Temperature)]"}
And it works.
I don’t know why it doesn’t work in OH3
